@Truwolf:
Might you post the code, pls.
Hello, I was able to solve the issue āCustom element doesnāt existā on my homeassistant installation with renaming the following items:
- file from
config/www/weather-card-chart.js
toconfig/www/weather-chart-card.js
- ui.nabu.casa/config/lovelace/resources URL from
/local/weather-card-chart.js
to/local/weather-chart-card.js
- Card Configuration: type: from
custom:weather-card-chart
tocustom:weather-chart-card
I recommend checking that the spelling at all three places is as described in Github.
A restart might also be needed and the Card Configuration is a bit hackling.
Good luck
I just started using the card, looks great. I see that imperial units are supported. My temperatures show in F, but the wind speed and pressure show in metric. How do I change this?
Is there a way to change the font color on the chart? Iām semi-OK using Card Mod, but the elements for the font seem to be hidden behind the canvas. Iāve tried setting the color to : white but it doesnāt affect the font on the chart itself. Thanks.
EDIT. found the easy answer, changing the theme from light to dark swapped the chart labels colour.
Iām sure itās obvious but I canāt seem to find how to change the 24:00 hourly output to AM and PM?
I donāt think you can
Thanks for the quick response but I have noticed in serveral earlier posts in this thread that they have found a way to display a 12 hour clock:
I donāt see a configuration option for that in the card on github and there is only a zone setting in HA itself so I have no idea how they are forcing that.
I thought the same thing, I wonder if itās depended on the weather sensor that is being used? For example, Iām using Openweathermap. Perhaps one of the other ones outputs differently?
I donāt think so. the weather entity is pretty standard
Can someone tell me how the Forecast Options are implimented on this card? I canāt find an example and my attempts have proven to all be failuresā¦Iāve tried this:
- type: custom:weather-chart-card
entity: weather.openweathermap
show_main: false
show_attributes: false
forecast:
labels_font_size: 12
temperature1_color: rgba(132, 219, 253, 1.0)
temperature2_color: rgba(132, 209, 253, 1.0)
and Iāve tried this:
show_main: false
labels_font_size: 2
Neither seem to impact the style of the card?
Okā¦Well after digging into the source code, Iām pretty sure the following forecast options were not included in the current release, perhaps they got blown out during one of the merges?
temperature1_color
temperature2_color
labels_font_size
condition_icons
precipitation_color
All the other variables appear to be workingā¦although I havenāt tested āiconsā (custom icon path).
Here is the source code for the basic configuration. You can try to copy forecast
block and change it:
Hi There.
I am new to this card, and have tried to install it following all the instrunctions in this thread.
I still get the āCustom element doesnāt existā with the following card entry:
cards:
entity: weather.home
I am on 2022.4.6
Does anyone have some good ideas?
Update: It appearently solved itself over night. Now it works.
I would really like the option to turn off the temp labels on the graph as @scstraus had mentioned
Love this card! Is there a way to change the colour of the icons to a different theme variable? Mine seem to stay on primary-text-Color and have tried changing the code in the js without success
I am also finding I cannot change the colours using the below code and my variables which are in the format āR,G,Bā.
- type: "custom:weather-chart-card"
entity: weather.dark_sky
forecast:
temperature1_color: 'rgba(var(--color-red),1.0)'
temperature2_color: 'rgba(var(--color-green),1.0)'
precipitation_color: 'rgba(var(--color-blue),1.0)'
is that the latest version of weather-chart-card? Asking because in the repo I see those graphs with the noted numbers (which was reason for me not to upgradeā¦)
Like that it would be an option for me (if I could ditch the icon in the footer)
also, because I didnt like the new way of this nice card, I just managed to carve out the lines graphs from the old card, and put in in a stack with the adapted custom weather-card by Bram:
will get rid of the gap in between so they look like 1, and hide the ticks and vertical grid:
Thank you for a nice card! I wonder how and where I can specify how many days of forecast I want to specify (I would like less than 9 days)
