🌻 Lovelace UI • Minimalist
its the work of @basbrus.
you can find it here: GitHub - basbruss/Minimalist-Dashboards: This is a showcase of my personal Minimalist UI dashboards.
Снимок экрана 2022-04-16 в 19.43.23|689x258
Someone found the battery level code in the card (person). I have been searching for 3 days and can’t find it, I would be very grateful if someone would share the code.
I checked here, but I didn’t find anything.!
I love your pollen card @ben93. Can you post your code please? Also which integration are you using?
Cannot figure out, why when the thermostat is ON, icon of Room Card with thermostat does not change to corresponding colour.
            entity_3:
              entity_id: climate.living_room
              templates:
                - red_on
                - blue_off
              tap_action:
                action: more-info
              icon: mdi:thermometer
Sorry I don´t get it to work. Can you post the snippet how you integrated it?
- type: horizontal-stack
            cards:
              - type: 'custom:button-card'
                template:
                  - card_room
                  - blue_no_state
                entity: sensor.schlafzimmer_temperatur
                label: '[[[ return["🌡️"] + states[sensor.schlafzimmer_temperature"].state +"°C  💧"+states["sensor.schlafzimmer_luftfeuchtigkeit"].state + "%"]]]'
                icon: mdi:bed-king-outline
That’s because the status is most likely “heat” (or heating, check dev console) and not “on”, which is what the red_on is looking for. You can copy the color files from the ULM directory to the custom ones and edit the status to look at the correct status.
That way I created red_heat and green_auto for my Tado thermostats.
Thanks, copy of color files did the trick. But have another problem, using generic thermostat, hvac_action is idle, but the state remains heat. Any ideas on this maybe ?
try here Minimalist-Dashboards/custom_design.yaml at 8e8d294cc8529fc859c4a2c8bbfadfcefa0fdd2b · basbruss/Minimalist-Dashboards · GitHub
card_person_custom:
hope to see your custom card soon.
edit: just try to add the battery code directly to the entity editor successfully
custom_fields:
  batt_info: |
        const battery = Math.round(states['sensor.lego_patio_door_sensor_battery'].state/1);
        const radius = 20.5; const circumference = radius * 2 * Math.PI;
        return `<svg viewBox="0 0 50 50"><circle cx="25" cy="25" r="${radius}"
        stroke="green" stroke-width="3" fill="none"
        style="transform: rotate(-90deg); transform-origin: 50% 50%;
        stroke-dasharray: ${circumference};
        stroke-dashoffset: ${circumference - battery / 100 * circumference};" />
        <text x="50%" y="54%" fill="var(--primary-text-color)" font-size="16" font-weight= "bold"
        text-anchor="middle" alignment-baseline="middle">
        ${battery}<tspan font-size="10">%</tspan></text></svg>`;} ]]]
styles:
  custom_fields:
    batt_info:
      - position: absolute
      - right: 6px
      - top: 6px
      - width: 25px
      - height: 25px
Sure. I think you should check the indentation.
