Hi, I want to use this card, if possible to swipe between rooms, so I want to create a swipe card with horizontal, vertical stacks, is this possible?
I can get it to work with one card without any issue, but more then one card, like this for instance does not work, or I’m stupid someone an idea if this is possible and so how to do this?
You can yeah. I even managed to get five ENTIRE pages (paths) in there with all the cards included. I wanted to emulate actual swiping from page to page like a native app. It worked, but it was very heavy since it loaded like 50 cards at the same time lol.
But it is possible, just wrap everything in the swiper card and you’re set.
Thanks for your quick reply, can you help me a little with the above card, because I tried everything but cant get it to work, yaml is very hard to understand for a non dev I’m afraid
I want to create a horizontal stack and under there an entity card that’s it, to be honest, but tried everything always get errors like duplicate field or indentation problem, pff yaml so fun
So the code contains two cards, one horizontal stack (with horseshoe inside) and one entity. Do you want to swipe between the horizontal stack and the entity below it? Did I understand correctly?
No I want to create more then one view like this (rooms) and then swipe between the rooms, so every room will have a horizontal stack and an entity card, so both cards need to be in one view, room, swipe
@dmertens How do you expect me to help you with a piece of code for swipe card if you only post one card lol.
Anyway this is what you need to do: wrap the entire view in a vertical-stack card. So each view needs to be wrapped inside it’s separate vertical-stack. So:
- cards:
- INSERT EVERYTHING FROM VIEW 1
type: vertical-stack
- cards:
- INSERT EVERYTHING FROM VIEW 2
- cards:
- INSERT EVERYTHING FROM VIEW 3
This gives you THREE separate vertical stacks wich each contains all the cards. So essentially now you have your three rooms each as a separate card. Then you just need to wrap that into a swiper card.
So you are wrapping al the cards you want for one single room inside a vertical-stack and THEN you wrap all your vertical-stacks inside a swiper card. Change the parameters as you see fit (remove or change them to your liking)
You are missing the ‘cards:’ option of the swiper card. If you look at the code carefully you will see you are missing ‘cards:’ that define the swipe cards. Basically you have used the swipe card but did not mention what the cards are, since you left that out.
So just put ‘ - cards:’ all the way at the top and fix the problem spaces of the swipe at the bottom (2 spaces to the left) and it should work. You see the difference?
Thanks for your quick reply, and yes I can see the differences but it still does not work I think?, I have now just 3 horizontal stacks in one view but no slider option?
Don’t use screenshots with code, but paste it here using the correct format like I did.
Anyway, I copy and pasted my code exactly like I wrote for you (and used my own sensors for testing). Works exactly as intended.
This is what I get:
Adding extra cards within each vertical-stack gives this.
Make sure you reload the page / reset cache just in case. But other than that, I can’t explain it any clearer than this since the code I wrote works exactly like it should.
OK got your example working, but now I want to add an entity card below the stack, I think I did everything as in your example, but now I got an error that I have a duplicate mapping error, pff I think I will never understand yaml, pfff
I advise you to practice with YAML more with basic stuff first, since I can tell you are all over the place with your code. You aren’t following my example if you look closely. Each card needs it’s separate indentation. Yet, above the line ‘start card 1’ that is tied to swipe card, you now suddenly write ‘type: vertical-stack’. So basically your swipe card is broken because you now literally have written that it’s a type: vertical stack AND a type: custom:swipe-card.
Play close attention to indentations and practice your code piece by piece first. Expand the swipe card by adding cards piece by piece. When that works, you have yourself a template you can copy, paste and edit the contents for different swipe cards.
We all have to start somewehere. I had 0 experience with this and am no developer by any means. I started with HA little over 4 months ago and have learned a lot of things. So just keep working with small steps and then YAML will click suddenly
Is it possible to swipe a horizontal stack containing within a vertical stack?
I have 4 cards but i only want to show 2 at a time, then allow a swipe to the 3rd/4th card however this horiztontal stack is currently inside a vertical stack.
Just create two vertical-stack cards that each contain two horizontal-stack cards. Then wrap the two vertical-stack cards inside swiper card. You can follow my example code above basically to achieve that.
I have only copied the base config so far with 4 sensors showing in coverflow. Aiming to change these to buttons, but when using on the app, if you swipe to move through the sensors when you let go it loads the page of data about the sensor, is there a way to need another press or something to activate a page within the swipe?
Had a look through the posts and realise no one has a final solution to accidental clicking, I have added secondary “blank” buttons in a vertical stack to help space the top buttons away from the scroll area.
Only other thing I would say is after saving my lovelace file and refreshing my UI all my other cards refresh instantly and the swiper takes probably 10+ seconds to appear on screen. Its installed using HACS?
I just installed the new update. Unforttunately this plugin is now broken on Safari browsers. I get the following error: Can’t find variable: ResizeObserver. This occurs on all Safari (based) browsers I tested (macOS, iOS, iPadOS). Works fine on Chrome and other browsers (including on macOS Chrome).
