Hey, can anyone aim me how to create additional dashboard for tablet? current one only work for phones.
I guess you just create a new ā¦/ui_lovelace_minimalist/dashboard/ui-lovelace.yaml and include new views and start overā¦ If thatās what you meant?
button_card_templates: !include_dir_merge_named "../../custom_components/ui_lovelace_minimalist/__ui_minimalist__/ulm_templates/"
title: "Minimalist"
background: "var(--background-image)"
- !include views/home2.yaml
- !include views/kitchen2.yaml
thank you I will try it
If you want to add a second standard dashboard you can following the instructions outlined on the Wiki
https://ui-lovelace-minimalist.github.io/UI/setup/customizing/#add-multiple-dashboards
You can want to consider using the adaptive dashboard for the tablet
https://ui-lovelace-minimalist.github.io/UI/setup/adaptive_dash/#setup
Nobody has tried restriction card? Would appreciate help on this, might come handy for others to protect a button.
Hey guys, I just installed this theme/dashboard, but the cards in my dashboard seem a little bit odd in my cellphone, there are no colors and all of the borders are visible
What could possibly be wrong?
mb not the right theme?
looks like default theme
Thatās it. My home assistant app theme was set to the default theme.
Thanks.
its the same like views:
- !include views/home.yaml
Hi!
I would like to use some custom-cards from this theme in my old standard lovelace dashboard.
Is there an easy way to do it?
how can i use the simple-thermostat in the UIM?
How can i use other Plugin from HACS ?
Plugin Link here in the board: Lovelace: Simple thermostat card
Error: Custom element doesnāt exist: simple-thermostat.
yaml code:
- type: horizontal-stack
cards:
- type: "custom:simple-thermostat"
entity: climate.mainhallway_hmipbwth_thermostat
I think he has a problem with the type: type: "custom:simple-thermostat"
he searching in the folder: ui_lovelace_minimalist/custom_cards/
after i reload the hacs plugin in store, it works fine
Iām trying to get a popup from an entity on the card_room template. Code used below for ulm_custom_popup works fine on a card_power_outlet, but not on card_room. The popup action seems to be triggered, but the popup itself doesnāt show. Any idea what Iām doing wrong here?
- type: custom:button-card
template:
- card_room
entity: sensor.logeerkamer_temperature
icon: mdi:bed
variables:
label_use_temperature: true
label_use_brightness: false
entity_1:
entity_id: light.lidl_color_light_m1
tap_action:
action: popup
ulm_custom_popup:
template: popup_power_outlet_stats
entity: switch.shellyplug_media
popup_variables:
ulm_popup_power_outlet_sensor1: sensor.shellyplug_media_energy
ulm_popup_power_outlet_sensor2: sensor.shellyplug_media_power
ulm_popup_power_outlet_graph_sensor: sensor.shellyplug_media_energy
ulm_popup_power_outlet_entity: switch.shellyplug_media
Other question: is there a way to call a custom popup for instance by calling a service?
Ah, so then you would lose the merging function?
yes, the right way like this:
- !include views/folder/file1.yaml
- !include views/folder/file2.yaml
I use browser mod for popups. They work perfectly.
you can then use another yaml to put cards in the popup.
e.g.:
I have a button card for my desk which has a double switch:
This is still a WIP, but the basic worksā¦
The code for this button is:
- type: 'custom:button-card'
template:
- card_esh_room
entity: switch.office_m
tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.popup
title: "Office M"
content: !include 'repeaters/multi-switch.yaml'
On hold it will show me a popup:
All thatās in the āmulti-switch.yamlā is:
type: custom:stack-in-card
cards:
# ENTERTAINMENT AREA #
- type: entities
entities:
- entity: 'switch.office_m'
icon: mdi:television-speaker
card_mod:
style: |
ha-card {
margin: 0em 1em 0em 1em;
- type: entities
entities:
- entity: 'switch.office_m_socket_socket_1'
icon: mdi:desktop-tower
- type: divider
- entity: 'switch.office_m_socket_socket_2'
icon: mdi:speaker
card_mod:
style: |
ha-card {
background: var(--secondary-background-color) !important;
border-radius: 1em !important;
box-shadow: 0 5px 5px -3px rgba(0,0,0,.5) !important;
margin: 1em;
But then youāll get a huge list of template includes, rather than just importing the folders and merging the files together.
For me that takes away from the āautomationā partā¦
Also, the include for the button_card_templates (as it is now) is the correct way of importing them as stated hereā¦
Iām just trying to figure out how to add my own templates as well, by including another folder
Just put your own templates into the minimalist custom cards folder and than the integration will handle it all for you
Somehow I didnāt realise that these are also templatesā¦
Thanks!
Hello! I hope itās ok to ask what I would need to do if I just wanted to create the fabulous room card? The whole minimalist āthemeā is a bit too much for me but I would really love be having the room card!
