Itās not the first time that card has broken other cards. Itās happened at least once before.
How should the overflow work on mobile if a horizontal stack of cards is too wide? Iām just seeing scrolling and ideally I would like the cards to change size to fit the width of the screen.
For example I have 4 chip cards in a horizontal stack and they work fine on a bigger screen, but my phone it requires horizontal scrolling to see the last button.
Thanks!
I was wondering why my person card was in Polish ā¦
On a related noteā¦ anyone know how to adapt imswelās person card to a vertical layout (ie. text below image) with either card-mod or by modifying the card template?
I tried to modify the template to do so but I canāt get the little notification icon to keep its proper position on different devices.
Hello everyone, first off I just want to thank everyone that has help made this wonderful dashboard. When I saw it it was exactly what Iāve been looking for. Iām making some great progress but one thing I canāt seem to figure out is how to make additional views. Could someone so kindly help with this?
Didnāt pushed reply. Sorry if my answer is a bit messy Iām in a rush and only on my mobile. Trying later to edit it with proper yaml examples.
I solved this two days ago.
What I did was to create a new folder called āviewsā in the /config/ui-minimalist/ folder. Also you need to uncomment the include views line in your lovelace-ui.yaml in your dashboard folder
Each view needs to be a separate yaml file. To keep the views in the order you want, I would advise to put a number in front of the file name. For meint looks like this at the moment
Config
-- ui-lovelace-minimalist
-- views
-- 01_home
-- 02_bad
Itās wip for know as I try to figure a few things out first.
Hey, I noticed that my speedtest card is bad:
The icon is under the name of the test. Also download has not tap function, but upload does - it opens the entity history.
I am like this too
Awesome Lovelace UI !
Trying to set it up bot somehow the radius of the custom button, when using the template card_light, does not show up.
It does for other button-cards. Does anyone have clue?
Below my yaml part:
- type: "custom:button-card"
template: "card_light"
entity: light.spots_keuken
variables:
ulm_card_light_enable_slider: true
ulm_card_light_enable_color: true
ulm_card_light_force_background_color: true
ulm_card_light_enable_popup: true
And here is the result:
I wonder if this is related to the Weather Card. I was having the same issue. Have you tried removing it to see if that fixes it?
Only the card doesnāt have any effect, or should i then remove the entire HACS plugin?
Same styling appears on the default dashboard
See here. It is exactly the same issue I was having last night and I narrowed it down to the Weather card. I wasnāt sure if this was an issue with my instance, but to see your weather card keeping its border radius whilst the rest breaks makes me think it is a similar issue.
Not all of them break, the custom button with the template chip_power_consumption does have the radius.
Iāve done the following steps but no changes for the light.
Still on the path of removing more and more HACS front-end
- Removed the card from the dashboard yaml; No luck
- Removed the plugin simple-weather-card; No luck
- Restarted HA after removal; No luck
@Jroen @spamsal @xXkr13g3rXx check your user profile and select one of the minimalist themes. This will fix the issue
Hello guys, IĀ“ve a question. I think IĀ“m too silly to get it ^^
The docs for the room card mentions:
āThe temperature should be provide by either a temperature
or current_temperature
attribute or by the entity state.ā
- type: 'custom:button-card'
template:
- card_room
- red_no_state
entity: light.schlafzimmer_nachttischleuchte
icon: mdi:bed-king-outline
tap_action:
action: navigate
navigation_path: '/ui-lovelace-minimalist/bathroom'
variables:
label_use_temperature: true
label_use_brightness: false
entity_1:
entity_id: light.badezimmer
templates:
- yellow_on
- red_off
tap_action:
action: toggle
entity_2:
entity_id: switch.schlafzimmer_steckdose
templates:
- green_on
- red_off
tap_action:
action: toggle
entity_3:
templates:
- green_on
- red_off
tap_action:
action: toggle
entity_4:
entity_id: sensor.schlafzimmer_temperatur
templates:
- pink_on
tap_action:
action: toggle
Where do I have to put the temperature sensor? Within the variables? IĀ“ve tried it but without success.
Also things like āpink_onā, āred_offā and so on doesnĀ“t work. Can you help me? Currently my baby-bottle is on for example but there is no color highlighting.
Thanks Bas
First off check if you have the correct theme selected for the user you are currently logged in with (Sidebar ā User Icon ā Theme Dropdown). It should be one of the āminimalistā themes.
The colors should work once the correct theme is selected.
The temperature sensor has to be the entity for the room card. So in your case replace light.schlafzimmer_nachttischleuchte
with the sensor entity that provides the temperature.
You already set label_use_temperature
and label_use_brightness
correctly as I see it.
Hi i am currently testing out ulm.
And having a hard time using some of the cards.
The room card has no errors (if there is an error it tells me) but its not showing up in my ui?
Anyone have any clue what is wrong?
I copied what kr13g3r did and it worked
I also had to add 5 entities, in the welcome card, or it would just show me the first entity
- title: "Example View"
path: home
icon: "mdi:flower"
cards:
- type: "vertical-stack"
cards:
template: "card_welcome_scenes"
entity: input_boolean.ui_card
variables:
ulm_card_welcome_scenes_collapse: input_boolean.ui_card
ulm_weather: "weather.home"
entity_1:
entity_id: "scene.daytime"
icon: "mdi:weather-partly-cloudy"
color: "blue"
entity_2:
entity_id: "scene.cozy"
icon: "mdi:weather-night-partly-cloudy"
color: "yellow"
entity_3:
entity_id: "scene.bedtime"
icon: "mdi:bed"
color: "green"
entity_4:
entity_id: "scene.off"
icon: "mdi:bed"
color: "green"
entity_5:
icon: "mdi:bed"
color: "green"
template:
- "card_room"
- "yellow"
entity: sensor.netatmo_livingroom_livingroom_temperature
icon: "mdi:sofa-outline"
tap_action:
action: navigate
navigation_path: "view/livingroom"
variables:
@Flo.C thank you so much for your reply! Looks like I was on the right track. Sadly though Iām still having issues. When I try this it just puts the dashboard into edit mode. Clicking done doesnāt list anything
Hereās what Iāve done so far. I created the folder structure as you shown
Made the following changes to the ui-lovelace.yaml
I took all the yaml code from the ui-lovelace.yaml and added it to the 01_home.yaml
Any idea what Iām missing?
