You donāt need to do that. Just put it in your theme
@Ian, great update, so simple, but opens so much possibilities now, with possibility to play with text size. Some follow up questions; would it be possible to make text not bold (or have some control by theme variables, which I like very much)? Would it be possible to reduce spacing before/after text divider? it seems to be a bit to big, especially if replacing standard divider other items seems to be pushed away up/down from text dividerā¦
EDIT: here is sample from my configuration that shows the issue (same code side by side using text divider row and standard divider):
Hi, Iām having trouble getting the text-divider-row to show in an entity-filter card.
I guess I need to add something to the state_filter section but Iāve no idea what.
type: entity-filter
entities:
- type: 'custom:text-divider-row'
text: Doors
- entity: sensor.front_door
- entity: sensor.inner_door
- entity: sensor.kitchen_door
- entity: sensor.garage_door
- entity: sensor.utility_room_door
- entity: sensor.patio_door
text: Windows
- entity: sensor.porch_window
- entity: sensor.workshop_window
- entity: sensor.utility_room_window
state_filter:
- open
The dividers show up if I change āentity-filterā to āentitiesā.
Can somebody help me here please?
It doesnāt have an entity so itās always going to be filtered
Ok, thanks, could you maybe add a note about that to the documentation to save anyone else wasting many hours trying to get it working.
Is there a way to reduce the top/bottom margin? I did some changes in a earlier version of the card but canāt figure it out how to do in the new version! Iām trying to use mod-card but is also not working and driving me crazy!!
Yes, there is. Here is updated code for this element with some further finetuning of parameters. You need to go to www\communitu\text-divider-row folder, delete (or rename text-divider-row.js.gz and replace conten of text-divider-row.js with code below:
Copyright (c) Microsoft Corporation.
Permission to use, copy, modify, and/or distribute this software for any
purpose with or without fee is hereby granted.
THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES WITH
REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF MERCHANTABILITY
AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY SPECIAL, DIRECT,
INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES WHATSOEVER RESULTING FROM
LOSS OF USE, DATA OR PROFITS, WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR
OTHER TORTIOUS ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR
PERFORMANCE OF THIS SOFTWARE.
function t(t,e,s,i){var n,r=arguments.length,o=r<3?e:null===i?i=Object.getOwnPropertyDescriptor(e,s):i;if("object"==typeof Reflect&&"function"==typeof Reflect.decorate)o=Reflect.decorate(t,e,s,i);else for(var a=t.length-1;a>=0;a--)(n=t[a])&&(o=(r<3?n(o):r>3?n(e,s,o):n(e,s))||o);return r>3&&o&&Object.defineProperty(e,s,o),o
* @license
* Copyright (c) 2017 The Polymer Project Authors. All rights reserved.
* This code may only be used under the BSD style license found at
* http://polymer.github.io/LICENSE.txt
* The complete set of authors may be found at
* http://polymer.github.io/AUTHORS.txt
* The complete set of contributors may be found at
* http://polymer.github.io/CONTRIBUTORS.txt
* Code distributed by Google as part of the polymer project is also
* subject to an additional IP rights grant found at
* http://polymer.github.io/PATENTS.txt