Below you can find two room cards:
### ingresso e matrimoniale
        - type: "horizontal-stack"
          cards:
            - type: 'custom:button-card' ### ingresso
              template:
                - card_room
                - blue_no_state
              entity: sensor.perceived_temp_int
              icon: mdi:door
              label: '[[[ return["🌡️"] + states["sensor.perceived_temp_int"].state +"°C  💧"+states["sensor.netatmo_casa_interno_humidity"].state + "%"]]]'
              tap_action:
                action: navigate
                navigation_path: '/ui_lovelace_minimalist/ingresso'
              variables:
                label_use_temperature: true
                label_use_brightness: false
                entity_1:
                  entity_id: binary_sensor.0x00158d00076a6a22_contact
                  templates:
                    - green_on
                    - red_off
                  tap_action:
                    action: none
                entity_2:
                  entity_id: binary_sensor.0x00158d00075bf633_occupancy
                  templates:
                    - green_on
#                    - red_off
                  tap_action:
                    action: none
                entity_3:
                  entity_id: light.0x00178801034840a6
                  templates:
                    - yellow_on
    #                - green_on
    #                - red_off
                  tap_action:
                    action: toggle
                entity_4:
                  entity_id: sensor.perceived_temp_int
                  templates:
                    - green_on
#                    - red_off
                  tap_action:
                    action: none
            - type: 'custom:button-card' ### stanza matrimoniale
              template:
                - card_room
                - blue_no_state
              entity: sensor.0x00158d0004ab001b_temperature
              label: '[[[ return["🌡️"] + states["sensor.0x00158d0004ab001b_temperature"].state +"°C  💧"+states["sensor.0x00158d0004ab001b_humidity"].state + "%"]]]'
              tap_action:
                action: navigate
                navigation_path: '/ui_lovelace_minimalist/matrimoniale'
              variables:
                entity_1:
                  entity_id: switch.sonoff_10002a4003
                  templates:
                    - yellow_on
                  tap_action:
                    action: toggle
                entity_2:
                  entity_id: none
                  templates:
                    - green_on
                    - red_off
                  tap_action:
                    action: none
                entity_3:
                  entity_id: none
                  templates:
                    - yellow_on
    #                - green_on
    #                - red_off
                  tap_action:
                    action: none
                entity_4:
                  entity_id: none
                  templates:
                    - red_on
                  tap_action:
                    action: none
you might need to modify the color card you’re using. because the state is not ON, to work it should something like the code below. Of course, disregard the icon part.
state:
  - operator: template
    value: |
        return (entity.state != "off" && entity.attributes.hvac_action == "idle")
    icon: mdi:radiator-disabled
    styles:
      icon:
        - color: rgba(var(--color-blue),1)
      img_cell:
        - background-color: rgba(var(--color-blue),0.2)
      card:
        - background-color: rgba(var(--color-background-blue), var(--opacity-bg))
      label:
        - color: rgba(var(--color-blue-text),1)
      name:
    value: |
        return (entity.state != "off" && entity.attributes.hvac_action == "heating")
    icon: mdi:radiator
    styles:
      icon:
        - color: rgba(var(--color-pink),1)
      img_cell:
        - background-color: rgba(var(--color-pink),0.2)
      card:
        - background-color: rgba(var(--color-background-pink), var(--opacity-bg))
      label:
        - color: rgba(var(--color-pink-text),1)
      name:
Hi there,
Is it possible to change the font size for the titles of the Room Card to make it bigger? It just seem a bit too small…
add this
        styles:
          label:
          - font-size: 16px
Thank you! I was actually referring to the main titles, but found out that I can use the same but with ‘name’ instead of ‘label’ and worked fine. Thanks again!
Hello together,
i am not sure, if i understand something wrong or i make something wrong.
But i hope you can help me :wink:
My lovelace.yaml looks like
title: "UI Lovelace Minimalist"
theme: minimalist-desktop
Now i thougt, the theme which is selected is minimalist-desktop.
But that is not the Case.
So is my assumption wrong or do i make something wrong?
I am trying to open a popup (power outlet or light popup) on mobile but it doesn’t seem to work. Either in the mobile phone app… do you know why?
You need to go to your profile and also make sure that you have the right theme selected.
Ah okay, i thought with the Statement “Theme” for the relevant Dashboard means, that the UI knows which Theme for which Dashboard should be used
Yeah, I think this should be in an FAQ somewhere. I’ve seen this question been asked so many times (I also had the same issue when I first installed it).
v0.0.8 :rainbow_flag:
Changes
:bulb: Features
:sparkles: Code enhancements
:bug: Bug Fixes
:speech_balloon: Translations
:memo: Documentation
:heart: Thank you so much for helping out to keep this UI awesome
@AndyVRD, @EverythingSmartHome, @JackPoint, @LRvdLinden, @Misiu, @Neekster, @Tommatheussen, @basbruss, @finder39, @github-actions, @kauelima, @likeadoc, @rairulyle, @sildehoop, @skrynklarn, @stokkie90, @yagrasdemonde and rick.stokkingreef
You have to give some more information to help you. Otherwise it’s just purely guessing what could be wrong :wink:
There is also a solution on the wiki for the most common popup errors. FAQ - UI Lovelace Minimalist
How have you setup browser_mod? How have you tried to enable the popup in your ui-lovelace.yaml file? Did you followed the instructions on the wiki?
