Lovelace: Multiple entity row
Thanks a lot, found this at last! Great help.
Hi, I’m curious about how you solved it. Please share it. Thanks in advance.
I have just tried to replicate “emteedubs” example by creating the quoted input select entities and used two dummy input boolen and managed to get his documented end result. I’m now in the process of replacing the dummy entity_id’s with the once for which I was looking for this combined ‘custom:multiple-entity-row’ and ‘custom:fold-entity-row’!
Is there a way I can hide/delete the ‘On’ denotation from the main switch.study?
Screenshot_2020-11-15 Overview - Home Assistant
type: entities
entities:
  - type: 'custom:fold-entity-row'
    head:
      entity: switch.study
      type: 'custom:multiple-entity-row'
      icon: 'mdi:lightbulb'
      state_color: true
      toggle: false
      entities:
        - entity: sensor.study_light_auto_active
        - entity: sensor.study_light_on_after_sunset
        - entity: sensor.study_light_off
        - icon: 'mdi:lightbulb-outline'
          state_color: true
          tap_action:
            action: call-service
            service: switch.toggle
            service_data:
              entity_id: switch.study
    entities:
      - entity: input_boolean.study_light_auto
      - entities:
          - entity: sensor.sunset
      - entity: input_datetime.study_light_after_time
      - entity: input_datetime.study_light_not_after_time
Did you try?:
show_state: false
Bingo! :+1:
Hi all,
i created a card to show some shelly information, is possible to change false or true of an attribute value to another text?
type: 'custom:auto-entities'
show_empty: false
card:
  type: entities
  title: Shelly
filter:
  exclude:
    - attributes:
        friendly_name: Shelly*
  include:
    - entity_id: '*shelly*'
      attributes:
        ip_address: '! none'
        has_firmware_update: '! none'
      options:
        show_state: true
        toggle: true
        entities:
          - attribute: ip_address
          - attribute: has_firmware_update
I tried with no luck
          - attribute: >-
               {% if state_attr(config.entity, 'has_firmware_update') %}
                 Latest
               {% else %}
                 Upgrade
               {% endif %}
hello friend,
i have some mistake in my card.
i think it is bad argument. can someone help me to understand.
(sorry i’m french)
card is very good and work perfectly .
i want understand why i have mistake (orange text)
cards: null
type: entities
entities:
  - entity: input_boolean.thermostats_horaire
  - type: section
  - entity: sensor.tranche_1
    state: true
    show_state: false
    entities:
      - entity: input_datetime.sejour_start_1
      - entity: input_datetime.sejour_stop_1
  - type: section
  - entity: sensor.tranche_2
    state: true
    show_state: false
    entities:
      - entity: input_datetime.sejour_start_2
      - entity: input_datetime.sejour_stop_2
  - type: section
  - entity: sensor.tranche_3
    state: true
    show_state: false
    entities:
      - entity: input_datetime.sejour_start_3
      - entity: input_datetime.sejour_stop_3
  - type: section
state_color: true
sensor.tranche_1
  sensors:
    tranche_1:
      friendly_name: tranche 1
      value_template: >-
        {{ (states.sensor.time.state >= states.input_datetime.sejour_start_1.state) and  (states.sensor.time.state <= states.input_datetime.sejour_stop_1.state)}}
      icon_template: >-
        {% if is_state('sensor.tranche_1', 'True') %}
           mdi:lightning-bolt: mdi:radiator
        {% else %}
            mdi:sleep
          {% endif %}
input_datetime.sejour_start_1 and input_datetime.sejour_stop_1 are time custom to heater
Hi All,
I think last-changed shows ‘Never’ in the Multiple-entity-row secondary-info since update 2020-12 of HA, but I am not sure. When I remove the type: 'custom:multiple-entity-row', the last-changed shows just fine as you can see in the image below.
I updated from 3.3.0 to 4.1.1, hoping to solve the issue, but that wasn’t the case.
It’s probably something minor/simple that I am missing, but I guess it’s in my blind-spot somewhere. So ehhh Help :blush:?
EDIT
After days of looking at the ‘Never’ shown above, today there all of a sudden was a last changed value. So… Things mysteriously started working as designed again… Beats me, but happy that it works.