*/}const e="undefined"!=typeof window&&null!=window.customElements&&void 0!==window.customElements.polyfillWrapFlushCallback,s=(t,e,s=null)=>{for(;e!==s;){const s=e.nextSibling;t.removeChild(e),e=s}},i=`{{lit-${String(Math.random()).slice(2)}}}`,n=`\x3c!--${i}--\x3e`,r=new RegExp(`${i}|${n}`);class o{constructor(t,e){this.parts=[],this.element=e;const s=[],n=[],o=document.createTreeWalker(e.content,133,null,!1);let l=0,h=-1,p=0;const{strings:u,values:{length:_}}=t;for(;p<_;){const t=o.nextNode();if(null!==t){if(h++,1===t.nodeType){if(t.hasAttributes()){const e=t.attributes,{length:s}=e;let i=0;for(let t=0;t<s;t++)a(e[t].name,"$lit$")&&i++;for(;i-- >0;){const e=u[p],s=d.exec(e)[2],i=s.toLowerCase()+"$lit$",n=t.getAttribute(i);t.removeAttribute(i);const o=n.split(r);this.parts.push({type:"attribute",index:h,name:s,strings:o}),p+=o.length-1}}"TEMPLATE"===t.tagName&&(n.push(t),o.currentNode=t.content)}else if(3===t.nodeType){const e=t.data;if(e.indexOf(i)>=0){const i=t.parentNode,n=e.split(r),o=n.length-1;for(let e=0;e<o;e++){let s,r=n[e];if(""===r)s=c();else{const t=d.exec(r);null!==t&&a(t[2],"$lit$")&&(r=r.slice(0,t.index)+t[1]+t[2].slice(0,-"$lit$".length)+t[3]),s=document.createTextNode(r)}i.insertBefore(s,t),this.parts.push({type:"node",index:++h})}""===n[o]?(i.insertBefore(c(),t),s.push(t)):t.data=n[o],p+=o}}else if(8===t.nodeType)if(t.data===i){const e=t.parentNode;null!==t.previousSibling&&h!==l||(h++,e.insertBefore(c(),t)),l=h,this.parts.push({type:"node",index:h}),null===t.nextSibling?t.data="":(s.push(t),h--),p++}else{let e=-1;for(;-1!==(e=t.data.indexOf(i,e+1));)this.parts.push({type:"node",index:-1}),p++}}else o.currentNode=n.pop()}for(const t of s)t.parentNode.removeChild(t)}}const a=(t,e)=>{const s=t.length-e.length;return s>=0&&t.slice(s)===e},l=t=>-1!==t.index,c=()=>document.createComment(""),d=/([ \x09\x0a\x0c\x0d])([^\0-\x1F\x7F-\x9F "'>=/]+)([ \x09\x0a\x0c\x0d]*=[ \x09\x0a\x0c\x0d]*(?:[^ \x09\x0a\x0c\x0d"'`<>=]*|"[^"]*|'[^']*))$/;function h(t,e){const{element:{content:s},parts:i}=t,n=document.createTreeWalker(s,133,null,!1);let r=u(i),o=i[r],a=-1,l=0;const c=[];let d=null;for(;n.nextNode();){a++;const t=n.currentNode;for(t.previousSibling===d&&(d=null),e.has(t)&&(c.push(t),null===d&&(d=t)),null!==d&&l++;void 0!==o&&o.index===a;)o.index=null!==d?-1:o.index-l,r=u(i,r),o=i[r]}c.forEach(t=>t.parentNode.removeChild(t))}const p=t=>{let e=11===t.nodeType?0:1;const s=document.createTreeWalker(t,133,null,!1);for(;s.nextNode();)e++;return e},u=(t,e=-1)=>{for(let s=e+1;s<t.length;s++){const e=t[s];if(l(e))return s}return-1};
* @license
const _=new WeakMap,m=t=>"function"==typeof t&&_.has(t),f={},y={};
* @license
class g{constructor(t,e,s){this.__parts=[],this.template=t,this.processor=e,this.options=s}update(t){let e=0;for(const s of this.__parts)void 0!==s&&s.setValue(t[e]),e++;for(const t of this.__parts)void 0!==t&&t.commit()}_clone(){const t=e?this.template.element.content.cloneNode(!0):document.importNode(this.template.element.content,!0),s=[],i=this.template.parts,n=document.createTreeWalker(t,133,null,!1);let r,o=0,a=0,c=n.nextNode();for(;o<i.length;)if(r=i[o],l(r)){for(;a<r.index;)a++,"TEMPLATE"===c.nodeName&&(s.push(c),n.currentNode=c.content),null===(c=n.nextNode())&&(n.currentNode=s.pop(),c=n.nextNode());if("node"===r.type){const t=this.processor.handleTextExpression(this.options);t.insertAfterNode(c.previousSibling),this.__parts.push(t)}else this.__parts.push(...this.processor.handleAttributeExpressions(c,r.name,r.strings,this.options));o++}else this.__parts.push(void 0),o++;return e&&(document.adoptNode(t),customElements.upgrade(t)),t}}
