šŸ’” Lovelace: RGB light card
Hey!
Is there any way to hide the switch from the light card?
I setup to turn on/off with a tap on the card, so the switch is not needed.
Thanks! :slight_smile:
The light card doesn’t have a switch :man_shrugging:
However, if you see a switch on your entities card, adding the following may help:
type: entities
show_header_toggle: false # <= Add this line
If it doesn’t solve your problem, please post a screenshot so we can understand instead of guessing.
Hey! :slight_smile:
Thanks, but I want to hide this:
Thanks!
Strungling to re-enable what I have in shelly4hass integration until white channel was working…
After white channel was not supported under shelly4hass I migrated all shelly devices to native shelly integration.
So now I need some help.
Can somebody tell me how to re-enable some functions which are not working for me anymore…
So look in lovelace is like that:
The problem is that when I try to edit white channel I actually edit
So how to edit white channel under lovelace… also editing color brigtness under lovelace would be very good…
Current lovelace code:
entities:
  - entity: light.shelly_rgbw2_dnevna
  - entity: sensor.shelly_rgbw2_dnevna_current_consumption
  - entity: sensor.shelly_rgbw2_dnevna_total_consumption
  - entity: sensor.variable_obvestilo_rgbw2_moc_svetlobe
    full_row: true
    step: 1
    type: custom:slider-entity-row
  - entity: sensor.variable_obvestilo_rgbw2_white
    full_row: true
    step: 1
      transition: 5
      white: 255
      device_id: 58c1420262940b82068d14666947731d
  - colors:
      - brightness: 1
        effect: 0
        icon_color: '#c0c0c0'
        rgb_color:
          - 255
          - 255
          - 255
        transition: 1
      - brightness: 220
        effect: 0
        icon_color: '#990000'
        rgb_color:
          - 255
          - 0
          - 0
        transition: 1
      - brightness: 220
        effect: 0
        icon_color: '#009900'
        rgb_color:
          - 0
          - 255
          - 0
        transition: 1
      - brightness: 220
        effect: 0
        icon_color: '#999900'
        rgb_color:
          - 255
          - 255
          - 0
        transition: 1
      - brightness: 220
        effect: 0
        icon_color: '#009999'
        rgb_color:
          - 0
          - 255
          - 255
        transition: 1
      - brightness: 220
        effect: 2
        icon_color: center/120% url('/local/images/rainbow.png')
        transition: 1
      - brightness: 1
        effect: 0
        icon_color: center/95% url('/local/images/night_mode.png')
        transition: 1
    justify: between
    type: custom:rgb-light-card
title: LED trak
type: entities
Options for controller:
Did you ever figure out how to do this?
This card is awesome, but it would be even cooler if I could call the color picker wheel/color temp slider from one of the ā€œcolorā€ buttons.
I’ve seen a few people ask about this but no actual answers.
For anyone want combine call service and static colors,
ā€œNote that you can mix lights and service calls in the same cardā€ here
type: entities
entities:
  - type: custom:rgb-light-card
    entity: light.id
    colors:
      - rgb_color:
          - 234
          - 136
          - 140
        brightness: 255
        transition: 1
        icon_color: '#10b2ec'
      - type: call-service
        service: script.turn_on
        service_data:
          entity_id: script.abc
        icon_color: '#90b2ec'
I was trying to use this light card but it seems like my
hide_when_off: true
is not working:
    entities:
      - entity: light.e27_living_room
        hide_when_off: true
        justify: center
        colors:
          - rgb_color:
              - 234
              - 136
              - 140
            brightness: 255
            transition: 1
          - rgb_color:
              - 251
              - 180
              - 139
            brightness: 200
            transition: 1
          - rgb_color:
              - 136
              - 198
              - 237
            brightness: 150
            transition: 1
gives
grafik
while
hide_when_off: false
seems to work
grafik
@kingisch Can you please go to the templates section of the developer tools, and tell me what is the result of this template while your light is turned off ?
{{ states['light.e27_living_room'].state }}
sure, it is ā€œoffā€
Thank you!
Edit: I found the mistake. I accidentally added two different entities in the entity section :man_facepalming:
Sorry for that!
I’m very much enjoying your card. Thanks again for making it.
Any possibility of a future version supporting templates?
Hey!
Did you manage to find a way to do this? I’m trying to call 2 services - Stop_dynamic_scenes and Light.Turn_on.
However, i can’t seem to find a way to do that. I have gotten this far, but every combination i try to do to call different services with the same click, it just calls one of them and not the other one
Ideally, it would call the ā€œStop_dynamic_scenesā€ for all the buttons that i have in that row
entity: light.office_floor
label_size: 11
justify: center
colors:
    service: scene_presets.stop_dynamic_scenes_for_targets
    service_data:
      targets:
        entity_id: light.office_floor
    color_temp_kelvin: 6410
    brightness: 255
    icon_color: 'linear-gradient(15deg, #fffcf7, #cae9f3)'
    label: Energise
Can you put the two service calls in a script and then call that?
Hey!
I could, however, i have multiple colours set up in the UI. Having a script for each of them would clug up the system. Is there maybe a way to pass the service call data to the script, run the ā€œStop_dynamic_scenesā€, and then apply the service call for light_turn.on?
You don’t have to create a new script for each color, just create one script that accepts variables instead
Hello everyone !
I’m glad to announce that I just released the version 1.13.0 of this card, making it possible to integrate natively inside a Tile card :tada:
Also, clicking on colors on a mobile app will now trigger haptic feedback :vibration_mode:
2024-09-19_11-452024-09-19_11-44
Have a great day!
Hello. Thanks for the card, it’s awesome. I am facing a an issue, might be stupid but can’t figure it out. Everything works fine EXCEPT the color changing part. I can turn the lamp by clicking on each of my colors below but I can’t change color while the lamp is on. For example if lamp is on White and i click on red, nothing happens. However if I toggle it off and click on red, lamp turns on red color. Any chance to fix this? Here is my code:
type: entities
entities:
  - entity: light.bedside_lamp
    toggle: true
    hide_when_off: true
    hide_state: false
    show_icon: false
    colorize: false
    hide_when_off: true
    colors:
      - rgb_color:
          - 255
          - 255
          - 255
        brightness: 255
        transition: 1
      - rgb_color:
          - 234
          - 136
          - 140
        brightness: 255
        transition: 1
      - rgb_color:
          - 251
          - 180
          - 139
        brightness: 255
        transition: 1
      - rgb_color:
          - 136
          - 198
          - 237
        brightness: 255
        transition: 1
      - rgb_color:
          - 140
          - 231
          - 185
        brightness: 255
        transition: 1
state_color: false
@Sporbillis does it work properly when you use the ā€œlight.turn_onā€ action from the developer tools?
@bokub thanks for replying!
I get this error when trying from developer tools. Please note that this is a Xiaomi Mi bedside lamp 2 (in case it helps). On my meross smart bulbs the above yaml works fine. Please help!
@Sporbillis This means it’s a Home Assistant error, that has nothing to do with my card.
Once you solve this problem, the card will work properly. Maybe create a dedicated topic to ask for help?
@bokub
Ok so after a restart the action works fine in developer tools. However my issue with the color changing in the card is not fixed. Anything else I can do?
