pedolsky
(Pedolsky)
May 21, 2021, 12:22pm
42
Wonderful idea!
But: Did I dismiss something? Everytime I am trying to add a custom:button-card the radial menu implodes and gives me a blank card. Here‘s my code:
type: 'custom:radial-menu'
icon: 'mdi:castle'
default_dismiss: false
items:
- entity: alarm_control_panel.ha_alarm
icon: 'mdi:alarm-light'
tap_action:
action: more-info
- entity: group.wohnzimmer
icon: 'mdi:sofa'
tap_action:
action: more-info
- entity: group.lounge
icon: 'mdi:beach'
tap_action:
action: more-info
- card:
type: 'custom:button-card'
entity: light.garderobe
icon: 'mdi:hanger'
show_name: true
styles:
card:
- background-color: black
- color: white
Raiders
(Raiders)
February 22, 2022, 12:43pm
43
I’ve been trying to find a way to reduce the circle the of icons. The circle appears too large around the fan icon.
- type: custom:radial-menu
icon: null
default_open: false
default_dismiss: true
hold_action:
action: url
url: https://www.home-assistant.io
style:
left: 77%
top: 58%
'--radial-menu-button-color': blue
'--radial-menu-item-color': red
items:
- icon: mdi:numeric-0-circle-outline
tap_action:
action: call-service
service: fan.set_speed
service_data:
speed: 'off'
entity_id: fan.sonoff_10009951b8
radial-menu-item-color: black
haptic: true
- icon: mdi:numeric-1-circle-outline
tap_action:
service_data:
speed: low
haptic: true
- icon: mdi:numeric-2-circle-outline
tap_action:
service_data:
speed: medium
haptic: true
- icon: mdi:numeric-3-circle-outline
tap_action:
service_data:
speed: high
haptic: true
Same problem here. Is it deprecated? .
pedolsky
(Pedolsky)
March 11, 2022, 6:38am
45
gabrielmiranda:
Is it deprecated?
I don’t know because I don’t use radial-menu anymore. Feel free to raise an issue against.
arcsi42
(arcsi42)
March 13, 2022, 9:08pm
46
I think I wanted to change the same thing, the pop-up icons appeared too far from the menu center on a phone screen, so I made a small change to the code and is working for me so far. I opened a PR to the main repo, but in the meantime you could download the updated javascript from my fork at: https://github.com/arcsi42/radial-menu/releases/tag/1.6.1-dev and then add a new items_offset
to your config.
I can’t seem to get the items_offset to work and I’ve tried it in a bunch of different places. Am I doing this right? From the readme, 35 is default and this shouldn’t be a hard change. I am on 1.60
icon: mdi:table-chair
default_open: true
items_offset: 5
hold_action:
service: light.turn_on
service_data:
entity_id: light.dining_room_lights
haptic: true
style:
radial-menu-button-color: blue
radial-menu-item-color: red
items:
- entity: light.dining_room_lights
icon: phu:bulb-group-sultan-lightstrip
tap_action:
action: toggle
haptic: true
hold_action:
action: more-info
- entity: light.dining_room_lamps
icon: mdi:lamp
tap_action:
action: toggle
haptic: true
hold_action:
action: more-info
- entity: light.dining_room_accent_lights
icon: phu:bulb-group-lightstrip
tap_action:
action: toggle
haptic: true
hold_action:
action: more-info
styles: null
- entity: light.dining_room_recessed_lights
icon: mdi:light-recessed
tap_action:
action: toggle
haptic: true
hold_action:
action: more-info
Kelvin
(kelv)
October 31, 2022, 6:41pm
48
How do you update this with your javascript?
Is there a way to make the entity picture larger like you can with the icons?
Say the menu had 5 entity pictures in it. How do I make those bigger? I’ve already made this a panel card.
8 line from bottom
remove - card: and down
then it will work
icon: 'mdi:castle'
items:
tap_action:
action: more-info
icon: 'mdi:sofa'
tap_action:
action: more-info
icon: 'mdi:beach'
tap_action:
action: more-info
icon: 'mdi:hanger'
show_name: true
styles:
card:
- color: white
