Thank you for the very detailed feedback. I really appreciate that
I changed the background in the yaml file to test it. (as mentioned Iām currently doing some trial and error. It does not really fit to this setup. I just wanted to know if I can change it in that way)
I will proceed reading in this thread and starting my test build.
Again, thank you
Hmmm, doesnāt look rightā¦ Just to be sure weāre on the same page, weāre talking about the yellowish background of the card, the slider color and the icon background?
What comes now is just guessing work I assume, some css definitions wonāt get handled by the browser. This would be my first guess, as the css code that is responsible for making these colours is coming from two separate things, one from this āthemeā, but the slider color is controlled by the slider-card. If two sources show the same āwrongā behaviour, it is likely that it has something to do with the one common point, the browser.
Could you please check, if another browser on the same tablet shows the same behaviour? Or the HA companion app? If they show the wrong colors as well, we have nailed it down to the tablet, otherwise to FKB.
Letās see where we get with this and then look further.
Took a little longer, sorry, but I canāt pinpoint anything down. I rebuild the same setup as described in the post above, with no problems. The language variables get loaded, I can change them around by deleting one *.yaml file and adding another one back, the languages changeā¦
That leaves me with the assumption, that something else is causing this. Not the best outcome, as debugging without reproducing an error is a tideous task (at least for you, as you need to try different things mostly with no outcome ).
If thatās ok for you, Iād suggest we do some further debugging via Github, because this could end in a lot of writing back and forth. At Github we could isolate that from the ānormalā things here in this thread, and others would still be able to follow that process and join in to help.
As I said, if itās ok for you, just open an issue at the main repository here, Iāll jump in right away. If not, itās not a problem at all, just let me know and we do it here in this thread.
Thanks your config really helped me understand layout card, for some reason I couldnāt ever get it from the documentation
I did have one more question for some reason when I have a picture elements card in my yaml it takes up a lot of the space unless I put a whole bunch of gap cards - but then there are heaps of gaps any tips?
Hey, @clemalex
i love your mod of the cover card with the favorite position. Iāve managed to implement it for my standard covers.
But as i am not speaking french and as I have no somfy covers I want to ask if it is possible to create a template based on the standard minimalistic cover card only with additional button for the favorite position?
I tried to but I successfully failed
Would really appreciate that!
My UI is shaping up nicely thanks to this āthemeā, really love how customisable it is. Iāve done two custom cards already, one with a calendar and one chip that changes symbol based on if someone is home, all away or night mode is on.
Two things I really would want to see is:
1, Conditional cards. Like for example when itās starting to get late, show both a new title and a card with night mode boolean. Or if media player is playing, show that media player and itās controls. I used DBuit Homekit-panel-card before and heās got that working, maybe could get some inspiration on how to make it happen here to?
2, A filler card so you could get one small entry instead of a long one. For example if I have an uneven amount of lights, instead of one of them cards becoming a long, full width one you could ad that card + a filler card so it getās symmetrical with the other cards. (Hope you get what I mean here, it was harder to explain then what I realised). I tried making one but making an empty card like did not fill it so that did not work
On the left the original template. On the right side the template with your code from the post above.
Maybe I did some mistakes as I copied itā¦
I would like to have the German version and the percentage. (and the colorization of the icon).
I just copied the whole code of your post into the templates without any adaptions. (i guess there could be the issue)
Absolutely! Itās not done completely, I want to make it a little simpler but here it is in itās first draft. If anyone look at this and know how to make it simpler, both the sensor and the card I would appreciate the feedback as Iām not a coder. This is just a mashup with what Iāve learned a long the way.
Card
Under the operator you can change the value where it changes from greyed out to blue āactiveā, itās set to 7 now and under custom_fields you can set when the ! notification badge should show up, itās set to 3.
Itās really just a copy paste from other cards, so maybe one could do this better? Is there any way to like make the card handle all the calulations without the sensor below?
Sensor
This sensor uses the calendar integration. I have my iCloud calendar synced with HA via Caldav. The first template shows the next event name, in this example itās a birthday calendar and I use a emoji in my calendar so I needed to remove that and the space between and also set a limit on how many letters to show.
Then there is two attributes in this sensor. First one days_text is in Swedish and if the events is today, tomorrow or the day after that it shows in text, if the event is more days away it says āIn x daysā. And this is used as the secondary label in the card.
Third attribute is simply how many days is left so I could use it in the card to tell when to turn it from grey to blue (active) and when to display the notification badge.
Edit: I donāt use sonar or Plex but if you could pull some data when a show is released you should be able to make it work with that as well.
I have that on my plate, to include and update all cards from this thread, so they find their way into the repo. Either as a custom-card or as an addition into the main template file. So in your case @sorted, Iād suggest to wait a bit, these cards will be available in the near future.
The problem with the code you copied is, it was written before we ordered the repo. That means there are old variables that arenāt filled with values, eg. the background from the icon or the language variables. These need to be updated.
Iām on it If you find some time, you know your help is always welcome, in the meantime Iām just updating your cards and add them as custom-cards.
Hi @paddy0174
Can I make a suggestion on one of the cards in this thread?
When clicking on the Light Name, in this case āBellaā, bring up the more-info pop-up.
Or the same action, but when clicking on the circular light icon on the left of the Light Name, in this case āBellaā.
Yes the yellow background, the slider and the icon. I just tested it on the tablet with Chrome and I have the same issue so it might not be the browserā¦ so I guess the tablet is the problem?? But how/why? And what can I do to solve it? How can the tablet block parts of the CSS?
Welcome back Andreas! Youāre always welcome to make suggestions!
The idea Iām right now working with, was to harmonize all cards (where possible), so all cards work with these actions:
tap toggle entity
double tap special function(s) (if needed) only on some cards
long tap more-info dialog (long tap meaning press and hold a while)
Would that be an alternative for you? As we (in this case HA itself) now do a mobile first approach, it might be better with different actions (opposed to different clicking locations) on smaller screens, but Iām open to all suggestions. I like the idea, that these tap actions are kind of harmonized, but thatās just my inner Monk Let me know what you (and others as well) think!
