Any solutions to this?
Itâs an esphome issue not an issue with this card so I hope you logged the issue in esphome?
@DavidFW1960 are you suggesting the NaN issue showing up on lovelace (even when latest values are non NaN or non ZERO) is an ESPHome issue and not a card issue?
I would have thought not being able to discard/ignore the one NaN (seen over the last 24hrs) would be a card issue.
Cheers,
Trevor
Ah⊠if the entity isnât NaN and the card isnât showing the current entity value it would be the card. I donât see NaN on any of mine - but I donât use esphome.
No, thereâs a feature request open over at github for the feature though.
The format of the state is most likely reported in a number format not supported/correctly parsed by the card which could result in NaN (not a number) as the output,
Iâve answered you over at github, letâs continue the discussion there.
I have downloaded the source code a month ago and compiled mini-graph-card-bundle.js v0.9.4. The aggregate func delta works fine. But now I donât see anything regarding delta and 0.9.4. I have no idea why this was removed.
Thank you for the reply, no worries. Great card though.
It wasnât removed, itâs currently only available in the dev branch though, I should really do a new release⊠maybe tonight or tomorrow.
Juhu. Soft upper and lower bounds will be great to have ![]()
Is there anyway to show the event time on the horizontal axis?
No, but planning on adding that soon.
I actually like the simplify of the graph without axes. Great for a quick glance at a trend.
Where a full featured Graph is required I use Grafana.
Yes, same here and the original design and idea was to keep the graph very minimalistic and light on information. Itâs also why I decided to build the graph lib from the ground up.
The feature request has been quite popular though which made me reconsider the idea.
Itâll of course be optional.
Hi all,
I am kinda new to this Home Assistant thing, but I really enjoy configuring it until I ran into this annoying issue I am having.
So I want 1 lovelace card with a sensor in the top, and then 2x2 graphs below it. Something like this:
However, this is what I can get:
This is what I got so far:
entities:
- entity: sensor.bloomhole_seen_clients
icon: 'mdi:devices'
name: Numer of Clients
- align_state: left
entities:
- color: '#19D541'
entity: sensor.bloomhole_dns_queries_today
font_size: 75
font_size_header: 22
hour24: true
line_width: 3
points_per_hour: 2
icon: 'mdi:earth'
show:
icon: true
points: false
style: |
ha-card {
border-radius: 12px;
background-image: none;
box-shadow: none;
background-color: rgba(114, 123, 140, 0.1);
font-weight: bold;
type: 'custom:mini-graph-card'
- align_state: left
entities:
- color: '#20BEE5'
entity: sensor.bloomhole_ads_blocked_today
font_size: 75
hour24: true
line_width: 3
points_per_hour: 2
icon: 'mdi:hand-right'
show:
icon: true
points: false
style: |
ha-card {
box-shadow: none;
font-weight: bold;
- align_state: left
entities:
- color: '#EEA527'
entity: sensor.bloomhole_ads_percentage_blocked_today
font_size: 75
hour24: true
line_width: 3
points_per_hour: 2
icon: 'mdi:chart-pie'
show:
icon: true
points: false
style: |
ha-card {
box-shadow: none;
font-weight: bold;
- align_state: left
entities:
- color: '#DC3F1C'
entity: sensor.bloomhole_domains_blocked
name: Domains on Blocklist
font_size: 75
hour24: true
line_width: 3
points_per_hour: 2
icon: 'mdi:format-list-bulleted'
show:
icon: true
points: false
style: |
ha-card {
box-shadow: none;
font-weight: bold;
show_header_toggle: false
title: PiHole
type: entities
When I try to change this to what I want, it gives an error:
This is what I try:
entities:
icon: 'mdi:devices'
- type: horizontal-stack
cards:
- align_state: left
entities:
- color: '#19D541'
font_size: 75
hour24: true
line_width: 3
points_per_hour: 2
icon: 'mdi:earth'
show:
icon: true
points: false
style: |
ha-card {
box-shadow: none;
font-weight: bold;
- align_state: left
entities:
- color: '#20BEE5'
font_size: 75
hour24: true
line_width: 3
points_per_hour: 2
show:
icon: true
points: false
style: |
ha-card {
box-shadow: none;
font-weight: bold;
- align_state: left
entities:
- color: '#EEA527'
font_size: 75
hour24: true
line_width: 3
points_per_hour: 2
show:
icon: true
points: false
style: |
ha-card {
box-shadow: none;
font-weight: bold;
- align_state: left
entities:
- color: '#DC3F1C'
font_size: 75
hour24: true
line_width: 3
points_per_hour: 2
show:
icon: true
points: false
style: |
ha-card {
box-shadow: none;
font-weight: bold;
title: PiHole
type: entities
Any ideas to get what I want?
This has nothing to do with the mini-graph card and this was the wrong place to post. You need to use a couple of tricks to put a horizontal stack in an entities card. See here: đč hui-element - Use built-in elements in the wrong place
Thanks! That is exactly what Iâm looking for.
I am trying to use the mini-graph card with this code.
# Atmospheric Quality
- type: "custom:vertical-stack-in-card"
cards:
- type: 'custom:mini-graph-card'
align_state: 'right'
decimals: 0
height: 50
hour24: false
unit: 'AQI'
color_thresholds:
- value: 0
color: '#00e400'
- value: 51
color: '#ffff00'
- value: 101
color: '#ff7e00'
- value: 151
color: '#ff0000'
- value: 201
color: '#990049'
- value: 301
color: '#4c0026'
show:
fill: 'fade'
icon: false
labels: true
points: true
entities:
# - entity: sensor.aqi
- entity: sensor.aqi_particles
color: 'Brown'
- entity: sensor.aqi_ozone
color: 'DeepSkyBlue'
- entity: sensor.aqi_carbon_monoxide
color: 'DarkSlateGray'
This is the view I get
What am I doing wrong (I have all the cards installed in HACS and in Lovelace)
carltonb
Thereâs most likely no history available for the entities.
See recorder and make sure itâs setup, working & recording the entities correctly.
Thank you for the hint.
Stupid yaml spacing on my part failed the recorder.yaml file.
Appreciate it.
for some reason my graphs are not showing. any idea where i should look for. did re-installation too but no luck.
color_thresholds:
- color: '#ff0505'
value: 74
- color: '#ff7a05'
value: 70
- color: '#ffcd05'
value: 65
entities:
- sensor.cpu_temperature
show:
labels: true
