Possible with using hacks only.
May give unstable results since card’s width is hardcoded.
And no legend is shown.
Thank you. Perhaps a future enhancement for the show_legend option?
Initial idea of @kalkih (see here), added some flexibility.
type: custom:mini-graph-card
entities:
- entity: sensor.speedtest_local_download
- entity: sensor.speedtest_local_upload
y_axis: secondary
show_state: true
show:
labels: true
labels_secondary: true
height: 300
hours_to_show: 24
line_width: 2
points_per_hour: 60
lower_bound_secondary: 0
lower_bound: 0
card_mod:
style: |
.line--rect,
.fill--rect,
.line--points {
transform: scaleY(50%);
.line--rect:last-of-type,
.fill--rect:nth-of-type(2),
.line--points:last-of-type {
transform-origin: center center;
transform: rotateX(180deg) scaleY(50%) translateY(-150px);
.graph__labels.--secondary {
flex-direction: column-reverse;
.graph__container__svg {
margin-bottom: 20px
Also, it is possible to to add a divider line as an X-axis:
entities:
y_axis: secondary
show_state: true
height: 200
show:
labels: true
fill: fade
card_mod:
style: |
.line--rect,
.fill--rect,
.line--points {
rect.fill--rect:nth-of-type(1) {
outline: 1px solid var(--secondary-text-color);
rect.fill--rect:nth-of-type(2),
rect.line--rect:last-of-type,
transform: rotateX(180deg) scaleY(50%) translateY(-100px);
margin-bottom: 16px;
How can I set a title instead of a name?
Like this:
instead of this:
I tried setting a title parameter with show name to false, but it did,t work
You may set only parameters described in docs.
This simple code:
entities:
- entity: sensor.cleargrass_1_co2
hours_to_show: 24
shows a whole graph name:
But if some point is touched by a mouse then that “graph name” is replaced by an “entity name”:
I’m charting power usage of a plug which is either consuming ~600W or ~90W, there is no in-between
But in mini-graph-chart it appears as is the power was 257W for a while, even when smoothing is disabled
“aggregate_func: max” makes it a little better but still the same problem. Is there anything else I can do? I tried others aggregate parameters too
Try aggregate_func: last
and more points_per_hour
Thank you I got it fixed but I am wondering why the min/max values are not showing up when enabling extrema?
You have not enabled extrema - check the doc. As well as legend. The code contains misplaced options.
Which doc are you referring to? I’ve read many times this one: https://github.com/kalkih/mini-graph-card
But CTRL+F on “Extrema” returns only 1 result:
And I’m not sure what I have to do with the legend either
![:confused: :confused:](https://community.home-assistant.io/images/emoji/twitter/confused.png?v=10)
How to set a color for the last bar:
- type: custom:mini-graph-card
entities:
show:
graph: bar
card_mod:
style: |
rect.bar:last-of-type {
fill: red;
(as an answer for this issue)
Hello, I was trying to make a stock graph where the color is red when the market is under the previous close value, but I not able to have variable in my code I don’t understand why. I already tried everything I could find here but it still doesn’t work.
variables:
- current_val: states['sensor.yahoofinance_cspx_as'].state
- previous_market_close: stat_attr('sensor.yahoofinance_cspx_as', 'regularMarketPreviousClose')
entities:
- sensor.yahoofinance_cspx_as
hours_to_show: 25
points_per_hour: 4
color_thresholds:
- value: '${previous_market_close}'
color: '#8AFF8A'
color: '#c0392b'
show:
labels: true
points: false
y_axis: true
show_line: true
icon_adaptive_color: true
extrema: true
Where in the mini graph card docs did you see this support for variables?
You’ll have to use config-template-card in combination with the mini-graph for what you want to achieve.
#1. Is there no option for making an X-axis in the graph? I want to have all 24h hours of the day to be displayed?
#2. Also, is there no way to be able to see all 24h in static mode. But with the current time to be marked somehow. I want to use Nordpools electricity prices forecast for the whole day to be displayed.
Now I can only see current time and 24hours history.
Is there a way to show only current day, e.g from 00.00 to 00.00 and no history from yesterday?
You could try apexcharts-card with this
type: custom:apexcharts-card
experimental:
color_threshold: true
graph_span: 1d
header:
title: Elpriser idag
show: true
span:
start: day
now:
show: true
label: Nu
series:
- entity: sensor.nordpool_kwh_se3_sek_3_10_025
data_generator: |
return entity.attributes.raw_today.map((entry) => {
return [new Date(entry.start), entry.value];
color_threshold:
- value: 0
color: green
opacity: 1
- value: 1
color: yellow
- value: 1.5
color: red
type: column
