Paddy, how about a vertical volume controler?
Kinda likeā¦ Turning the light slider 90 degreesā¦?
Has anyone of you already managed to integrate a conditional display of chips?
When I try to do this, the individual chips within conditional cards are always very far apart.
I have also found an older comment about this here:
Lovelace UI ā¢ Minimalist - Share your Projects! - Home Assistant Community (home-assistant.io)
Unfortunately, I donāt get it displayed that way and itās probably not a very elegant solution in general.
First of all, thanks for that wonderful āthemeā. The UI is so much butter as the standard lovelace one!
As Iām starting to build up my frontend I wanted to use more chips and tried to create a ānightmode_stateā chip but i keep getting errors and I really donāt know why?
thats the error:
Thatās my file structure and code:
### CHIP NIGHTMODE ###
chip_nightmode_state:
template: chip_nightmode_state
triggers_update:
- "[[[ variables.ulm_chip_nightmode_entity ]]]"
label: |
var icon = '';
if (states[variables.ulm_chip_nightmode_entity].state == 'on'){
var icon = 'š';
} else if(states[variables.ulm_chip_nightmode_entity].state == 'off'){
var icon = 'ā«';
return icon;
and in the dashboard:
button_card_templates: !include_dir_merge_named minimalist-templates/
- title: Minimalist
cards:
- type: horizontal-stack
cards:
- type: custom:button-card
template: edge
template: chip_temperature
variables:
ulm_chip_humidity_outside: sensor.draussen_2
ulm_chip_temperature_outside: sensor.draussen
ulm_chip_temperature_weather: weather.weatherbit_grafelfing
template: edge
variables:
ulm_chip_nightmode_entity: input_boolean.nightmode
template: edge
Any help would be greatly appreciated
thanks!
Flave
you missed a ā}ā at the end of
var icon = 'ā«';
Also you referenced the template chip_nightmode_state to itself
You should also use a ātriggers_update: all
ā instead of passing a specific entity via javacripts.
See here: triggers_update
doesnāt accept javascript templates Ā· Issue #35 Ā· UI-Lovelace-Minimalist/UI (github.com)
You have created an infinite loop because your chip_nightmode_state
depends on chip_nightmode_state
You should change the following and everything should work
template: chips # <- here is your error
triggers_update:
Edit: the changes by @CM000n should also be fixed
Btw, something to consider (but it is not wrong by you) is that you have created a custom card specifically for you night-mode. But you pass the night-mode entity as a variable to the card. Which is kind of redundant because I assume reuse in your HA configuration will not happen
The card could be reduced to:
template: chips
label: |
var icon = '';
if (states['input_boolean.nightmode'].state == 'on') {
var icon = 'š';
} else if(states['input_boolean.nightmode'].state == 'off') {
var icon = 'ā«';
return icon;
And then in your dashboard:
template: edge
template: edge
@CM000n @bms wow that was super fast! That did the trick. Thanks!
I followed the wiki and there it says the template name should be changed (what i did). That should be fixed.
Using the variable is redundant thatās true, but that way the card can be used by other more easily.
Also building new chips is probably easier.
Aah yes, I see where the confusion came from.
If you want to create a new card starting from the chip_temperature (for example)
paddy_chip_temperature: # <- this should be the name of your new card
template: chip_temperature # <- this should be name of the card you try to extend
Hope this makes things a little more clear.
ah now i get it. Your explanation makes more sense and should be added to the wiki
Hello to all,
Congratulations for the work, this theme is fantastic and I am slowly trying to implement it.
Has anyone thought of a custom card for the vacuum cleaner?
This āAirCondition Cardā could be helpful: Custom-cards list - UI-Lovelace-Minimalist
But you would have to customize it (look here: Changing template - UI-Lovelace-Minimalist
Iām afraid this has already been asked before but I could not find it in the thread.
How can i make the display of the chip conditional?
And two additional questions:
- And is there any best practice for getting a nice desktop view (meaning one horizontal stack is really on row) other than using grid layout?
- how to format the temperature chip in a way that if the temp is below zero the temp-string will be displayed āblueā?
Look for some inspirations here: https://github.com/CM000n/homeassistant/blob/d2463560bd7519f84190f9cdb6532415a77d4a10/lovelace-minimalist.yaml
thanks - ok so will have to use the grid-layout.
Hello!
Iām struggling with how to place the chips.
Iām currently have a number of chips (5 or 6), and Iām placing them with a horizontal-stack, but of course, it is only placing them in one row.
Do you know guys a way of placing the chips as in the example here?
Thanks!
this could be interesting: GitHub - bramkragten/swipe-card: Card that allows you to swipe throught multiple cards for Home Assistant Lovelace
and here (another method): Lovelace: Swiper card
For layouting grids: https://grid.layoutit.com
Look for some inspirations here: homeassistant/lovelace-minimalist.yaml at d2463560bd7519f84190f9cdb6532415a77d4a10 Ā· CM000n/homeassistant Ā· GitHub
Well, I was checking at the config that you sent me, and it seems that they are not using the layout that I was mentioning, and the Slider card is not working as expected.
Iāll have to go through a different path i guess.
Thanks!
Start with a vertical stack
Then add one horizontal stack per row =]
Iām trying to figure out how to use a conditional card in order to only show buttons when they are needed. But i always get an error. Would be happy if anyone can help.
error:
code:
cards:
template: edge
- type: conditional
conditions:
- entity: switch.eg_kuche_steckdose_spulnische_rechts_espressomaschine
state: 'on'
card:
type: 'custom:button-card'
template: card_power_outlet
variables:
ulm_card_power_outlet_consumption_sensor: sensor.tagesstromverbrauch_espressomaschine
entity: group.espresso
template: edge
Flave
ācard:ā Should be on the same vertical line as āconditions:ā. Otherwise it thinks your are adding the card as a condition.
cards:
template: edge
- type: conditional
conditions:
state: 'on'
card:
variables:
template: edge