Is there a way to use this with another custom entity row?
I have some custom button entity row plugins and I would like to use those plugins and also add some other custom attributes to the same row.
here is a typical config for my plugin:
- type: custom:binary-control-button-row
  entity: light.computer_room_ceiling_light
  customTheme: true
  reverseButtons: true
I tried wrapping it in your custom plugin but it doesn’t end up as I’d like:
- type: custom:multiple-entity-row
  toggle: true
  state_color: true
  entities:
      customTheme: true
    - attribute: off_brightness
      name: Off Brightness
Here is how it looks with both of those:
ex
I’d like to keep the custom buttons from the second row and just add the secondary entity attribute to the same line as in the first row.
Is there anyway to correctly nest these two entity rows together to get the end result I want?
Have I done something wrong here as each line is slightly off centre
Capture
type: entities
entities:
  - entity: sensor.ivy_s_room
    icon: 'mdi:thermometer'
    secondary_info: last-changed
    entities:
      - attribute: min_value
      - attribute: max_value
  - entity: sensor.our_room
    entities:
      - entity: sensor.oregontemphygro_2dde_hum
  - entity: sensor.kitchen
    entities:
      - entity: sensor.oregontemphygro_2dd4_hum
  - entity: sensor.hallway
    entities:
      - entity: sensor.oregontemphygro_2d60_hum
  - entity: sensor.garden
    entities:
      - entity: sensor.oregontemphygro_2dcf_hum
I want to hide “Power” entity when “light.cabinet” is off.
How can I do it in my simple Entities card:
Screenshot
  - entity: light.cabinet
    toggle: true
    state_color: true
    entities:
        attribute: current_power_w
        unit: W
Hi All,
Can someone help me with follow:
entity: sensor.meek_hallway_wifi_info
show_state: false
entities:
  - attribute: RSSI
  - attribute: IP Address
  - attribute: Number Reconnects
  - attribute: Connected msec
Connected msec value is 205665000 (msec)
How can I convert this back to hours in the card?
I don’t know what I am doing wrong, but the more-info/toggle/etc. action into double_tap_action/hold_action isn’t working for me. For example, when I hold the icon, it happens nothing. Neither on browser (firefox) or Androidphone (HA App).
In normal glance, the hold_action ist working with more-info.
        entities:
          - entity: light.kleiderschrank
            icon: 'mdi:wardrobe'
            state_color: true
            tap_action:
              action: toggle
            hold_action:
              action: more-info
        entity: light.zimmer_licht
        toggle: true
        state_color: true
And 2nd on my phone is something wrong with the layout, I think :sweat_smile:
grafik
Edit: Ok there is a Github Issue.
I don’t if that is working but try the format: option:
show_state: false
entities:
    format: time
How can I rotate a single icon on a multiple entity row?
  - type: 'custom:multiple-entity-row'
    entities:
      - entity: switch.sonoff_zzzzzz
        toggle: true
        icon: 'mdi:coach-lamp'
        state_color: true
        tap_action:
          action: toggle
        styles:
          width: 40px
          text-align: center
      - entity: switch.sonoff_yyyyyyyyy
        toggle: true
        icon: 'mdi:globe-light'
        state_color: true
        tap_action:
          action: toggle
        styles:
          rotate: 180
          width: 40px
          text-align: center
    entity: switch.sonoff_xxxxxxxx
    toggle: true
    icon: 'mdi:grass'
    show_state: false
I think the feature is coming in a new version in Home Assistant: https://github.com/home-assistant/frontend/pull/4855
not really, Issue is closed.
check 🔹 Card-mod - Add css styles to any lovelace card
This is great,
I wanted to add a power indicator under my light switch, and this is what I used.
Is there any way to bring a brightness slider into the mix?
notice I have two Entry lights I want to put the slider up to the first one. this possible?
  - entity: light.entry_87
    secondary_info:
       attribute: "current_power_w"
       unit: W
    styles:
    toggle: true
    toggle: true
    type: 'custom:slider-entity-row'
Or somehow add a fold entity to drop down a slider.