* @license
*/const v=` ${i} `;class S{constructor(t,e,s,i){this.strings=t,this.values=e,this.type=s,this.processor=i}getHTML(){const t=this.strings.length-1;let e="",s=!1;for(let r=0;r<t;r++){const t=this.strings[r],o=t.lastIndexOf("\x3c!--");s=(o>-1||s)&&-1===t.indexOf("--\x3e",o+1);const a=d.exec(t);e+=null===a?t+(s?v:n):t.substr(0,a.index)+a[1]+a[2]+"$lit$"+a[3]+i}return e+=this.strings[t],e}getTemplateElement(){const t=document.createElement("template");return t.innerHTML=this.getHTML(),t}}
* @license
*/const w=t=>null===t||!("object"==typeof t||"function"==typeof t),b=t=>Array.isArray(t)||!(!t||!t[Symbol.iterator]);class x{constructor(t,e,s){this.dirty=!0,this.element=t,this.name=e,this.strings=s,this.parts=[];for(let t=0;t<s.length-1;t++)this.parts[t]=this._createPart()}_createPart(){return new P(this)}_getValue(){const t=this.strings,e=t.length-1;let s="";for(let i=0;i<e;i++){s+=t[i];const e=this.parts[i];if(void 0!==e){const t=e.value;if(w(t)||!b(t))s+="string"==typeof t?t:String(t);else for(const e of t)s+="string"==typeof e?e:String(e)}}return s+=t[e],s}commit(){this.dirty&&(this.dirty=!1,this.element.setAttribute(this.name,this._getValue()))}}class P{constructor(t){this.value=void 0,this.committer=t}setValue(t){t===f||w(t)&&t===this.value||(this.value=t,m(t)||(this.committer.dirty=!0))}commit(){for(;m(this.value);){const t=this.value;this.value=f,t(this)}this.value!==f&&this.committer.commit()}}class N{constructor(t){this.value=void 0,this.__pendingValue=void 0,this.options=t}appendInto(t){this.startNode=t.appendChild(c()),this.endNode=t.appendChild(c())}insertAfterNode(t){this.startNode=t,this.endNode=t.nextSibling}appendIntoPart(t){t.__insert(this.startNode=c()),t.__insert(this.endNode=c())}insertAfterPart(t){t.__insert(this.startNode=c()),this.endNode=t.endNode,t.endNode=this.startNode}setValue(t){this.__pendingValue=t}commit(){if(null===this.startNode.parentNode)return;for(;m(this.__pendingValue);){const t=this.__pendingValue;this.__pendingValue=f,t(this)}const t=this.__pendingValue;t!==f&&(w(t)?t!==this.value&&this.__commitText(t):t instanceof S?this.__commitTemplateResult(t):t instanceof Node?this.__commitNode(t):b(t)?this.__commitIterable(t):t===y?(this.value=y,this.clear()):this.__commitText(t))}__insert(t){this.endNode.parentNode.insertBefore(t,this.endNode)}__commitNode(t){this.value!==t&&(this.clear(),this.__insert(t),this.value=t)}__commitText(t){const e=this.startNode.nextSibling,s="string"==typeof(t=null==t?"":t)?t:String(t);e===this.endNode.previousSibling&&3===e.nodeType?e.data=s:this.__commitNode(document.createTextNode(s)),this.value=t}__commitTemplateResult(t){const e=this.options.templateFactory(t);if(this.value instanceof g&&this.value.template===e)this.value.update(t.values);else{const s=new g(e,t.processor,this.options),i=s._clone();s.update(t.values),this.__commitNode(i),this.value=s}}__commitIterable(t){Array.isArray(this.value)||(this.value=[],this.clear());const e=this.value;let s,i=0;for(const n of t)s=e[i],void 0===s&&(s=new N(this.options),e.push(s),0===i?s.appendIntoPart(this):s.insertAfterPart(e[i-1])),s.setValue(n),s.commit(),i++;i<e.length&&(e.length=i,this.clear(s&&s.endNode))}clear(t=this.startNode){s(this.startNode.parentNode,t.nextSibling,this.endNode)}}class C{constructor(t,e,s){if(this.value=void 0,this.