Lovelace: Multiple entity row
I love this frequently updated card more and more. Big thanks to @benct
Anyone succeeded in hiding an entity if unavailable or not found?
It does not work for me this way:
entities:
  - entity: light.eettafel_midden
    type: 'custom:multiple-entity-row'
    toggle: true
    entities:
      - attribute: brightness
        hide_unavailable: true
  - type: section
  - entity: media_player.werkplek
    state_color: true
    toggle: true
    icon: 'mdi:google-home'
    entities:
      - attribute: volume_level
        format: precision2
  - entity: media_player.werkplek_hub
    toggle: true
    icon: 'mdi:tablet-dashboard'
    entities:
        format: precision2
What could be (done) wrong?
I think it will also be nice to hide an entity completely if unavailable?!
Do you know what the correct record should be in the case of changes in the color of the sensor icons?
Zrzut ekranu 2020-10-23 210245
Hi, please let me know, in more detail, what you like to achieve.
So, which state of which (attribute of) sensor should lead to which action?
Maybe you can share the current code, that could be make it more clear for me.
You can post in here or send me a private message.
I mean changing the color of the icon of a given sensor depending on whether it is on or off
example: if sensor.warm_water_active is ‘on’ icon mdi:fire is yellow
if sensor.warm_water_activated_2 is ‘on’ icon mdi:fire is yellow
  - entities:
      - entity: sensor.warm_water_active
        icon: mdi:fire
      - entity: sensor.warm_water_activated_2
        icon: mdi:fire
    entity: sensor.warm_water_heating
    state: false
    show_state: false
    state_header: Grzanie wody
    state_color: true
    toggle: false
    icon: 'mdi:coolant-temperature'
sensor.warm_water_activated_2 is ‘off’
Zrzut ekranu 2020-10-24 201906 kopia
I guess you mean this?:
  - entity: sensor.warm_water_heating
    show_state: false
    state_color: true
    entities:
        icon: 'mdi:fire'
        state_color: true
        icon: 'mdi:fire'
        state_color: true
I’m new in HA, and i want to setup Multiple entity row. I’ve install this whit HACS, i create a lovelace.yaml and when my page is blank.
This is my .yaml :
  - title: Accueil
    path: accueil
    panel: false
    badges: []
    cards:
#Multiple row test1
type: entities
entities:
    - entity: sensor.nas_temperature
      type: custom:multiple-entity-row
      name: 'Temperature NAS 1'
      entities:
        - sensor.nas_temperature
#Nom de page
title: Test
Sorry, I didn’t notice the answer.
In the case of binary_sensor, of course, state_color: true will work. Unfortunately, the example I gave is the sensor and here the colors do not change as standard. I am using card-mode.
I managed to change the main icon, but not the additional one.
        style: |
          :host {
            --paper-item-icon-color:
              {% if is_state(config.entity, 'on')  %}
                var(--state-icon-active-color)
              {% else %}
                var(--state-icon-color)
              {% endif %}
Mmm… What happens if you use the colors directly instead of via a var?
        style: |
          :host {
                yellow
              {% else %}
                orangered
              {% endif %}
Maybe you could show the complete code of this part?
And, what is the info from this sensor as shown within Developer Tools?
  - entities:
        icon: 'mdi:fire'
        style: |
          :host {
                yellow
              {% else %}
                orangered
              {% endif %}
    state: false
    state_color: true
    toggle: false
After update Home Assistant custom:multiple-entity-row
Error
I have a card with the following code:
entity: sensor.wc_qp_janela
styles:
  color: var(--my-font01-color)
state_header: WC
entities:
  - entity: sensor.qp_varanda
  - entity: sensor.qp_janela
    styles:
      color: var(--my-font02-color)
style: |
  ha-card {
    --my-font02-color: {% if states('sensor.qp_janela') = "Fechada" %}red{% else %}black{% endif %};
    --my-font01-color: {% if states('sensor.wc_qp_janela') = "Aberta" %}red{% else %}black{% endif %};
The card:
The entities don’t change the color.
Some help, please?
thks
What do you get after changing ‘=’ to ‘==’ ?
Otherwise show info from sensor (attributes).
the same result :neutral_face:
thks
If you give me some more detailed info than I can take a better look at it. At best you show your complete card and the sensor info.
