In other words, or illustrated by a more simple example…
What I am trying to achieve is having the fill underneath the line just as red as the line itself (this is an edited screenshot):
I was thinking it was more faint because it is opaque to some degree but it seems there is more going on here…
Is it possible at all and how?
JasonLee
(Jason)
November 6, 2021, 11:35am
1915
How do I change the proportions on the mini graph card? By default, the graph appears to be 50% the height of the card and the labels 50%.
How would I adjust it, so for example the graph took up 75% of the height of the card and the labels only 25%?
And adding x and y-axis numbering is still not possible right?
JasonLee:
Could you provide a picture describing your needs?
Just for completeness, I finally managed to get it done through trial-and-error. Solution turns out to be fairly easy…
style: |
.fill {
fill: white;
opacity: 1 !important;
Graph now looks exactly how I wanted it…
Thanks!
Great, this is really nice styling))
baz123
(Brian)
November 16, 2021, 7:59am
1919
Can you set the name: of an entity to the state (string) of another entity by using a template?
Works in the Template editor but not as a name in the card
No, templates may be applied only if the card is placed inside config-template-card
Luth1ng
(Luth1ng)
November 16, 2021, 11:16pm
1921
Hi!
I would like to center three entity states, but my config doesn’t want to…
I guess it’s possible regarding the issue multiple show_state · Issue #56 · kalkih/mini-graph-card · GitHub
With 2 entities with “show_state: true” it works fine, but with 3 entities, no…
Here’s my config :
type: custom:mini-graph-card
entities:
- entity: sensor.theeye_air_temperature
color: green
show_state: true
- entity: sensor.ble_temperature_thermometre1
color: skyblue
show_fill: false
show_state: true
- entity: sensor.laporte_air_temperature
color: red
show_fill: false
show_state: true
- entity: binary_sensor.night
color: rgba(255,255,255,.25)
y_axis: secondary
aggregate_func: min
show_state: false
show_line: false
show_points: false
show_name: false
show_icon: false
state_map:
- value: 'off'
label: Jour
- value: 'on'
label: Nuit
show:
icon: false
fill: fade
line_width: 3
hours_to_show: 168
animate: true
decimals: 1
hour24: true
align_state: center
align_header: center
Could I achieve this ? How ?
Many thanks for your help
boxi
November 19, 2021, 6:55pm
1922
Hi can you share your code pls ?
EdwinNL
December 5, 2021, 1:33pm
1923
Did this ever get a follow-up?
It’s looking so, so cool!
Any idea why my mini graph cards aren’t being displayed on my nest hub when casting my dashboard from duckdns?
Happens on both my nest hub and nest hub max.
No errors or anything, still shows the state. Just no graphs. Every other custom card displays fine.
Displays fine on desktop and mobile though…
Could be due to CATT, or the nest hub itself, but it was fine when I was casting a local http dashboard (as opposed to https dns).
[Update: Must be an issue with duckdns/https and mini graph card.
Managed to setup a reverse proxy, and casting the local http site shows the graphs fine.]
did67
(Did67)
December 9, 2021, 4:42pm
1925
It’s possible to convert an ppm ?
sidlauskas
(Lukas Šidlauskas)
December 12, 2021, 6:43pm
1926
Successfully added, but it’s not working. HA core-2021.11.5. Can someone tell me what I’m doing wrong here?
You should specify at least one entity
sidlauskas
(Lukas Šidlauskas)
December 12, 2021, 9:11pm
1928
It only works when I specify it this way:
cards:
- entities:
- entity: water_heater.vicare_water
name: Water temperature
type: horizontal-stack
This code is minimal to work:
- type: custom:mini-graph-card
entities:
sidlauskas
(Lukas Šidlauskas)
December 12, 2021, 9:33pm
1930
nope, it doesn’t work this way either
This is a code to be used in yaml mode:
cards:
entities:
This is a code to be used in storage mode - i.e.creating cards from UI:
entities:
A view = a list of cards.
In yaml a list is this:
- abc
jkkkkjkj
yyyyyyyyyy
- def
jjuuy
- 123abc
pepe59
(Pepe59)
December 12, 2021, 11:42pm
1932
If you are using user interfaces, remove the hyphen at type.
entities:
- entity: sensor.living_room_temperature
SteveA
(Stephen Anderson)
December 20, 2021, 5:02pm
1933
It is possible to show_state for multiple entities in a single row as opposed to stacked across the right side? I am tracking 5 Temperature sensors and showing the legend it would be cleaner to show the legend and the current state together. Thanks