__pendingValue=void 0,2!==s.length||""!==s[0]||""!==s[1])throw new Error("Boolean attributes can only contain a single expression");this.element=t,this.name=e,this.strings=s}setValue(t){this.__pendingValue=t}commit(){for(;m(this.__pendingValue);){const t=this.__pendingValue;this.__pendingValue=f,t(this)}if(this.__pendingValue===f)return;const t=!!this.__pendingValue;this.value!==t&&(t?this.element.setAttribute(this.name,""):this.element.removeAttribute(this.name),this.value=t),this.__pendingValue=f}}class E extends x{constructor(t,e,s){super(t,e,s),this.single=2===s.length&&""===s[0]&&""===s[1]}_createPart(){return new T(this)}_getValue(){return this.single?this.parts[0].value:super._getValue()}commit(){this.dirty&&(this.dirty=!1,this.element[this.name]=this._getValue())}}class T extends P{}let A=!1;(()=>{try{const t={get capture(){return A=!0,!1}};window.addEventListener("test",t,t),window.removeEventListener("test",t,t)}catch(t){}})();class V{constructor(t,e,s){this.value=void 0,this.__pendingValue=void 0,this.element=t,this.eventName=e,this.eventContext=s,this.__boundHandleEvent=t=>this.handleEvent(t)}setValue(t){this.__pendingValue=t}commit(){for(;m(this.__pendingValue);){const t=this.__pendingValue;this.__pendingValue=f,t(this)}if(this.__pendingValue===f)return;const t=this.__pendingValue,e=this.value,s=null==t||null!=e&&(t.capture!==e.capture||t.once!==e.once||t.passive!==e.passive),i=null!=t&&(null==e||s);s&&this.element.removeEventListener(this.eventName,this.__boundHandleEvent,this.__options),i&&(this.__options=k(t),this.element.addEventListener(this.eventName,this.__boundHandleEvent,this.__options)),this.value=t,this.__pendingValue=f}handleEvent(t){"function"==typeof this.value?this.value.call(this.eventContext||this.element,t):this.value.handleEvent(t)}}const k=t=>t&&(A?{capture:t.capture,passive:t.passive,once:t.once}:t.capture)
* @license
*/;function O(t){let e=U.get(t.type);void 0===e&&(e={stringsArray:new WeakMap,keyString:new Map},U.set(t.type,e));let s=e.stringsArray.get(t.strings);if(void 0!==s)return s;const n=t.strings.join(i);return s=e.keyString.get(n),void 0===s&&(s=new o(t,t.getTemplateElement()),e.keyString.set(n,s)),e.stringsArray.set(t.strings,s),s}const U=new Map,R=new WeakMap;
* @license
*/const M=new
* @license
class{handleAttributeExpressions(t,e,s,i){const n=e[0];if("."===n){return new E(t,e.slice(1),s).parts}if("@"===n)return[new V(t,e.slice(1),i.eventContext)];if("?"===n)return[new C(t,e.slice(1),s)];return new x(t,e,s).parts}handleTextExpression(t){return new N(t)}};
* @license
*/"undefined"!=typeof window&&(window.litHtmlVersions||(window.litHtmlVersions=[])).push("1.2.1");const z=(t,...e)=>new S(t,e,"html",M)
* @license
*/,j=(t,e)=>`${t}--${e}`;let $=!0;void 0===window.ShadyCSS?$=!1:void 0===window.ShadyCSS.prepareTemplateDom&&(console.warn("Incompatible ShadyCSS version detected. Please update to at least @webcomponents/[email protected] and @webcomponents/[email protected]."),$=!1);const q=t=>e=>{const s=j(e.type,t);let n=U.get(s);void 0===n&&(n={stringsArray:new WeakMap,keyString:new Map},U.set(s,n));let r=n.stringsArray.get(e.strings);if(void 0!==r)return r;const a=e.strings.join(i);if(r=n.keyString.get(a),void 0===r){const s=e.getTemplateElement();$&&window.ShadyCSS.prepareTemplateDom(s,t),r=new o(e,s),n.keyString.set(a,r)}return n.stringsArray.set(e.strings,r),r},I=["html","svg"],F=new Set,L=(t,e,s)=>{F.add(t);const i=s?s.element:document.createElement("template"),n=e.querySelectorAll("style"),{length:r}=n;if(0===r)return void window.ShadyCSS.prepareTemplateStyles(i,t);const o=document.createElement("style");for(let t=0;t<r;t++){const e=n[t];e.parentNode.removeChild(e),o.textContent+=e.textContent}(t=>{I.forEach(e=>{const s=U.get(j(e,t));void 0!==s&&s.keyString.forEach(t=>{const{element:{content:e}}=t,s=new Set;Array.from(e.querySelectorAll("style")).forEach(t=>{s.add(t)}),h(t,s)})})})(t);const a=i.content;s?function(t,e,s=null){const{element:{content:i},parts:n}=t;if(null==s)return void i.appendChild(e);const r=document.createTreeWalker(i,133,null,!1);let o=u(n),a=0,l=-1;for(;r.nextNode();){l++;for(r.currentNode===s&&(a=p(e),s.parentNode.insertBefore(e,s));-1!==o&&n[o].index===l;){if(a>0){for(;-1!==o;)n[o].index+=a,o=u(n,o);return}o=u(n,o)}}}(s,o,a.firstChild):a.insertBefore(o,a.firstChild),window.ShadyCSS.prepareTemplateStyles(i,t);const l=a.querySelector("style");if(window.ShadyCSS.nativeShadow&&null!==l)e.insertBefore(l.cloneNode(!0),e.firstChild);else if(s){a.insertBefore(o,a.firstChild);const t=new Set;t.add(o),h(s,t)}};window.JSCompiler_renameProperty=(t,e)=>t;const B={toAttribute(t,e){switch(e){case Boolean:return t?"":null;case Object:case Array:return null==t?t:JSON.stringify(t)}return t},fromAttribute(t,e){switch(e){case Boolean:return null!==t;case Number:return null===t?null:Number(t);case Object:case Array:return JSON.parse(t)}return t}},H=(t,e)=>e!==t&&(e==e||t==t),W={attribute:!0,type:String,converter:B,reflect:!1,hasChanged:H};class D extends HTMLElement{constructor(){super(),this._updateState=0,this._instanceProperties=void 0,this._updatePromise=new Promise(t=>this._enableUpdatingResolver=t),this._changedProperties=new Map,this._reflectingProperties=void 0,this.initialize()}static get observedAttributes(){this.finalize();const t=[];return this._classProperties.forEach((e,s)=>{const i=this._attributeNameForProperty(s,e);void 0!==i&&(this._attributeToPropertyMap.set(i,s),t.push(i))}),t}static _ensureClassProperties(){if(!this.hasOwnProperty(JSCompiler_renameProperty("_classProperties",this))){this._classProperties=new Map;const t=Object.getPrototypeOf(this)._classProperties;void 0!==t&&t.forEach((t,e)=>this._classProperties.set(e,t))}}static createProperty(t,e=W){if(this._ensureClassProperties(),this._classProperties.set(t,e),e.noAccessor||this.prototype.hasOwnProperty(t))return;const s="symbol"==typeof t?Symbol():"__"+t,i=this.getPropertyDescriptor(t,s,e);void 0!==i&&Object.defineProperty(this.prototype,t,i)}static getPropertyDescriptor(t,e,s){return{get(){return this[e]},set(s){const i=this[t];this[e]=s,this._requestUpdate(t,i)},configurable:!0,enumerable:!0}}static getPropertyOptions(t){return this._classProperties&&this._classProperties.get(t)||W}static finalize(){const t=Object.getPrototypeOf(this);if(t.hasOwnProperty("finalized")||t.finalize(),this.finalized=!0,this._ensureClassProperties(),this._attributeToPropertyMap=new Map,this.hasOwnProperty(JSCompiler_renameProperty("properties",this))){const t=this.properties,e=[...Object.getOwnPropertyNames(t),..."function"==typeof Object.getOwnPropertySymbols?Object.getOwnPropertySymbols(t):[]];for(const s of e)this.createProperty(s,t[s])}}static _attributeNameForProperty(t,e){const s=e.attribute;return!1===s?void 0:"string"==typeof s?s:"string"==typeof t?t.toLowerCase():void 0}static _valueHasChanged(t,e,s=H){return s(t,e)}static _propertyValueFromAttribute(t,e){const s=e.type,i=e.converter||B,n="function"==typeof