Thatâs so strange. Do you have other custom cards that are working fine on mobile?
No that is the only one. I also tried to request the desktop site on the mobile device, thinking it could be linked to the way the mobile version of the website. But I get the same result.
If you ended up using HACS doesnât the resource need to be:
resources:
- type: module
url: /community_plugin/roku-card/roku-card.js
Indeed it does, but they said it was working on desktop so I didnât look at that. So is likely a caching issue on their desktop, not mobile. @altf4 try @jalsing suggestion
It does not have to be, but if you use that HACS will bust the cache for you, and serve a gz version of the card
That was it!
Thank you so much all for your help! Since I really just started I really appreciate the step by step help you provided @iantrich @jalsing @ludeeus
Breaking Changes:
dbltap_action
has been renamed todouble_tap_action
icon
option inside theapp
object has been renamed toimage
id
object has been renamed toapp
url
option inside theaction
object has been renamed tourl_path
New Features:
app
object now support tap/hold/double_tap actions
How do I get the Input Source wording and drop-down box like it shows in an image in a post on Jan 25, '19 2:38 PM? I am also having trouble getting the volume buttons to continue to send commands when I hold them down. Are there examples of each of these? The tap option for volume buttons work fine. Itâs just when I hold the volume buttons down they donât continually raise or lower the volume.
@iantrich or anyone I donât get what I am doing wrong.
Here is where the roku-card is located according to the configurator:
/config/www/community/roku-card/roku-card.js
Here is what i have in my lovelace config:
resource:
url: /local/community/roku-card/roku-card.js
Here is what I get:
Custom element doesnât exist: roku-card.
Iâm assuming you installed it via HACS? If so, just revisit the page in HACS and it tells you what you need to enter and if using storage mode will even add it for you.
Thank you so much for the quick response! So it has 2 different paths and I tried both.
Near the top is has this
resources:
url: /local/roku-card.js
type: module
And at the bottom, it mentions the file path that the card is located, which the same I said in my previous post.
Then it says, when you add this to your lovelace config, add this:
url: /hacsfiles/roku-card/roku-card.js
type-module
But either way, I continue to get the red card.
At the bottom it says this
- url: /community_plugin/roku-card/roku-card.js
type: module
Weird, I donât see that URL at all. But that didnât work for me either. Same red card
I had this issue too and it was due to the syntax of the conditional card the remote was under. I guess it used to tolerate a dash before âtypeâ ( - type: custom:roku-card
) but doesnât any more. I took the dash out and it works now. My yaml looks like this now and is working:
- type: conditional
conditions:
- entity: sensor.harmony_activity
state: "Watch Roku"
card:
entity: media_player.roku
title: Roku
theme: darkpurple
power:
service: remote.turn_on
service_data:
entity_id: remote.harmony_hub
activity: 888888888
I love this card. It is definitely my most used one. An idea for an added feature. Not sure if it is possible as I am not a developer, but a button that you hit to pop up a keyboard would be amazing. It would make searching you tube and such so much easier. Also one that would pop up a 10 key pad for entering pin codes on Roku.
Thanks so much!
How do use the themes? Setting theme: darkpurple does nothing for me.
provide your configuration and verify that it is a valid theme that works for your outside this card.
As far as I know, the integration does not support search
Any errors in your browserâs console?
Hi, below is my configuration. Are you saying I need to install a theme first and then select that theme inside my configuration? Sorry for noob questions. This is still relatively new to me.
popup_cards:
remote.roku_express:
card:
apps:
- app: Netflix
image: /local/images/netflix.png
tap_action:
action: call-service
service: media_player.select_source
service_data:
entity_id: media_player.roku_express
source: Netflix
- app: Sling TV
image: /local/images/sling.png
tap_action:
service_data:
source: Sling TV
- app: YouTube
image: /local/images/youtube.png
tap_action:
service_data:
source: YouTube
- app: PBS KIDS
image: /local/images/pbskids.png
tap_action:
service_data:
source: PBS KIDS
entity: remote.roku_express
theme: darkpurple
tv: true
type: 'custom:roku-card'
title: Roku Express
