Great! Do I have to include this in the raw editor of the Lovelace dashboard itself?
is it perhaps possible to desribe what I have to do and edit?
(Sorry for the questions, this is my first more advanced custom theme.)
they are not hosted but if you want any code just tell me which one and i will post
For now it does only work if you dashboard is in yaml mode: Multiple Dashboards - Home Assistant
This is sadly not possible through the raw-editor. You can add new dashboards to your configuration.yaml file. See example underneath. Or edit the file which comes with the installation and add the cards you need to it.
lovelace:
mode: storage
# Add yaml dashboards
dashboards:
lovelace-minimalist-mobile:
mode: yaml
title: Minimalist Mobile
icon: mdi:flower
show_in_sidebar: true
filename: ui_lovelace_minimalist/dashboard/ui-lovelace-mobile.yaml
Than you have to create a yaml file in this folder:
And make sure the name of your file is the same as in your configuration.yaml file
PS: you could also send me a PM so I can help you a bit in Dutch
thanks, message sent your way!
This really helped me out! Thank you for your help and time.
Bedankt!
Damn, I somehow missed the part where they should be stored in /config/ui_lovelace_minimalist/custom_cards
, my bad.
A note, it should be stated that even if you are only creating dashboards in YAML that you still need to do the integration install or the custom_cards
wonāt be appropriately used, and you wont have the UI_LOVELACE_MINIMALIST
option in the YAML Reloading
section. I didnāt add the integration at first as I figured since I wasnāt editing the in the UI editor I didnāt need to. Just something to clarify in the documentation in the future
Thanks!
Hi, I installed this ui, but my boxes arenāt curved and just doesnāt look like they should
Looks like you havenāt selected the right theme, you need to choose one of the minimalist themes in your user settings
Oh, thanks, it works now
I installed this and necessary addons manually. I dont use HACS. Running Home Assistant 2022.3.7 latest version. Around 3-4 update ago popup cards were working however for the past ~2 weeks I couldnāt make popup cards work. Does anybody have an idea?
I tried removing everything and installed again but still they wont workā¦
Hello! The āchip_presence_detectionā chip is not clickable at the moment. Is it possible to change this, so we can click on the chip (and navigate to a persons page?)
Thank you!
Hi, how to make settings button on this? I canāt open settings when using this theme on mobile.
You can still open settings pulling from the left side, but to get the navigation bar button back you must edit theme script.
Hi All,
someone has the same problem as me, while scrolling the UI dashboard can happens very often that inadvertently I change the brightness of the light card. Is there a way to avoid it?
I tried and it doesnāt show the menu
Hi All,
Did the v0.0.7 Hotfix solve the light and light slider issue for anybody?
I still canāt get lights to appear again, so trying to understand if its an issue my end.
Thanks,
How is it possible to implement custom popup cards? Any hints or link to a documentation?
I do have some chips for number of switched on lights and number of open window. Would love to have a list of the lights/windows when clicking on the chips.
Edit: Looks like I just now stumbled upon a hintā¦ It seems to be possible using browser_mod and service: browser_mod.popup
Edit2: Way easier than what I expected . Just define a tap_action
on the chip:
tap_action:
action: "call-service"
service_data:
title: Popup example
card:
type: entities
entities:
- light.kitchen
Anyone doing conditional chips? I would like to only show the open windows chip if there are any open windows. It works as long as there is only a single conditional chip in hporizontal-stack. But as soon as there are multiple of them they start to jump around when they toggle and have large gaps in between.
No light switched on:
One light switched on:
As mentioned, I do have all the chips in a horizontal-stack. They are defined like this:
- type: conditional
conditions:
- entity: sensor.current_lights_on
state_not: "0"
card:
type: "custom:button-card"
template: chip_icon_state
variables:
ulm_chip_icon_state_icon: "š”"
ulm_chip_icon_state_entity: sensor.current_lights_on
Looks like it could be related to this post. But I couldnāt figure out what the proposed solution is:
Hi, I added this line to my dashboard config
- type: "custom:button-card"
template:
- card_media_player
entity: media_player.eshare_5545
variables:
ulm_card_media_player_enable_popup: true
But when I open the dashboard it doesnāt show up
imgur link
EDIT: Now this shows up
Look at your indentation
After variables:
you need always a tab, otherwise all defaults of the variables will be overridden causing it to be undefined.
template:
- card_media_player
variables:
