Can you log an issue against the repo and include your theme? Thanks
Big shout out to @RomRider for his work on long-press and haptic on button-card. Made it really easy to add here.
- Menu now supports tap_action and hold_action
- Items now support hold_action
- New
action
typeurl
which allows you to open a new tab with the specified url - New haptic feedback support. Currently only available in the iOS beta app
This is brilliant. Is there a way of adjusting the size of the card. I want to make it bigger. That would be great, then we could use it as a launching any tab view/pop-ups
Also not sure if if possible, but any chance we can hide the views/menu in the browser?
New Features:
- New
double_tap_action
option - New
card
option foritems
. You can specify a custom card to use as an item now
Breaking Change:
url
action option renamed tourl_path
is it me or does this plugin not work using the mobile app?
taping the icon doesn´t do anything for me, works on PC tho.
type: 'custom:radial-menu'
icon: 'mdi:lightbulb'
default_open: false
default_dismiss: false
items:
- entity: light.all
tap_action:
action: toggle
haptic: true
Which mobile app?
the official companion app. figured that it also doesn´t work usinmg safari.
iOS 13 changed how taps are being sent. Working on a fix. Is affecting most of my cards
Here’s a cool variation:
Hi there! Amazing feature but is there a way how to change color and size of icons without changing theme ? Would be great.
I am struggling with getting this to work, I installed via HACS, and tried this super-basic config to test;
- cards:
- type: history-graph
entities:
- sensor.kontor_ovn_timer
hours_to_show: 24
refresh_interval: 0
- type: "custom:radial-menu"
items:
- entity: light.do_ltak
But i get the error message: “Custom element doesn’t exist: radial-menu.”
Any tips on how to troubleshoot?
it’s not enough to just install via HACS, you have to add to your Lovelace resources as well.
I am pretty sure i have done this, I usually do, and all the other custom cards i have installed work, but is there a way to double check if it has been done? (there is no “add to lovelace”-option if i go into the plugin in HACS)
I tried turning of YAML-mode. Added the card there, and it worked, then i copied the code verbatim from the raw config-editor. And turned on ymal-mode again, now it doesn’t work again. Any tips? This confuses me.
- type: 'custom:radial-menu'
items:
- entity: light.kjellerstue_dlbord
icon: 'mdi:flash'
- entity: light.kjellerstue_dlbakvegg
icon: 'mdi:flash'
EDIT:
Turns out you have to add resources manually when using yaml-mode, but not when not using yaml-mode, so that solved it. (So iantrich was right, I just though you added it by choosing “add to lovelace” when installing via HACS), I haven’t done this with the other custom cards though, so who know why they work in yaml-mode.
If I have an existing button card can I wire up the tap action on that to popup this radial menu element?
My ui looks like this
and I would like to be able to tap one of the square button cards that is wired up to an input_select. I would like to be able to change the selection using this radial menu.
thanks!
Version 1.6.0 Released with Theme variables:
name | Default | Description |
radial-icon-size |
24px |
icon size |
radial-menu-button-color |
primary-color |
Menu color |
radial-menu-item-color |
primary-color |
Item color |
How do you add the theme variables to the radial menu config? (sorry if stupid question)
Could someone please explain how do I increase the size of the icons? I asked the developer and he just answered me with this link “https://www.home-assistant.io/integrations/frontend/” but I really couldn’t figure out how to do that …
Thanks in advance!
That link describes how to use themes. You use the theme variable for the icon size in your theme to adjust the size --radial-icon-size: 16px
Thank you very much, now it’s clearer and I’ve already put it into practice !!
