brpeterso
(Brpeterso)
August 9, 2022, 1:38am
267
- entity: switch.keezer_socket_1
icon: mdi:fan
state_color: true
tap_action:
action: toggle
haptic: success
style:
hui-generic-entity-row:
state-badge {
color: orange;
animation: rotation 0.5s linear infinite;
@keyframes rotation {
0% {
transform: rotate(0deg);
100% {
transform: rotate(360deg);
Just went there and saw examples. Here’s what I have, but it’s not working. See anything?
Unfortunately CSS isn’t my strong point.
Here is an example I have but it’s simply something I copied from the mushroom card thread:
- type: custom:mushroom-chips-card
chips:
- type: template
entity: fan.bedroom_fan
content_info: none
use_light_color: false
card_mod: null
icon: mdi:fan
icon_color: |2-
{% set state=states('fan.bedroom_fan') %}
{% if state=='on' %}
yellow
{% elif state=='off' %}
white
{% endif %}
style: |
0% {
100% {
The difference being I have the card listed, then the style under that whereas you have that other line in there: hui-generic-entity-row:
Perhaps try modifying your code to be like the layout of mine… unless someone else with more skill can say otherwise.
You are trying to solve the problem by copy/paste: took a style for element A from card B to get an effect for element C in card D.
i.e. - this code is for another element from another card.
Check card-mod thread and find a post for multiple-entity-row, it will give you correct paths to your elements.
Animation for multiple-entity-row:
- type: custom:multiple-entity-row
entity: sun.sun
card_mod:
style:
hui-generic-entity-row $: |
state-badge {
animation: rotation_1 2s linear infinite;
@keyframes rotation_1 {
0% {
transform: rotate(359deg);
100% {
div.entity:nth-child(2) state-badge {
animation: rotation_2 0.5s linear infinite;
@keyframes rotation_2 {
0% {
100% {
entities:
- entity: sun.sun
- entity: sun.sun
icon: true
show_state: false
More styles
brpeterso
(Brpeterso)
August 9, 2022, 10:12am
271
Thanks. This is close. Now I just want it to spin when it’s on. CSS is definitely outside my comfort zone, so I have been trying to copy and paste with small tweaks to see what works.
type: entities
entities:
- entity: sensor.plaato_keg_tap1_beer_left
icon: mdi:beer
show_state: false
card_mod:
style:
hui-generic-entity-row $: ''
div.entity:nth-child(4) state-badge {
0% {
100% {
entities:
- entity: sensor.plaato_keg_tap1_percent_beer_left
- entity: sensor.plaato_keg_tap2_percent_beer_left
- entity: sensor.plaato_keg_tap4_percent_beer_left
icon: mdi:fan
state_color: true
tap_action:
action: toggle
haptic: success
Use jinjia templates inside CSS style, there are plenty of examples in card-mod thread.
I have been playing around and I am having issues in removing the unwanted sensor from my multiple entriy row, I would like to list 5 sensors results in a row, but when I add the llast sensor in the top, I am not getting any headers for it, like I do with the rest, any ideals on how to get the same results
here is my code.
type: entities
entities:
- type: divider
- entity: sensor.givtcp_export_energy_6_month_total_2024_2_compensation
Name: 2024 2nd half
entities:
- entity: sensor.givtcp_export_energy_6_month_total_2022_2_compensation
name: 2022 2nd half
- entity: sensor.givtcp_export_energy_6_month_total_2023_1_compensation
name: 2023 1st half
- entity: sensor.givtcp_export_energy_6_month_total_2023_2_compensation
name: 2023 2nd half
- entity: sensor.givtcp_export_energy_6_month_total_2024_1_compensation
name: 2024 1st half
- type: divider
title: 6 Month SEG
state_color: true
show_header_toggle: true
Solutions:
Using “styles” - decrease a width and/or font-size:
name: 2023 2nd half
styles:
font-size: 10px ### this affects to header & state
width: 50px
Using card-mod - decrease a font-size for headers only.