i?i:i.fromAttribute;return n?n(t,s):t}static _propertyValueToAttribute(t,e){if(void 0===e.reflect)return;const s=e.type,i=e.converter;return(i&&i.toAttribute||B.toAttribute)(t,s)}initialize(){this._saveInstanceProperties(),this._requestUpdate()}_saveInstanceProperties(){this.constructor._classProperties.forEach((t,e)=>{if(this.hasOwnProperty(e)){const t=this[e];delete this[e],this._instanceProperties||(this._instanceProperties=new Map),this._instanceProperties.set(e,t)}})}_applyInstanceProperties(){this._instanceProperties.forEach((t,e)=>this[e]=t),this._instanceProperties=void 0}connectedCallback(){this.enableUpdating()}enableUpdating(){void 0!==this._enableUpdatingResolver&&(this._enableUpdatingResolver(),this._enableUpdatingResolver=void 0)}disconnectedCallback(){}attributeChangedCallback(t,e,s){e!==s&&this._attributeToProperty(t,s)}_propertyToAttribute(t,e,s=W){const i=this.constructor,n=i._attributeNameForProperty(t,s);if(void 0!==n){const t=i._propertyValueToAttribute(e,s);if(void 0===t)return;this._updateState=8|this._updateState,null==t?this.removeAttribute(n):this.setAttribute(n,t),this._updateState=-9&this._updateState}}_attributeToProperty(t,e){if(8&this._updateState)return;const s=this.constructor,i=s._attributeToPropertyMap.get(t);if(void 0!==i){const t=s.getPropertyOptions(i);this._updateState=16|this._updateState,this[i]=s._propertyValueFromAttribute(e,t),this._updateState=-17&this._updateState}}_requestUpdate(t,e){let s=!0;if(void 0!==t){const i=this.constructor,n=i.getPropertyOptions(t);i._valueHasChanged(this[t],e,n.hasChanged)?(this._changedProperties.has(t)||this._changedProperties.set(t,e),!0!==n.reflect||16&this._updateState||(void 0===this._reflectingProperties&&(this._reflectingProperties=new Map),this._reflectingProperties.set(t,n))):s=!1}!this._hasRequestedUpdate&&s&&(this._updatePromise=this._enqueueUpdate())}requestUpdate(t,e){return this._requestUpdate(t,e),this.updateComplete}async _enqueueUpdate(){this._updateState=4|this._updateState;try{await this._updatePromise}catch(t){}const t=this.performUpdate();return null!=t&&await t,!this._hasRequestedUpdate}get _hasRequestedUpdate(){return 4&this._updateState}get hasUpdated(){return 1&this._updateState}performUpdate(){this._instanceProperties&&this._applyInstanceProperties();let t=!1;const e=this._changedProperties;try{t=this.shouldUpdate(e),t?this.update(e):this._markUpdated()}catch(e){throw t=!1,this._markUpdated(),e}t&&(1&this._updateState||(this._updateState=1|this._updateState,this.firstUpdated(e)),this.updated(e))}_markUpdated(){this._changedProperties=new Map,this._updateState=-5&this._updateState}get updateComplete(){return this._getUpdateComplete()}_getUpdateComplete(){return this._updatePromise}shouldUpdate(t){return!0}update(t){void 0!==this._reflectingProperties&&this._reflectingProperties.size>0&&(this._reflectingProperties.forEach((t,e)=>this._propertyToAttribute(e,this[e],t)),this._reflectingProperties=void 0),this._markUpdated()}updated(t){}firstUpdated(t){}}D.finalized=!0;
* @license
const J=(t,e)=>"method"===e.kind&&e.descriptor&&!("value"in e.descriptor)?Object.assign(Object.assign({},e),{finisher(s){s.createProperty(e.key,t)}}):{kind:"field",key:Symbol(),placement:"own",descriptor:{},initializer(){"function"==typeof e.initializer&&(this[e.key]=e.initializer.call(this))},finisher(s){s.createProperty(e.key,t)}};
@license
Copyright (c) 2019 The Polymer Project Authors. All rights reserved.
