I thought your comments regarding
Known issue since 0.97.
and
Release 0.1.0 Check for source_list to avoid crash
were directed at me, and if they were I dont know what to do with the link.
and
It is a known issue but the new release does not address it
Echoing what lawsuitup said. Love the remote! It’s very responsive and easy to use. But the resending of the input made me remove it until the bug is fixed
My fix would be to remove inputs for now while I do the rewrite, I guess
Also the link is to the new release so that you can upgrade your installed version if you are manually tracking updates. If using HACS, it will eventually show upgrade automatically
Hi Ian,
Thank you for the work it looks awesome! I just started to install HA and I’m trying to add my first cards. The default media control card being limited I found your card but I have a hard time installing it.
I cannot find the ui-lovelace.yaml file to add this.
I did copy roku-card.js in config/www.
Ahh, I did not find it in there though, do I have to add a repository to see it?
Once installed I can just add a custom card in the raw config editor?
No, it should be there by default as it is part of the custom-cards organization. You use the raw config editor to place it in your resources, yes
Oh my, thank you so much. I apologize for the confusion, I was looking in the add-on store and not HACS! I had no idea this needed to be installed
Edit: Awesome I got it to work but I have two questions:
www
folderThanks for following up Ian!
id
under apps
for ex. Youtube
. Netflix does work properly. Is it limited to what is physically present on the actual remote?Failed to call service media_player/select_source. 'NoneType' object has no attribute 'launch'
Share you configuration
Here is what I have in the raw config editor:
resources:
- type: module
url: /local/roku-card.js?v=0
title: Home
- badges:
- person.yohan
- person.emma
cards:
- entity: weather.home
type: weather-forecast
icon: 'mdi:home-outline'
path: default_view
title: Home
- badges: []
cards:
- entity: switch.aeon_labs_zw096_smart_switch_6_switch
hold_action:
action: more-info
icon: 'mdi:power-socket-us'
show_icon: true
show_name: true
tap_action:
action: toggle
theme: default
type: entity-button
icon: 'mdi:lightbulb-outline'
path: lights
title: Lights
- badges: []
cards:
- apps:
- icon: /local/netflix.png
- icon: /local/youtube.png
entity: media_player.55_tcl_roku_tv
tv: true
type: 'custom:roku-card'
volume_down:
dbltap_action:
action: call-service
service: remote.send_command
service_data:
command: play
entity_id: remote.55_tcl_roku_tv
volume_up:
tap_action:
service_data:
command: play
- entity: media_player.55_tcl_roku_tv
type: media-control
icon: 'mdi:youtube-tv'
Check the spelling, such is in the Developer Tools -> States
My guess is that it should be “YouTube”
That was it!
Still getting the error on the mobile device though thank you for your help! I bought you a beer
Hey! Thanks!
I still think that has to be a caching issue
Hi Ian,
I wanted to test it on more devices and browsers to see if the issue is coming from there and it is really doubtful.
I tested it on an iPhone, iPad, Android tablet and Android smartphone. On Safari, Firefox, Firefox Focus and Brave.
All cache and cookies have been erased beforehand and the browser has been freshly installed in some cases. Most of the devices connected to HA for the first time as well.