Hi Nico,
The sensor info:
      # Sensores de porta e janela com estado personalizado
      qp_varanda:
        friendly_name: Porta da varanda
        value_template: "{% if is_state('binary_sensor.wd_qp_porta_varanda', 'on') %}Aberta{% else %}Fechada{% endif %}"
        icon_template: "{% if is_state('binary_sensor.wd_qp_porta_varanda', 'on') %}mdi:door-open{% else %}mdi:door-closed{% endif %}"
      qp_janela:
        friendly_name: Janela
        value_template: "{% if is_state('binary_sensor.wd_qp_janela_pequena', 'on') %}Aberta{% else %}Fechada{% endif %}"
        icon_template: "{% if is_state('binary_sensor.wd_qp_janela_pequena', 'on') %}mdi:door-open{% else %}mdi:door-closed{% endif %}"
      wc_qp_janela:
        friendly_name: WC Quarto principal
        value_template: "{% if is_state('binary_sensor.wd_wc_quarto_principal', 'on') %}Aberta{% else %}Fechada{% endif %}"
        icon_template: "{% if is_state('binary_sensor.wd_wc_quarto_principal', 'on') %}mdi:window-open{% else %}mdi:window-closed{% endif %}"
The code of the complete card:
styles:
state_header: WC
entities:
    styles:
style: |
  ha-card {
    --my-font02-color: {% if states('sensor.qp_janela') == 'Fechada' %} red {% else %} black {% endif %};
    --my-font01-color: {% if states('sensor.wc_qp_janela') == 'Fechada' %} red {% else %} black {% endif %};
Thanks for your help :slight_smile:
Try this:
type: entities
entities:
  - type: 'custom:multiple-entity-row'
    show_state: true
    styles:
    state_header: WC
    entities:
        styles:
style: |
  ha-card {
Amazing…
It’s working.
NicoS, thanks for you help :slight_smile:
best regards
Hello again,
How I can put the state blink?
I try this code, but didn’t work:
type: entities
entities:
    styles:
    style: |
      ha-card {
          animation: var(--my-animation);
          @keyframes blink {
            50% {
                background: white;
                opacity: 0.0;
    state_header: WC
    entities:
        styles:
        styles:
          color: var(--my-font03-color)
style: |
  ha-card {
    --my-font01-color: {% if states('sensor.wc_qp_janela') == 'Aberta' %} red {% else %} black {% endif %};
    --my-font02-color: {% if states('sensor.qp_varanda') == 'Aberta' %} red {% else %} black {% endif %};
    --my-font03-color: {% if states('sensor.qp_janela') == 'Abeta' %} red {% else %} black {% endif %};
    --my-animation: {% if states('sensor.wc_qp_janela') == 'Aberta' %} blink 2s ease infinite  {% endif %};
I found the solution:
type: entities
entities:
    styles:
      animation: var(--my-animation01);
    style: |
      @keyframes blink {
        50% {
            background: white;
            opacity: 0.2;
    state_header: WC
    entities:
        styles:
          animation: var(--my-animation02);
        style: |
          @keyframes blink {
            50% {
                background: white;
                opacity: 0.2;
        styles:
          animation: var(--my-animation03);
        style: |
          @keyframes blink {
            50% {
                background: white;
                opacity: 0.3;
style: |
  multiple-entity-row {
    --my-animation01: {% if states('sensor.wc_qp_janela') == 'Aberta' %} blink 2s ease infinite  {% endif %};
    --my-animation02: {% if states('sensor.qp_varanda') == 'Aberta' %} blink 2s ease infinite  {% endif %};
    --my-animation03: {% if states('sensor.qp_janela') == 'Aberta' %} blink 2s ease infinite  {% endif %};
:+1: Rows in entities cards can be styled individually. For those, the styles will be applied to the shadowRoot of the element, so a good starting point (rather than ha-card ) would be :host :
See also here
I’m trying to put a entities-condition inside multiple-entity-row but failed sofar. The following code demonstrates that in case of a single entity, the condition works. But, embed the condition within multiple-entity -row fails to react. Is this an indentation issue or is it NOT DOABLE at all? Any help appreciated.
Screenshot_2020-11-13 Overview - Home Assistant
type: entities
entities:
  - entity: sensor.str_dt_in_out
  - entity: sensor.last_flame_out
    type: conditional
    conditions:
        state: '00:00'
      - entity: switch.floor_pump_208
        state_not: 'on'
    row:
  - entities:
        type: conditional
        conditions:
            state: '00:00'
            state_not: 'on'
        row:
      - entity: sensor.floor_pump_power
        unit: W
    icon: 'mdi:lightbulb'
    state_color: true
    toggle: false
show_header_toggle: false
title: ESP-MQTT