http://polymer.github.io/LICENSE.txt The complete set of authors may be found at
http://polymer.github.io/AUTHORS.txt The complete set of contributors may be
found at http://polymer.github.io/CONTRIBUTORS.txt Code distributed by Google as
part of the polymer project is also subject to an additional IP rights grant
found at http://polymer.github.io/PATENTS.txt
const X="adoptedStyleSheets"in Document.prototype&&"replace"in CSSStyleSheet.prototype,G=Symbol();class K{constructor(t,e){if(e!==G)throw new Error("CSSResult is not constructable. Use `unsafeCSS` or `css` instead.");this.cssText=t}get styleSheet(){return void 0===this._styleSheet&&(X?(this._styleSheet=new CSSStyleSheet,this._styleSheet.replaceSync(this.cssText)):this._styleSheet=null),this._styleSheet}toString(){return this.cssText}}const Q=(t,...e)=>{const s=e.reduce((e,s,i)=>e+(t=>{if(t instanceof K)return t.cssText;if("number"==typeof t)return t;throw new Error(`Value passed to 'css' function must be a 'css' function result: ${t}. Use 'unsafeCSS' to pass non-literal values, but\n take care to ensure page security.`)})(s)+t[i+1],t[0]);return new K(s,G)};
* @license
(window.litElementVersions||(window.litElementVersions=[])).push("2.3.1");const Y={};class Z extends D{static getStyles(){return this.styles}static _getUniqueStyles(){if(this.hasOwnProperty(JSCompiler_renameProperty("_styles",this)))return;const t=this.getStyles();if(void 0===t)this._styles=[];else if(Array.isArray(t)){const e=(t,s)=>t.reduceRight((t,s)=>Array.isArray(s)?e(s,t):(t.add(s),t),s),s=e(t,new Set),i=[];s.forEach(t=>i.unshift(t)),this._styles=i}else this._styles=[t]}initialize(){super.initialize(),this.constructor._getUniqueStyles(),this.renderRoot=this.createRenderRoot(),window.ShadowRoot&&this.renderRoot instanceof window.ShadowRoot&&this.adoptStyles()}createRenderRoot(){return this.attachShadow({mode:"open"})}adoptStyles(){const t=this.constructor._styles;0!==t.length&&(void 0===window.ShadyCSS||window.ShadyCSS.nativeShadow?X?this.renderRoot.adoptedStyleSheets=t.map(t=>t.styleSheet):this._needsShimAdoptedStyleSheets=!0:window.ShadyCSS.ScopingShim.prepareAdoptedCssText(t.map(t=>t.cssText),this.localName))}connectedCallback(){super.connectedCallback(),this.hasUpdated&&void 0!==window.ShadyCSS&&window.ShadyCSS.styleElement(this)}update(t){const e=this.render();super.update(t),e!==Y&&this.constructor.render(e,this.renderRoot,{scopeName:this.localName,eventContext:this}),this._needsShimAdoptedStyleSheets&&(this._needsShimAdoptedStyleSheets=!1,this.constructor._styles.forEach(t=>{const e=document.createElement("style");e.textContent=t.cssText,this.renderRoot.appendChild(e)}))}render(){return Y}}Z.finalized=!0,Z.render=(t,e,i)=>{if(!i||"object"!=typeof i||!i.scopeName)throw new Error("The `scopeName` option is required.");const n=i.scopeName,r=R.has(e),o=$&&11===e.nodeType&&!!e.host,a=o&&!F.has(n),l=a?document.createDocumentFragment():e;if(((t,e,i)=>{let n=R.get(e);void 0===n&&(s(e,e.firstChild),R.set(e,n=new N(Object.assign({templateFactory:O},i))),n.appendInto(e)),n.setValue(t),n.commit()})(t,l,Object.assign({templateFactory:q(n)},i)),a){const t=R.get(l);R.delete(l);const i=t.value instanceof g?t.value.template:void 0;L(n,l,i),s(e,e.firstChild),e.appendChild(l),R.set(e,t)}!r&&o&&window.ShadyCSS.styleElement(e.host)};console.info("%c TEXT-DIVIDER-ROW \n%c Version 1.4.0 ","color: orange; font-weight: bold; background: black","color: white; font-weight: bold; background: dimgray");let tt=class extends Z{setConfig(t){if(!t||!t.text)throw new Error("Error in card configuration.");this._config=t}render(){return this._config?z`
<h2 class="text-divider"><span>${this._config.text}</span></h2>
`:z``}static get styles(){return Q`
:host {
display: block;
position: relative;
--divider-color: var(--text-divider-color, var(--secondary-text-color));
--font-size: var(--text-divider-font-size, 14px);
--line-size: var(--text-divider-line-size, 1px);
--font-weight: var(--text-divider-font-weight, normal);
--margin-top: var(--text-divider-margin-top, 1em);
--margin-bottom: var(--text-divider-margin-bottom, 1em);
.text-divider {
margin: 0;
margin-top: var(--text-divider-margin-top);
margin-bottom: var(--text-divider-margin-bottom);
line-height: 0;
text-align: center;
white-space: nowrap;
display: flex;
align-items: center;
.text-divider span {
padding: 0.7em;
color: var(--divider-color);
font-size: var(--font-size);
