I tried lookin for an ansewer in all above posts, but was unable to find one.
Is it possible to override the action behaviour of a chip?
I tried the below code, but nothing happens when I click the chip:
Hello!
I have a problem with some tap/hold actions in cards.
If i tap on card or icon - toggle action works, but if i tap on name - toggle action doesnāt work.
Popup also doesnāt work. Please, help.
One of my card:
Uncaught button-card.js?hacstag=146194325342:425
ButtonCardJSTemplateError: SyntaxError: Unexpected token 'return' in 'var action = variables.ulm_name_tap_action;
if (action == 'adaptive'){
return {
'opti...'
at new Function (<anonymous>)
at Je._evalTemplate (button-card.js?hacstag=146194325342:425:9295)
at Je._getTemplateOrValue (button-card.js?hacstag=146194325342:425:9964)
at button-card.js?hacstag=146194325342:547:3849
at Array.forEach (<anonymous>)
at n (button-card.js?hacstag=146194325342:547:3791)
at Je._evalActions (button-card.js?hacstag=146194325342:547:3910)
at Je._handleTap (button-card.js?hacstag=146194325342:547:4643)
at Je._handleAction (button-card.js?hacstag=146194325342:547:4488)
at N.handleEvent (button-card.js?hacstag=146194325342:1:9239)
EDIT: Please ignore everything below, it seems that I still changed something in custom_card_esh_welcome.yaml (but I donāt remember that ). I just copy/pasted content of custom_card_esh_welcome.yaml from github to my local file again and weather popup is working as expected:
Hi guys. I just started with Minimalist, sorry if this already been asked, but this thread is hugeā¦ I followed Lewisās tut on YT (Everythingsmarthome), so basically, I have very similar conf as him for now.
And template, i.e. custom_card_esh_welcome.yaml is unmodified.
If I click on weather inside HOME:
I get following (empty) popup:
I believe this is normal behavior and that something else needs to be setup, but since I just started, could someone point me in right direction what file should be edited and where, in order to get something useful in popup. E.g. Weather Popup , or if this isnāt possible, then at least default HA Weather Forecast card.
I understand how would I accomplish Weather Popup if this would be weather card, but Iām not certain where to make edits in case of this custom card where weather is just one part of it.
Hey guys,
Quick question, Iām a little new to this, but Iām loving learning all about CSS!
I recently made a new page for my dashboard, but wanted to add a few color variables, as there werenāt any pre-made that I liked for my application.
My desktop runs the āminimalist-desktopā theme, so I went to that .yaml file, and found all the colors available! So, I added one, refreshed the system, and it worked beautifully.
However, now all my edits are gone from that file, and thatās fine because there werenāt many made. But I seem to have made a mistake, and things were overwritten?
Is there a way to keep my additions to this file from being overwritten? Or should I create a new āthemeā file with my own colors, and just copy everything else from āminimalist-desktopā?
Iāve noticed with the Nest integration, 1. if you try to tap the + or - too many times in succession (in other words, more than twice in a row or so) you will get an error message that it cannot accept any more commands because there are too many at once - and 2. holding down the button does does not increment it eitherā¦
I have a suggestion to resolve bothā¦ (well definately the second but maybe not the first so much)ā¦
Sorry I donāt have the time to try to implement this right now, but can someone try the changes I suggest below to the code?
If the command to the thermostat is just a ā+1ā or ā-1ā for the button presses, then change each command going to the thermostat to change the temperature to the exact corresponding number instead, because -
For #1 above, update the logic such that:
When the user is rapidly tapping the button every command is NOT sent to the thermostat, but only the first tap would immediately send a command to the thermostat, and then queue up the thermostat commands generated until the tapping stops, then immediately send the command for the last tap - and empty the rest of the queue, not sending the other unnecessary commands (unless the same logic can be applied without using a queue, maybe just a counter to keep track of the exact temperature to send for the last tap)?
For #2 above, update the logic such that:
REMOVE any code that sends a message to the thermostat when the button is pressed (donāt freak, just bear with me here)!
Send the message to the thermostat for the temperature change only once when you lift your finger off the button instead - because the change might be more than one degree, BECAUSE -
When you hold your finger down on the button, it would increment the number once for every 1/3 or 1/2 of a second while it is still held downā¦!!! (If you want to get really fancy, it would increment faster if you hold it down longer, but I donāt think that applies here as it might actually be counterproductive as the range of numbers is pretty smallā¦)
How can I get the popup that would show a MUCH more elegant circle which allows me to drag the one or two points shown there? I thought I saw that in one of the cards but it was a different thermostat card that doesnāt work for my Nest integration I donāt thinkā¦?
For Nest, set up (spin up) a Homebridge container in docker and add the Next integration to that. Then add Homebridge to HA via the HomeKit integration. I found it to be really stable that way, even with rapid taps.
So basically Homebridge (used to make non-HomeKit compatible IoT devices work with HomeKit) is what will communicate with Nestās servers; then Home Assistant just chats with Homebridge.
