Yevgeniy
(Yevgeniy)
January 3, 2019, 3:31pm
1
Custom weather card for Lovelace:
Animated chart with weather forecast (maximum for 9 days);
Time of sunrise and sunset (optional);
Displays values from the temperature sensor instead of data from the forecast (optional).
Installation instructions can be found on the GitHub
eLRIC
January 5, 2019, 9:38am
2
Thanks a lot. It looks really cool in the dashboard
I’ve got latest version on github (raw js from the repo) and have some issue with the days (see ‘invalid date’ hereunder)
Any guess where I could have a look to correct it ?
Yevgeniy
(Yevgeniy)
January 5, 2019, 10:00am
3
Thanks for reporting. This is known issue and fix will be released soon.
jones
January 5, 2019, 3:53pm
4
Hey @Yevgeniy
Nice work. One Question. The custom updater does not recognitze your card. I’ve the following entry in my configuration.yaml:
custom_updater:
show_installable: False
track:
- cards
card_urls:
- https://raw.githubusercontent.com/sgttrs/lovelace-weather-card-chart/master/custom-updater.json
and in lovelace-ui.yaml:
resources:
- url: /local/custom-weather-card-chart.js?v=0.1
type: module
Can you help out?
Barmalej
(Barma Lej)
January 6, 2019, 6:01pm
5
Hi! Great Work!
Can you hourly forecast with hour make?
Можешь в почасовой прогноз часы добавить?
Yevgeniy
(Yevgeniy)
January 6, 2019, 7:18pm
6
Thanks. Sorry for late answer.
@eLRIC Issue fixed in v0.2.
@jones Custom updater works now.
@Barmalej I will try to add this feature in future releases.
jones
January 6, 2019, 7:31pm
7
@Yevgeniy Can you please update the README.md with the correct entry for custom_updater? I’ve entered the new URL to your custom_updater.json but it still doesn’t show up.
Yevgeniy
(Yevgeniy)
January 6, 2019, 8:10pm
8
Of course. I updated the instructions
eLRIC
January 6, 2019, 9:45pm
9
Still have some issue … strange one as different browsers show different issues …
FF 64.0
Chromium 72.x
Details on the OWM itself seems OK
Do I need to setup a specific OWM sensor on top of OWM config itself ?
Yevgeniy
(Yevgeniy)
January 7, 2019, 4:50am
10
@eLRIC Are you cleared cache in firefox?
eLRIC
January 7, 2019, 9:26pm
11
Should have done it before
Now, I have the same as in Chromium (same day without hour)
rsachoc
(Rsachoc)
January 8, 2019, 3:13am
12
Thanks for this, I’ve got this working and it’s a great replacement for the now defunct Yahoo weather. Is there a way I can display the daily values (i.e. Monday, Tuesday, etc) rather than the different times of the current day? Also, FYI, the graph values displays “NaN mm” for the rain amount when it’s 0 mm - perhaps it’s better to just say 0 mm? Also, can we change to imperial system i.e. inches of rain rather than metric i.e. mm?
edit if we’re sticking to the multiple values (every 3 hours) for the display, is there a way we could display Tues 3pm and so on, like the underlying Openweather data? Right now it just shows Tu Tu Tu?
Yevgeniy
(Yevgeniy)
January 9, 2019, 1:58pm
13
Thank you. It’s implemented in v0.2.1.
Yevgeniy
(Yevgeniy)
January 9, 2019, 2:00pm
14
v0.2.1
Add localisation to date ticks.
Tooltip: show zero if precipitation is null, support imperial units for precipitations
Please make sure you clear your browser’s cache after updating.
Romquenin
(Romquenin)
January 10, 2019, 1:31pm
15
Thanks for this card. I’m using weather.dark_sky with your card and instead of displaying the days it shows 9 hours. Any ideas on how to solve this.
- type: 'custom:weather-card-chart'
title: Météo
weather: weather.dark_sky
sun: sun.sun
Narfel
(Narf Elchen)
January 10, 2019, 5:55pm
16
Cool card! What is the green line in your chart and how do you get it?
Narfel
(Narf Elchen)
January 10, 2019, 6:21pm
17
To answer myself and the one above: the green line is night when you set the mode to daily
@Romquenin add mode: daily to your weather in configuration.yaml
Narfel
(Narf Elchen)
January 10, 2019, 8:10pm
19
suggestion: i flipped Line 166 in custom-weather-card-chart.js to
if (temperature < 0) {
return “-” + Math.round(temperature);
since most places are more likely to have positive degree values throughout the year. i miss the snow, though
Looks good. But I’m getting full white screen on my lovelace view when I put the following code:
title: Hava
sun: sun.sun
and here is the browser console log:
custom-weather-card-chart.js?v=0.1:145 Uncaught (in promise) TypeError: Cannot read property 'attributes' of null
at HTMLElement.set hass [as hass] (custom-weather-card-chart.js?v=0.1:145)
any advice?
switched to openweather, problem solved
