Using my first swiper setup, I can’t find the answer to a few questions, so turn to you:
I have a set of custom button cards with aspect ratio 1/1 and Id like the swiper to have a width of 1 button in a row of 4 buttons. However, Ive tried both 25% or eg 50px in the card-width field, but it still shows me a full width swiper.
Have now added it to a horizontal stack like this:
which works fine, but was wondering if this is the way to go.
Secondly, I’d like the swipe to simple continue to the first when it reaches the last button, while it now seems to quickly scroll back to the first button. Do I need a dedicated setting for that?
O, and lastly: is this card now deprecated? Seems the repo is locked, and no more development taking place? If so, is there a new alternative we should use?
thanks for having a look!
I have a slider-entity-row inside swipe-card and when I changes lights parameters via slider-entity-row tab of swipe-card moving too.
How can I fix it?
i have the same issue like @Syrius in v3.0.0 ,after reload page several timres it load correctly,if i update to v3.1.0 ,all cards inside swipe-card are black,only can see the scrollbard.
someone else with this problem?
That looks great! Do you have to update the card every time you download a new game though, or will the card be updated automatically based on the source select of PS4 integration?
Thanks for answer, I installed it like you said, deleted cache but same issue yet
in my case the problem is with picture-elements card, I have other views with entities that I have no problem
Thanks again bro
Anyone using this with button card? I have tried it in the past but I have issues with touch being to sensitive. The cards work fine (have them setup in a horiontal-stack), but when swiping I have to start the swipe motion by dragging a button card. It then either registers it as a tap_action or hold_action (depends on how slow I drag). Is there a way I can fix this by using some parameters so it ignores the button card actions?
I have keyboard navigation turned on for now, but that isn’s as intuitive for tablet usage.
to the card, and rely on the navigation buttons. This has cut down on accidental button presses for me, and allowed me to add sliding elements to the card.
I think this card is great except for one thing. It is SO slow to load. Like 20 seconds at least. Which is annoying for me, and terrible for my SO. Does anyone know of any ways to speed up the cards load time?
20 seconds??? It is nowhere near that slow to me. It does take a few seconds (2-4 seconds usually, sometimes instant) on page reload when having multiple (conditional) cards.
Regarding your navigate solution: that doesn’t really work for me with my UI with button cards. I do use that for other cards though.
