petro
(Petro)
October 14, 2018, 1:02pm
41
So this card does not display anything beyond this card if you add a sensor to the custom:mini-graph-card that outputs a string. Example: I have a sesnor that outputs used space on a disk drive. The sensor outputs units with the state so the result is ‘34gb’ instead of 34. When this happens, everything below this card in the current view does not load.
- type: custom:swipe-card
card_width: '185px'
start_card: 1
parameters:
effect: 'coverflow'
grabCursor: true
centeredSlides: true
slidesPerView: 'auto'
coverflowEffect:
rotate: 50
stretch: 0
depth: 100
modifier: 1
slideShadows : true
pagination:
type: 'bullets'
cards:
# This card breaks the swipe-card and every card below swipe-card
# if the sensor.used_space_volume_1 returns a string that cannot be
# converted to a number.
- type: custom:mini-graph-card
entity: sensor.used_space_volume_1
line_width: 8
line_color: '#FF6384'
EDIT: To clarify, if i use a different configuration it works. It appears as if the ‘smaller sized’ card that does not contain a graph messes this exact configuration up.
EDIT: It seems as if it’s just the custom:mini-graph-card that is causing the problems. It just doesn’t display with some sensors.
LAST EDIT: Updated from 0.75.3 to 0.80. Fixed all issues I was having with this.
Great, thank you very much. see below.
woody4165
(Woody)
October 16, 2018, 8:34am
44
Great, really hot space saving in an UI
Is it possible to give a title to the entire card?
I tried with name:
and title:
but with no success.
Thanks!
Argo
(Argo)
October 16, 2018, 4:32pm
45
Hey there!
Bram_Kragten:
url: /local/custom-lovelace/swipe-card/swipe-card.js?v=1.0 type: js
Here is a mistake isn’t it? Should be:
- url: /local/custom-lovelace/swipe-card/swiper-card.js?v=1.0
type: js
Not swipe-card.js
but swiper-card.js
petro
(Petro)
October 16, 2018, 4:44pm
46
@Bram_Kragten I second Woody, this would be a nice enhancement to the card.
matisaul
(Matias Saul)
October 16, 2018, 11:59pm
47
Hi, could you share that config?? I’m using the button-card, but I can’t success using swiper
Wow… I have to say this one is just beautiful and works great without issues the first time…
this really makes the UI pop, feels like a major HA upgrade.
Thanks so much for this!!!
woody4165
(Woody)
October 17, 2018, 7:39am
49
Can someone share the code for this swipe card?
parameters:
spaceBetween: 8
cards:
- type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: entity-button
entity: light.eettafel
icon: mdi:sofa
color: red
action: more_info
icon: mdi:ceiling-light
action: more_info
entity: light.ron
icon: mdi:lamp
action: more_info
entity: light.snape
icon: mdi:floor-lamp
action: more_info
cards:
entity: light.living_room_lights
icon: mdi:sofa
action: more_info
entity: light.harry
action: more_info
entity: light.ron
icon: mdi:lamp
action: more_info
entity: light.snape
action: more_info
cards:
cards:
icon: mdi:sofa
color: red
action: more_info
action: more_info
entity: light.ron
icon: mdi:lamp
action: more_info
entity: light.snape
action: more_info
cards:
icon: mdi:sofa
action: more_info
color_type: card
entity: light.harry
action: more_info
entity: light.ron
icon: mdi:lamp
action: more_info
entity: light.snape
action: more_info
maurizio53
(Maurizio Fabiani)
October 17, 2018, 10:28am
51
Why i get this little difference between the two cards having the same code?
card_width: '80%'
parameters:
effect: 'coverflow'
spaceBetween: 8
pagination:
type: 'progressbar'
navigation:
keyboard:
enabled: true
onlyInViewport: true
cards:
- type: sensor
entity: sensor.temperature_158d0002009a82
line_width: 8
- type: sensor
entity: sensor.temperature_158d0001b95fa0
name: Temperatura Camera Letto
line_color: '#36A2EB'
line_width: 8
- type: sensor
entity: sensor.temperature_158d0001b95f60
line_color: '#ffce57'
line_width: 8
- type: sensor
entity: sensor.bagno_temperature
line_color: "#4BC0C0"
accuracy: 8
line_width: 8
card_width: '80%'
parameters:
spaceBetween: 8
pagination:
type: 'progressbar'
navigation:
keyboard:
enabled: true
cards:
- type: sensor
entity: sensor.humidity_158d0002009a82
line_width: 8
- type: sensor
entity: sensor.humidity_158d0001b95fa0
name: Umidità Camera Letto
line_width: 8
- type: sensor
entity: sensor.humidity_158d0001b95f60
line_width: 8
- type: sensor
entity: sensor.bagno_humidity
accuracy: 8
line_width: 8
Could you share how you did this this way?
Mine works but the tiles aren’t all the same size like this, can’t really figure out how…
It seems to be auto adjusting with the text but how do I force the format like yours?
Yeah, just make sure the texts are about the same lenght
maurizio53
(Maurizio Fabiani)
October 17, 2018, 3:10pm
55
Arghhhh… forgot to disable !!!
tested different settings and ended up better
matisaul
(Matias Saul)
October 17, 2018, 3:43pm
57
Is there a way to put the bullet pagination lower than the cards? (like margin-bottom)
You can change the css file
It would look weird, this card is not a card itself. Like is does not have a background color and drop shadow.
matisaul
(Matias Saul)
October 17, 2018, 6:12pm
60
I don’t know why I get an error message, but refreshing the browser several times works:
Uncaught TypeError: element.setConfig is not a function
Am I doing something wrong, or is a known bug?