font-weight: var(--font-weight)
.text-divider:before,
.text-divider:after {
content: '';
background: var(--divider-color);
display: block;
height: var(--line-size);
width: 100%;
`}};var et,st;t([(t,e)=>void 0!==e?((t,e,s)=>{e.constructor.createProperty(s,t)})(et,t,e):J(et,t)],tt.prototype,"_config",void 0),tt=t([(st="text-divider-row",t=>"function"==typeof t?((t,e)=>(window.customElements.define(t,e),e))(st,t):((t,e)=>{const{kind:s,elements:i}=e;return{kind:s,elements:i,finisher(e){window.customElements.define(t,e)}}})(st,t))],tt);
Then in your theme you need to add some new variables to control additional configuration options of text-divider-row:
# Text divider row
text-divider-color: var(--secondary-text-color)
text-divider-font-size: 15px
text-divider-line-size: 1px
text-divider-font-weight: # normal or bold
text-divider-margin-top: 0.25em # margin on top of the row
text-divider-margin-bottom: 0em # margin at the bottom of the row
Note it is a bit experimental, I made these changes for myself, so better make backup copy before replacing the files Here is sample card using modifie version of this component (using parameters as in theme above):
Thanks!!! That is exactly what I was looking for!!
Is it also possible to have the text a different color than the lines?
You get what you wish for Here is the updated code:
* @license
* @license
* @license
* @license
* @license
* @license
* @license
*/const M=new
* @license
* @license
* @license
* @license
@license
* @license
:host {
display: block;
position: relative;
--text-divider-text: var(--text-divider-text, var(--divider-color));
.text-divider {
margin: 0;
line-height: 0;
text-align: center;
display: flex;
padding: 0.7em;
color: var(--text-divider-text);
content: '';
display: block;
width: 100%;
You also need to add to your theme new color variable (the last one on the list below):
# Text divider row
text-divider-text: "#123456" # new: text color
Wow! Superb! Itās a shame I can only give 1 like Iām going to try it first thing tomorrow morning.
Thanks a lot!
why not contribute this back to the project?
Hehā¦ Iām amateur programmer, just fiddling with existing codeā¦ not even know where to start However if someone more experienced would like to take this code, check and integrateā¦ Iād be proud of my humble contribution.
Submit a PR and Iād be happy to give it a review
Thanks for this divider. Agree to say that it is one of these things that should be native in HA.
Am I the only one to think that it is strange to configure it on the theme ?
You have to reboot HA to see changes on font size/ line size ? Could be more handy directly in lovelaceā¦
Anyway it still very useful !
No you just need to reload themes.
Iāve just found that I have difficulties to see my modification due to the ācache assetsā of Nginx add on.
Two more little (newbe) questions :
- how to add parameters to the default theme ? I tried to add my parameters in a new file : āconfig\themes\default.yamlā but it doesnāt seems to be the right wayā¦
- What is the good way to reload themes ? (Select one then another is enough ? Or a reboot is necessary ?)
You canāt edit the default theme. You would need to make a whole new one with variables you want to change and not call it default!
Do you have a themes directory? Put it in there. Otherwise a themes.yaml? I think you need to check the themes docs as otherwise just repeating the docs here is not a good use of my time.
To reload themes there is a reload.themes service you can call.
Thanks for sharing your knowledge.
I read the document, I admit that I have missed the reload the āfrontend.reload_themesā. I was thinking that all the reload possibilities were exposed with āserver controlsā buttonsā¦
But for the default theme, it doesnāt indicate how we can override it (or not).
So Iāve created a new file in my theme folder, added my parameters and it works fine now. Thanks fort hat ! But I lost the dark themeā¦ I presume that I have now to import parameters now to get back a dark theme similar to the original . Anyway, this is another suject, now I know how to change a parameter on Text Divider Row
They are but only if you have defined themesā¦
The thing is if you add a theme and there are missing variables it will get the missing ones from the default theme. Depending on how you have themes configured that may be either dark or light theme.
