Lovelace: Swiper card
did you manage to get this working @Myztillx?
I tried this, but I don’t get it working adding cards in a conditional card and then into a swiper card. Do you have any config/code example?
edit: got it working
I was just about to post an example. Glad you got is working though!
Maybe for the others when searching for a swiper conditional combination:
quick note: please be aware that cardoptions is a homekit-hacs plugin function so you should revert it back to normal card configuration
                      - card: custom:swipe-card
                        wider: true
                        higher: true
                        widerSize: 3
                        higherSize: 3
                        noPadding: true
                        cardOptions:
                          cards:
                            - type: conditional
                              conditions:
                                - entity: media_player.spotify_mart
                                  state: "playing"
                              card:
                                  type: "custom:mini-media-player"
                                  artwork: full-cover
                                  style: |
                                      :host {
                                      ha-card {
                                        height: 100%;
                                        background: none  !important;
                                        box-shadow: none !important;
                                        position: relative;
                                        font-size: 0.5vw !important;
                                      .button {
                                        padding: 0px !important;
                                        margin: 3px 2px !important;
                                      ha-card{
                                      overflow: hidden !important;
                                      :host #primaryProgress{
                                      background: #474A52 !important;
                                      display: flex !important;
                                      height: 100%;
                                  hide:
                                    power: true
                                    progress: false
                                    runtime: true
                                    icon: true
                                    source: true
                                    volume: true
                                    controls: false
                            - type: conditional
                              conditions:
                                - entity: media_player.spotify_lussie33
                                  state: "playing"
                              card:
                                  artwork: full-cover
                                  style: |
                                      :host {
                                      ha-card {
                                        height: 100%;
                                        position: relative;
                                      .button {
                                      ha-card{
                                      height: 100%;
                                  hide:
                                    power: true
                                    progress: false
                                    runtime: true
                                    icon: true
                                    source: true
                                    volume: true
                                    controls: false
Has anyone managed to get loop working?
I want to have (currently 2 maps but there will probably be more) and instead of swiping the correct way I want to be able to loop around all maps.
This is what I have currently which does not work
type: 'custom:swipe-card'
parameters:
  loop: true
  loopAdditionalSlides: 2
  loopedSlides: 2
  centeredSlides: true
  slidesPerView: auto
  spaceBetween: 8
  pagination:
    type: progressbar
  navigation: null
  keyboard:
    enabled: true
    onlyInViewport: true
cards:
  - type: map
    entities:
      - person.petra
      - person.andreash
      - device_tracker.kraftan
  - type: map
    entities:
      - person.petra
When you read the documentation about loops https://swiperjs.com/api/ (CTRL + F “Loop” match 9/38 ) it’s not clear to me at least what I have done wrong.
I get two cards and I can swipe between them but when I loop I get to a blank card and if I keep swiping I go back to the card I came from.
Did you find out @Kejszijo? I would like to know also.
From one of the versions the problem was solved by itself.
It looks to follow the color of the theme.
Hey, I’m trying to resize the bullets since i have them “clickable” and on my touchscreen (raspberry pi os) i can’t swipe (it bugs) and clicking works.
But the bullets are too small to click.
Do you have any idea how to css them and where?
This is what I have but it has no effect @Bram_Kragten
                        style: |
                            .swiper-pagination-bullet {
                              width: 20px;
                              height: 20px;
the only way I found to edit swipe card style was to use the custom:mod-card type on top of the swipe card
type: custom:mod-card
style:
  swipe-card:
      .swiper-scrollbar-drag {
        background-color: rgba(255,79,211,0.6) !important;
card:
    type: custom:swipe-card
    cards:
Hey all, I am using this with a raspberry pi and a touchscreen, chromium. And I experience that swipe just won’t work. It won’t fully swipe as it should and it’s laggy. Did others experience this issue, and found a solution for this?
added the .js file in www/custom-lovelace/swipe-card/
added resources:
  • url: /local/custom-lovelace/swipe-card/swipe-card.js?v=3.0.0
    type: module
    to the top of lovelace yaml but get this error when trying to make a custom card… ??
UI editor is not supported for this config:
  • Cannot read property ‘setConfig’ of undefined
    You can still edit your config in yaml.
This isn’t a swiper card issue, but a user error.
Follow the docs. Nowhere do they say to put them in lovelace.yaml. It goes in configuration.yaml if you use YAML mode.
https://www.home-assistant.io/lovelace/dashboards-and-views/
As explained per example on the official docs:
lovelace:
  mode: yaml
  # Include external resources only add when mode is yaml, otherwise manage in the resources in the lovelace configuration panel.
  resources:
    - url: /local/my-custom-card.js
      type: module
    - url: /local/my-webfont.css
      type: css
This is all in configuration.yaml.
Awesome card, thank you. Can we make a “Thumbs Gallery” with it ?
the example of “Thumbs Gallery” from the swiper website :
Technically you can. Just create Picture or Glance Cards and insert those inside the Swiper Card. Then use the correct parameters and components (like navigation and/or pagination). Then you have what you showed in the demo.
