Normally HA will see âtrueâ as âonâ and that is already added. Please check this and make sure you have the correct settings.
If this is not the case then could you please provide a screen shot of your entity from within the developer tools and could you also please provide us your YAML of the automation? This YAML code are the settings you have selected in the automation so I can help. To do this go into your automation, top right 3 dots, Edit in YAML, copy all the code, come back to the forum and in your reply at the top tool bar click on â</>â and paste code in there.
I think I may have found a bug in the TODO description when running with confirmation disabled. When running with a custom group only, my TODO task description was empty.
Looking at your gist, I think you want this line
Yep you sure have. I will fix it⊠thanks for the heads up.
I will look at it
Again thanks for the heads up letting me know.
EDIT: Home Assistant has a bug in the to-do list. I am waiting for them to fix this before I can fix the blueprint. All my to-do list are gone and I have errors. I have logged a bug report with HA.
Just transitioning from my NodeRED automations to the HA ones when I found this awesome blueprint. However I could not figure out if there is an option to use wildcards to ignore things. I am running battery nodes as an integration but would love to ignore all of the sensors from their and everything not reporting numbers. But rather than manually adding each of the devices to the ignore list, is it possible to use wildcards here as well? If so, how is this actually done? Thanks!
Iâm trying to send emails with this. From the Custom actions section, it always send emails if there is a low battery or not. Perhaps have a checkbox for performing an action if the âBattery Low Warning Levelâ condition is met.
here a example of the mail notification with the custom action:
service: notify.smtp_gmail
metadata: {}
title: đȘ«Batterie unter 10% —
message: |-
Folgenden GerÀte haben weniger als 10% Batterie:{{'
'}}âą {{sensors|replace(', ', '
âą ')}}
This is because your are using the custom actions and you need to build your code correctly. What is happening is you have no batteries to report so it is coming up blank. Below is the FAQ for you. See points 5, 6 & 7.
Sorry may I ask what is the easiest way to update the blueprint I have to 2.1 from Version: 1.5?
Also does updating remove/delete the automation I already have added?
Do I need to redo the automation completely as a result of updating?
As such is there a way to auto update and does that auto update the automation already setup?
Sorry new to blueprints so had to ask. BTW awesome work.
There are a number of ways. The 2 easy ways are, go to the top of this post and just click the import button (blue button) again or in blueprints next to each blueprint on the right there are 3 dots. Click on it and select re-import blueprint.
No
No, some times I note some changes you need to do but this one is okay.
Thanks updated. Awesome work. I had setup a helper Battery Threshold with a slider from 0 - 100. I had added it to my front Dash to change from 20 to 10 etc as needed instead of going to the automationâs. Is there an easy way to do this for this blueprint?
Currently no, you have to go into the automation. It should be something that you set and forget. If you set it to 20% then when you get your low battery notification it should let you know what 10% it is. Then you can check the batteries that are at 10%. Also note you have a âBattery Sensors - Custom Groupâ were you can set a different % to your chosen batteries.
