Lovelace - refreshes/refocusses page frequently?
I had the same problem.
Just uninstall Chrome Beta and use the normal release version.
Same issue here on 2022.10.4. UI Randomnly flashes and reloads. Also, history graphs on pupups seem buggy (don’t load properly sometimes) and seem to force the refresh.
Happening on Edge. The android app works fine.
Tried undoing the changes I’ve made to my setup but can’t get to the bottom of this.
Edit: Apparently, an update to edge must have been responsible in my case. In dev builds (which I use as daily driver), the problem occurs, at least since version 107.0.1418.8. Version 107.0.1402.2 worked fine. As do the stable 106 versions.
still an issue… is there any fix?
if you want to reproduce it happens 100% of the time if there is a 1 milosecond connection disconnect…
Same issue here. Super annoying…
Home Assistant 2023.2.5
Supervisor 2023.01.1
Operating System 9.5
Frontend 20230202.0 - latest