I tried to make a simple example and I’m not sure that what I’m trying to do is possible…
In fact the “Thumbs” component is a way to sync two swipers so the main swiper has another instance of a swiper in parameter :face_with_monocle:
So two question about the code example below (which doesn’t work) :
  1. Is vertical stack the right way to do it?
  2. Can I instantiate my sub swiper in the main swiper ?
type: vertical-stack
cards:
  - type: 'custom:swipe-card'
    title: MainSwiper
    parameters:
      navigation: null
      keyboard:
        enabled: true
      Thumbs:
        swiper: SubSwiper
        autoScrollOffset: 1
    cards:
      - type: sensor
        entity: sensor.temp_chambre
      - type: sensor
        entity: sensor.temp_1
      - type: sensor
        entity: sensor.temp_2
      - type: sensor
        entity: sensor.temp_3
    title: SubSwiper
    card_width: 185px
    parameters:
      freeMode: true
      grabCursor: true
      spaceBetween: 10
      watchSlidesVisibility: true
      watchSlidesProgress: true
      slidesPerView: 2
    cards:
      - type: sensor
      - type: sensor
      - type: sensor
      - type: sensor
Thanks for your advice :slight_smile:
Is there a way to have the cards auto swype? I have all my notifications setup but I want them to auto scroll and also somehow hide the pages without any active notifications.
Well figured out autoscroll but I still need to to hide inactive cards, anyone with a tip?
        parameters:
          spaceBetween: 0
          scrollbar:
            hide: true
            draggable: true
            snapOnRelease: true
          effect: cover
          slideShadows: true
          autoplay:
            delay: 1000
          speed: 2000
        cards:
          - type: entity-filter
            state_filter:
              - 'on'
              - armed_home
              - armed_away
              - cool
              - Clean
              - heat
              - '1'
              - '2'
              - '3'
              - '4'
              - open
            show_header_toggle: false
            entities:
              - entity: alarm_control_panel.home_alarm
                icon: 'mdi:alarm-light'
              - entity: >-
                  cover.linear_nortek_security_control_llc_gd00z_4_garage_door_opener_remote_controller_barrier_state_label
              - entity: input_boolean.mail_flag
              - entity: switch.inovelli_unknown_type_ff00_id_ff07_switch
              - entity: input_boolean.trash_out
                name: It's Trash Day!
              - entity: input_boolean.recycle_out
                name: It's Recycling Day!
            state_filter:
              - 'on'
              - armed_home
              - armed_away
              - cool
              - Clean
              - heat
              - '1'
              - '2'
              - '3'
              - '4'
              - open
            entities:
              - entity: binary_sensor.aerogarden_farm_left_need_water
                name: Farm Left Needs Water
              - entity: binary_sensor.aerogarden_farm_right_need_water
                name: Farm Right Needs Water
              - entity: binary_sensor.aerogarden_grandma_s_bounty_left_need_water
                name: Bounty Needs Water
              - entity: binary_sensor.aerogarden_farm_left_need_nutrients
                name: Farm Left Needs Nutrients
              - entity: binary_sensor.aerogarden_farm_right_need_nutrients
                name: Farm Right Needs Nutrients
              - entity: binary_sensor.aerogarden_grandma_s_bounty_left_need_nutrients
                name: Bounty Needs Nutrients
            state_filter:
              - 'on'
              - armed_home
              - armed_away
              - cool
              - Clean
              - heat
              - '1'
              - '2'
              - '3'
              - '4'
              - open
            entities:
              - entity: switch.jasco_products_14288_duplex_receptacle_switch
                name: Attic Fan On
              - entity: climate.home
                name: Central Thermostat
              - entity: switch.dehumidifier_switch
                name: Dehumidifier is On
              - entity: sensor.vacuum
                name: Rosie 5 MK2
            state_filter:
              - 'on'
              - armed_home
              - armed_away
              - cool
              - Clean
              - heat
              - '1'
              - '2'
              - '3'
              - '4'
              - open
            entities:
              - entity: input_boolean.aloe_water
                name: Aloe Plant Needs Water
              - entity: input_boolean.croton_water
                name: Croton Plant Needs Water
              - entity: input_boolean.dragon_tree_water
                name: Dragon Tree Plant Needs Water
              - entity: input_boolean.front_garden_water
                name: Front Garden Needs Water
            state_filter:
              - 'on'
              - armed_home
              - armed_away
              - cool
              - Clean
              - heat
              - '1'
              - '2'
              - '3'
              - '4'
              - open
            entities:
              - entity: binary_sensor.updater
                name: HassIO Update Pending
              - entity: sensor.hacs
                name: Hacs Update Pending
Hi, auto scroll is working for me with this config :
preview:
GIF 17-11-2020 02-34-05
title: Backyard
card_width: 185px
start_card: 2
parameters:
  effect: coverflow
  grabCursor: true
  slidesPerView: auto
  autoplay:
    delay: 2000
  coverflowEffect:
    rotate: 50
    stretch: 0
    depth: 100
    modifier: 1
    slideShadows: true
  pagination:
    type: bullets
cards:
  - type: sensor
    line_width: 6
    line_color: '#FF6384'
  - type: sensor
    line_color: '#36A2EB'
    line_width: 8
  - type: sensor
    line_color: '#ffce57'
    line_width: 8
  - type: sensor
    entity: sensor.temp_4
    line_color: '#4BC0C0'
    accuracy: 8
    line_width: 8
But I don’t know for hiding inactive cards…
Thanks, got auto working but now I have the t.setConfig error and cant get it to go away. Tried downgrading and clearing cache but its still there
Recently I had a problem with Nginx cache… Just in case keep it in mind when you made modifications and it doesn’t work after clearing browser cache :wink:
Where is that cache and when you cleared it did the t.set error go away?
