šŸ—‚ Lovelace Text Divider Row
now I understand, thanks a lot
Hi!
Iā€™ve been using this text divider for well over a year, but somehow itā€™s stopped working (canā€™t really say when but recentlyish?).
Iā€™ve tried removing the js and replace with a new one, tried removing it from resources (via the home assistant configuration/lovelace setting place).
The code seems to work (doesnā€™t show up in red) but thereā€™s just nothing there :frowning:
cards:
  - text: text goes here
    type: 'custom:text-divider-row'
  - cards:
      blaba....
Couldnā€™t figure out the formating above but the spacing is correct in real life.
I canā€™t seem to find any errors in the homeassistant log- could errors end up somewhere else?
Thanks for your time // Martin
Edit: it started working again for some unknown reason. Well, good enough for me.
Seems the transparent background issue has returned since updating to HA 12.4. Why canā€™t I make it transparent again? Thoughts?
Can confirm that the transparent background issue persists.
Changing the background-card-color: card-background-color: changes the background now instead of paper-card-background-color:.
Love this card to break up my mobile view using the Mushroom theme.
Looking for some help on the text background. It doesnā€™t quite match the background and looks to default to the card background colour.
Iā€™m struggling to figure out how to remove the entities box and not have the text background the pure white:
Here is the code Iā€™m using:
type: entities
card_mod:
  style: |
    ha-card {
      background: none;
      box-shadow: none;
      card-background-color: '#FAFAFA';
entities:
  - type: custom:text-divider-row
    text: Text
Iā€™ve messed around with different values for card-background-color and also gave paper-card-background-color a go too. Iā€™ve tried HEX and RGBA colours. Seen a few posts trying to use just the text-divider-row card without the entities card but this seemed the best way to achieve the look by using card_mod. Thanks for any help!
Seems like a ā€œguessingā€ - no wonder it make take a lot of time and may not provide a positive result (((.
Each element has a set of supported CSS-properties, some of them may be assigned to supported variables.
We should not ā€œguessā€ - we should open the Code Inspector (or how is it called in a browser) and see what properties are used for an element.
Check this link.
Probably you need to give a transparent background to a label (see an example with ā€œbackground-colorā€).
If you got a lot of text-divider-row in your HA setup - then probably you should use a card-mod-theme for all text-divider-row instances with a corrected style.
IMHO the background for the label should be transparent w/o any card-modā€¦ But for now it could be a good workaround.
Good advice, thanks for the response! Always forget about the good old inspectorā€¦
That link is exactly what Iā€™m trying to achieve so what I have done is overwrite my block with the extract from that link:
However it isnā€™t updating the styling despite it showing the paint brush at the bottom.
Shall I uninstall and reinstall the card-mod addon?
UPDATE: Found a workable solution within the entities card styling:
type: entities
card_mod:
  style: |
    ha-card {
      background: none;
      box-shadow: none;
      --ha-card-background: #fafafa
entities:
    text: Rooms
Iā€™m now playing around with your suggestion of editing the theme rather than applying to every text-divider rowā€¦but it may not work as it would affect those entities cards Iā€™m not using with the text divider row. I will update if I figure it outā€¦
UPDATE 2: Definitely need to do something at the theme level as I need to have two different colours based on LIGHT or DARK modes.
Because you are trying to apply a card-mod style to a card which DOES NOT have a ha-card element.
Read docs for card-mod on GitHub.
The card is supposed to be used inside the Entities card - which DOES have a ha-card element , so the card-mod style may be applied.
This ā€œbrushā€ is not related to card-mod.
The card-mod style in the example you provided is not related to to styling the ā€œtext-divider-rowā€.
It MAY affect - nothing more.
Probably by this style you defined the ā€œ--ha-card-backgroundā€ variable (undefined by default) and this variable is used then by the ā€œtext-divider-rowā€.
What you really need is:
  1. Place the ā€œtext-divider-rowā€ inside Entities card (as it supposed to be used).
  2. Apply a card-mod style to the ā€œtext-divider-rowā€:
        text: modded
        card_mod:
          style:
In some cases you DO NOT need a custom theme to handle ā€œlight/dark modeā€.
Read this.
This is a great custom card which I use around my Lovelace to group information.
Currently is showing the line through the divider:
and I have it configured like:
   cards:
      - type: custom:vertical-stack-in-card
        title: Non-rechargeable batteries
        cards:
            text: Temperature Sensors
            cards: null
          - type: entities
            entities:
              - entity: sensor.living_room_temp_battery
                name: Living Room (Xiaomi)
                type: custom:bar-cardtype or paste code here
Iā€™ve gone through this thread but canā€™t seem to make it without the line again.
Any help is appreciated.
Thanks!
I found similar and its because it is an entities row item rather than a card in itself. It is designed to be used within the Entities card. I used card-mod to hide the Entities card background and then adjust the background of the Text Divider elementā€¦
Thanks @BlackCatPeanut! Iā€™ll follow that path - a few things have to be changedā€¦ :thinking:
Hi @BlackCatPeanut
so following the info and links (thanks @Ildar_Gabdullin ) Iā€™ve managed to end in something like this:
With code:
    cards:
      - type: entities
        entities:
            text: strikethrough
            card_mod:
              style: |
                .text-divider {
                .text-divider span {
                  color: orange !important;
                  background-color: none !important;
                  padding-left: 32px !important;
                  padding-right: 32px !important;
Which is still with the line dividing the text.Should be a simple formatting line - can anyone help on this?
Thanks!
Can you paste your code here, please?
Iā€™ve gone in a different direction for this card so unfortunately no longer use it as I described before. Sorry :frowning:
ok, so then could you tell us your method how to get a divider with a title without all the problems we are discussing here? Thank you
I opened the .js file and hardcoded the background color of my theme. Sure, I could put a var there, but I cannot find what variable is the background from the theme.yaml file. Adding the color in the format #07090e to span worked for me.
        color: var(--divider-color);
        font-size: var(--font-size);
        background: #07090e;
        padding: 1px 1em;
No, it does not work. I also tried to add
style: |
    background: #07090e !important;
below the type: custom:text-divider-row but the result still inherit something from somewhere and I cannot find where. The inherrited properties are:
    background: var(--background);
    padding: 1px 1em;
What do you want to achieve by card-mod?
