Lovelace: Simple thermostat card
Is there a way to hide the preset mode but keep the operation mode?
Remove preset section from your config.
Thanks but I do not have a preset section in my config. Code:
  - type: 'custom:simple-thermostat'
    entity: climate.boiler
    layout:
      mode:
        headings: false
      step: row
Add this on the same ‘level’ as layout
control:
  hvac:
Mine looks likr this:
entity: climate.trv_salon
sensors:
  - entity: sensor.trv_salon_valve
step_layout: row
control:
  hvac:
    'off':
    heat:
    auto:
  preset:
    none: false
    away: false
    schedule:
    manual:
    complex: false
layout:
  mode:
    headings: false
  step: row
Correction, to this:
control:
  hvac: true
This worked. That’s great, thanks!
No problem :slight_smile:
Getting this error after adding the component and adding to resources/lovelace:
TypeError: can't define property "entity": Object is not extensible
Anyone seen this error before?
style not working with HA 2021.4.6
I want to hide the control buttons when my thermostat is turned off, but I cannot get the _hide_when_off feature to work.
My original config:
anchors:
  simple_thermostat: &simple_thermostat
    layout:
      step: row #row (-/+)|column (pfeile)
      mode:  # no text for control buttons
        names: false
        icons: true
    hide:
      state: true
    label:
      temperature: Temperat.
    control:
      - hvac
cards:
  - type: custom:vertical-stack-in-card
    # living room - Wohnzimmer
    cards:
      # thermostat living room
      - type: custom:simple-thermostat
        entity: climate.000c9a499b5808
        name: Wohnzimmer Thermostat
        <<: *simple_thermostat
        sensors:
          - entity: sensor.hm_thermo_wz_actor_state
          - entity: sensor.hm_thermo_wz_window_state
          - entity: sensor.hm_thermo_wz_active_profile
      - type: divider
will show the control buttons permanently. If I change the format to
    layout:
        names: false
        icons: true
    hide:
      state: true
    label:
    control:
      - hvac:
        _hide_when_off: true
the control buttons disappear permanently even if the thermostat is in ‘heat’ or ‘auto’ mode.
Am I doing something wrong?
Thanks for your input.
@nervetattoo: Very, very cool card. Thanks a LOT for your work.
Yeah, it needs to be an object when you pass additional config to control, so:
    control:
      hvac:
The list format you have used only supports (string) name of the mode type
oh, you are right, I missed that.
Thanks, works like a charm.
I’m attempting to hide the “Operation” and “Preset” labels and failing. I see that it’s referenced in this thread, and I’ve read the documentation but either I’m not understanding it or it’s not working for me:
Thermostat
entity: climate.pool_thermostat
decimals: 0
step_size: 1
fallback: 'Off'
label:
  temperature: Pool temperature
hide:
  state: true
header:
  icon: false
setpoints:
  temperature: null
control:
  hvac:
    _name: null
    'off':
      icon: 'mdi:power-off'
    cool: false
    heat_cool: false
  preset:
    _name: null
    none:
    Auxiliary:
sensors:
  - entity: climate.pool_thermostat
    attribute: hvac_action
  - entity: sensor.openweathermap_temperature
    name: Air Temperature
    decimals: 0
  - entity: sensor.openweathermap_humidity
If I add _name: false, the labels don’t change. If I add _name: something else, the label changes to “something else”. If I add _name: or _name: null, the label remains defaulted to either “Operation” or “Preset”.
What am I doing wrong?
You need to focus on different section. The _name is intended to really modify name.
You want to remove the label. So in layout:
      layout:
        mode:
          headings: false
Thank you! That did the trick.
Is it possible to configure the component tu use temperature sensor from other entity than climate we set in config? I’m thinking if I can tell my AC unit to use room temperature sensor instead of the built in one :thinking:
Yes it possible, I suggest you read the documentation.
Well…I did look at GitHub documentation and I wouldn’t ask if I would find something relevant. But I might be tired and well…blind?
Did you search this topic? Your question was asked before: Lovelace: Simple thermostat card - #104 by tyrsen