Go to card-mod thread → 1st post → style for multiple-entity-row
Reconsider the whole design - for example, you may use flex-grid-card (which is better for placing many values in one row).
arganto
August 14, 2022, 7:37am
275
Problem here:
chrischambers:
Name: 2024 2nd half
name: 2024 2nd half
And if you want it exactly the same, use show_state: false
for the main entity and add the 5th as the other 4.
arganto:
show_state: false
thanks this fix the issue for me.
Oh, seems now I understood the REAL issue )))
alamoudi.moh
(Mohammed Alamoudi )
August 15, 2022, 4:00pm
278
hi,
i need your support, now i have one switch with 3 toggles, as the below code, if i trun on anyone, the entire row of the three switch will turn yellow, is there a way to make only the on switch turn yellow and the rest remain as it
type: entities
entities:
- entity: switch.master_switch_01
name: Master Switch 01
icon: mdi:lightbulb-outline
tap_action:
action: call-service
service: switch.toggle
service_data:
entity_id: switch.master_switch_01
toggle: true
state_color: true
entities:
- icon: mdi:lightbulb-outline
state_color: true
tap_action:
service_data:
entity_id: switch.master_switch_01_right
state_color: true
tap_action:
service_data:
entity_id: switch.master_switch_01_center
state_color: true
tap_action:
service_data:
entity_id: switch.master_switch_01_left
I already provided you a solution here .
What is wrong with it?
state_color: true
tap_action: ----- DO NOT THINK IT NEEDED THEN
service_data:
AleXSR7001
(AleXSR700)
September 8, 2022, 2:53pm
280
Hello everyone,
I stumbled across this card searching for a solution to what I hoped would be a simple task ^^
I would like to create a row consiting of a slider (of entity 1) + state (of entity 2).
For the slider I am using custom:slider-entity-row
Is this possible with multiple-entities-row card? Or does it only support “normal” entities but cannot be combined with slider-entity-row
Here an example of the slider part:
type: entities
entities:
- type: custom:slider-entity-row
entity: climate.eq_3_living_room
and of the entities part
type: entities
entities:
- entity: sensor.xiaomi_temperature_living_room
show_name: false
show_icon: false
smoysauce
(smoysauce)
September 11, 2022, 3:32am
282
Random question, but based on searching I am not sure it’s possible. I am using the Team Tracker integration which pulls in and creates an entity for a team with all the live game information/stats as attributes which includes the team logos as URLs to the PNG images. Is there a way to pull in and display these as the icon or something in the row? I haven’t had any luck, even with using the config-template card with this.
There is the associated Team Tracker Card which does this and I have tried to take pieces from, but am not great at JS. (I have used the official card, but would like to create a minimized version using the multiple entity row, if possible)
Anyone try or achieve anything like this or is it really not possible? Appreciate any insight!
If some entity has an “entity_picture
” attribute specified then this image is displayed instead of an icon.
This works for the “main entity” & the very left image/icon in the row.
Alternatively, the "image"
option may show a specified image - this also relates to the “main entity” & the very left image/icon.
Since your image is a part of some attribute - then you need to place the whole row into "config-template-card"
and extract a path from an attribute value.
If you need to show an image on the right part of the row - then find another ways like “adding an image as :after/:before pseudoclass by card-mod”.
smoysauce
(smoysauce)
September 14, 2022, 12:16am
284
I appreciate it. I’ll try that out. Do you know if it will pull the PNG from the URL or does the PNG have to actually be in the sensor/attribute?
JPG, PNG, … cannot be a bitmap inside an attribute.
It is always a path.
smoysauce
(smoysauce)
September 14, 2022, 12:31am
286
Gotcha. So this is where I am stuck where it will show the URL but for the life of me, I can’t figure out how to show the image
type: custom:config-template-card
variables:
GAME_STATE: states['sensor.ncaafb_huskers'].state
TEAM_LOGO: states['sensor.ncaafb_huskers'].attributes.league_logo
entities:
- sensor.ncaafb_huskers
card:
entities:
- entity: sensor.ncaafb_huskers
attribute: tv_network
attribute: team_score
attribute: clock
attribute: opponent_score
attribute: quarter
attribute: league_logo
image: state_attr('sensor.ncaafb_huskers', 'league_logo')
state-color: true
state_header: Status
