Lovelace Windrose Card
Released version 1.11.4
Fixes:
  • Text position error on Safari/MacOS/iOS, Tspan was added by the SVG library, causing padding issues.
I had noticed that S cardinal is being cut off by the box padding / boundary and still present on 1.11.4 Chrome
Edit 1: The compass card is now history!
I can reproduce this only in a Sections view. You are also using the sections view?
Need to investigate this one. Can you open an issue in GitHub?
Thanks.
Released version 1.11.5
  • Entity check code, revert to previous method.
The other method seams to fail for some entities.
Hmm where is my mistake? My data comes from weather underground
grafik
Some special entity config required for the WindRoseCard?
The same Entity works in the compass card:
grafik
Config should be something like this:
wind_direction_entity:
  entity: sensor.wind_direction
  direction_letters: NOZWX
  use_statistics: false
  direction_compensation: 0
Released version 1.11.6
Fixes:
  • Margin calculation when speedbars are hidden. Fixes #97
  • Background image position fixed when using longer cardinal direction labels.
  • Small fix in measurement matching
Fantastic card. I’m starting to feel like an idiot but I just can’t seem to get the background_image right. How is this parameter supposed to work, because whatever path I try all I get is this image:
Currently I have it working like this:
background_image: /hacsfiles/lovelace-windrose-card/bg.png
I put the image next to the windrose javascript file, downloaded bij HACS.
It should be a square image file.
Release version 1.11.7
Fixes:
  • Initial cardinal direction letters configuration when adding card now works. Fixes #101
