No problem, happy to help. More information on all that type of information can be found Here
Blacky ![]()
Blacky ![]()
Have a brew on me too! The only thing I can think of is having a sensor we can check from elsewhere that is just true/false to indicate whether there is currently a battery with low charge. Then I can put something on the homepage to remind me if I havenāt looked at the notifications. Just an idea. Thanks for the blueprint!
Thank you for this Blueprint, Would be cool if we could get the batterys added to a To-Do list so we know to replace them or order more. Then when its done we can check it off the list.
Cheers. Also the ability to ignore āunavailableā ones in the check. I have a couple of sensors that drop out and back in from time to time as theyāre on the edge of wifi range
Stay Charged, Stay Smart! Customize it your way and letās automate your battery maintenance! ![]()
New Feature ![]()
If you would like to include your battery type in your notification then Click Here on how to do this. Example below we added in (CR20232) but you could have (4 x AAA) or (Rechargeable) or just a separate list that relates to your device it is totally up to you.
If you like this blueprint? Consider hitting the
button in the top post ![]()
If you like my blueprints, and would like to show your support or just say thank you? Click Here ![]()
Enjoy
Blacky ![]()
If you are on version 1.7 recommend update without delay.
Bugs Fixes ![]()
Enjoy
Blacky ![]()
Hello:
Thank you for your Blueprint. I reviewed the different options above and not sure I understand some of the flow.
So, I would like to send a separate notification via pushover (which I have installed). But I would like the notification to be sent if any device has a low battery. In other words poll all batteries rather than a specific one and send a notification with that device name with low battery. Essentially same as the blueprint works in the easy notification section.
Never mind. Figured it out.
Fantastic blueprint, very well documented and easy to use!
I was wondering if it would be possible to have an item per sensor added to the to-do list. In that way, they can be marked as completed individually.
Another interesting thing to be considered (maybe similar to what @ghostridernrw40 mentioned about the ātoo little chargeā) would be to include two thresholds. One for a simple warning (say 20%, when there is no need yet to replace the battery, but provides time to check if replacements need to be bought; this might not need to be added to the to-do list), and then another one for a critical warning (say 5%, a replacement is required now and this should be added to the to-do list). I tried duplicating the blueprint and sending different messages and options about the to-do list, but the below 5% sensors are reported twice, once as a critical warning and another as a simple warning.
Thanks!
No you will just need to edit the To-Do list removing the ones you have done until it is all done.
I will not matter⦠I know what you are trying to do but lets think of the logic. If the battery is below 20% then when it runs it reposts the level. So if you have a individual setting that report batteries below 20% first and then another one below 5% second then every time it runs it will always be below 20%
You will just have to put 20% and then when you get the notification look for the ones reporting below 5% and replace them.
If you add it to the To-Do list then when you get a confirmation it has been done, click on it as it will take you to your To-Do task. Then edit it removing the ones above 20%.
I not sure how critical or how fast your batteries go flat but if you set 5% like I do you have time to get batteries and replace them. If your batteries are critical then try using the āBattery Sensors - Custom Groupā and add the critical faster discharging batteries in there and set a higher reporting level of say 20%. Then you have more time and is why it was added as a feature. Remember to exclude the batteries used in āBattery Sensors - Custom Groupā so you dont get 2 reports of the same battery. Then make sure you enable custom group.
Let us know how you go.
Blacky ![]()
Hello:
As per my previous post, I am using pushover as my second notification to report battery levels of all devices below a certain level at a predetermined time everyday.
However, I am still receiving a notification at the predetermined time every day even though i have no devices below the predetermined level. So, no devices are displaying with the set battery level. I am using the {{all_sensors}} command
Is there a way to set a condition just for the pushover notification to not have a notification sent at the predetermined time if no device meet the battery level?
Yep it is in the FAQ. Look at item 5, 6 & 7
Q: How do I use the sensors in custom actions?
A: Please Click Here
Blacky ![]()
Figured it out. Thank you.
Nice blueprint! Iām testing right now.
Would it be possible to display the information on a Markdown card?
You would probably have to try this through custom actions.
Blacky ![]()
