I just posted a fix on your other post in the HP Printer topic.
Not directly, but you can use card-mod like in @maurizio53 example above.
Primary/secondary/tertiary was replaced with entities
in version 3.0.0:
entities:
- attribute: ['Installed At']
Thanks, i realized that just after posting…
card-mod works, but for all icons in a row. Does not work on a single entity in the form of the tap_action icon. I would like the play and pause icons to be black and the main entity icon of the vacuum cleaner to be in the default color (blue). It is possible?
HI @benct
after the lates update my auto-entities card isn’t populated any longer, using this.entity_id. I think I changed all updated config options, but would you please have a look what could be wrong?:
- type: custom:auto-entities
card:
type: entities
title: Multiple lights
show_header_toggle: false
filter:
include:
- domain: light
state: 'on'
attributes:
rgb_color: '! none'
options:
type: custom:multiple-entity-row
toggle: true
secondary_info: last-changed
entities:
- entity: this.entity_id
attribute: brightness
unit: '%'
attribute: rgb_color
worked just nicely before with primary and secondary…
thanks for having a look!
update
just letting you know this is working again. Not even sure an update caused this, but all fine once more.
Great, just wat i needed.
Thank you so much.
One question, is it possible to change the size of the main icon?
I’ve even tried card-mod without succes.
ty
Is there a way to have a lock.toggle on tap_action. I want to be able to lock and unlock my front door on tap.
I have a problem using tap_action
on this card.
If I use the card to simply to show an entity (sometimes with a custom secondary info) and define a tap action of browser_mod.popup
I get the default HA more-info pop up if I tap the name or icon, but the correct popup that I defined if I tap on the state.
This config…
entity: input_number.irrigation_number_of_zones
name: Number of zones defined
tap_action:
action: call-service
service: browser_mod.popup
service_data:
title: Number of zones defined
card:
type: entities
entities:
- entity: input_number.irrigation_number_of_zones
deviceID:
- this
style:
font-family: Oswald
font-size: 14px
border-radius: 10px
box-shadow: 0px 0px 8px 2px
"--paper-dialog-background-color": "#343433" # Popup header
"--paper-card-background-color": "#343433" # Card background
…produces this
Tapping the state gives this popup (correct)
Tapping the name or icon gives this popup (incorrect)
Can anyone help?
entities:
- entity: binary_sensor.door_window_sensor_158d0002027e23
- entity: binary_sensor.door_window_sensor_158d0001fd6efe
- entity: binary_sensor.motion_sensor_158d00022548e0
- entity: light.tall
- entity: light.sofa
- entity: light.desk
- entity: switch.livingroom_light
- entity: switch.computer_light
- entity: switch.kitlight
- entity: cover.curtains
type: 'custom:multiple-entity-row'
show_state: false
entities:
- icon: 'mdi:blinds-open'
tap_action:
service: cover.open_cover
service_data:
entity_id: cover.curtains
- icon: 'mdi:stop'
tap_action:
service: cover.stop_cover
service_data:
- icon: 'mdi:blinds'
tap_action:
service: cover.close_cover
service_data:
title: Livingroom
type: entities
What does error mean? The card works fine either with that message in Chrome, Firefox, Safari but not edge (Custom element does not exisit error), the URL resource has been added.
Expected a value of type {entity,name,icon} | entity-id
for entities.9.type
but received "custom:multiple-entity-row"
Anyone help? Can you even add Multiple Entity Row to an entity card? If so can some send me an example that works
Sure, it’s just another entity in the list.
entities:
- entity: ...
- type: custom:multiple-entity-row
- entity: ...
Hi There
First I love the card, keep up the good work, Thx
Is there away to change the space between the entities on the row?
If not, this feature would really help to make it look nicer when the entities are too cramped and there is
plenty of room in the row.
Thx
Hillel
tried your code and get errors?
entities:
for entities.1.type
for entities.1.type
Got a feeling this error is mean to appear however not sure why it still fails in edge but works in all the other browsers.
Edge error
Resource URL has been added to HA dashboard in the new place.
I’m having a problem with the toggle
option for a switch
entity displaying as two buttons instead of an actual toggle.
The documentation appears to show switch
as domain that supports a normal toggle.
Perhaps MQTT switches are special case for some reason?
- type: 'custom:multiple-entity-row'
entities:
- entity: switch.smartfan_vertical
toggle: true
- entity: switch.smartfan_horizontal
toggle: true
entity: input_select.smartfan_oscillation
show_state: false
The first row is what I see and the second is what I want to see:
UPDATE: Solved my own issue, the mqtt switch was incorrectly configured as optimistic: true
I am using card this for water sensors. Both sensors have device_class set to moisture. When I use just an entity card, the state shows as “Dry”. When I add the multiple entity row type to bring in last changed and battery info, “Dry” changes to “Off”. Below is my code and a screenshot. Bug or something I did wrong?
type: entities
title: Water Sensors
entities:
- entity: binary_sensor.dome_leak_sensor_laundry
- entity: binary_sensor.dome_leak_sensor_water_heater
It is known to the dev but the fix has no known ETA
I have the same issue as ladaowner although the cause may be different. Whenever I reboot home assistant there will be a time when some sensors will show an ‘entity not available’ error. If any entity used in the multiple entity row card is not available then the entire card will error out and not be displayed. Does anyone know of a way to catch these errors more gracefully, perhaps utilising the ‘config-template-card’ or the ‘decluttering-card’? I don’t have the experience to know if this is possible or not.
Hi, @benct, I would like to thanks and congratulate - very useful custom card.
Question - is it possible to see timer counting down? As it is in entity type card.
