Lupusec2Mqtt
Hi there,
I started this project several years ago to integrate my Lupusec Alarm System into Home Assistant.
The code was published on Github and was meant to be run in an own docker container and was also only available for amd64.
After someone ask me about the possibility to make it work on ARM based systems, I took the time to create an addon that will work on both architectures.
The addon is available as a custom repository on Github here: CyberDNS/hassio-addons-repository: My custom addon repository for homeassistant. All started with the integration of my Lupusec Alarm System. (github.com)
So feel free to use it, share your ideas or even contribute. :slightly_smiling_face:
I wish you nice holidays,
David
Thx for your work! I will test it with the x1plus :slight_smile:
Hey,
it worked like a charm! Thank you!
Unbenannt
However, I don’t understand why an extra mqtt add-on is necessary. Wouldn’t direct integration be more error-free?
many Greetings
Allgrind
Glad to hear that it is working on the XT1 too.
I would say that the simplest explanation why I haven’t implemented a direct integration is because I like the idea of Mqtt to make the code independent of the system you want to use it in. So mainly even someone using Openhab or FHEM could use the code.
But I think the most important thing in the decision is that I am a dotnet developer and have not a lot of experience with python (only small helper scripts etc.) So in using dotnet it takes me only little time to hack together new functionalities if needed.
I wish you nice (remaining) holidays,
David
Hey,
22 days later and it still works perfectly!
How long is the polling time actually?
Viele GrĂĽĂźe
Jan
It is polled every 2 seconds.
Best regards,
David
Kannst du mir sagen wie du das gemacht hast ? Habe die XT2 Plus und den Mosquito Broker installiert und auch die Cyber DNS Repo und das Lupusex2Mqtt teil. Wie kann ich das nun einbinden ? Bitte Hilf mir :.-)
Hey,
i installed everything but how can i show now that a window is open in my lovelace ? I installed the Mosquito MWTT und your LupusecMQtt and how must i go on ? Pleas help me.
Hi Christoph,
Do you see something like this in the logs?
[13:36:00 INF] Polling... (Every 5th cycle is logged) {"SourceContext": "Lupusec2Mqtt.Lupusec.PollingHostedService"}
You can use a tool like MQTT Explorer to check if the devices are published to MQTT Broker.
https://www.microsoft.com/store/productId/9PP8SFM082WD
Did you install the MQTT Integration, too?
The entities should appear automatically in that integration.
Best regards,
David
Did you also configure the Lupus integration?
Then the Enties appear in the MQTT adapter
Best regards,
Jan
I Managed it to Work now !!! Thank you very much !!! It was a User/Password Problem.
David, are you planning on making it possible to add a second lupusec system? That would be great.
Thanks!
@CyberDNS David, are you planning on making it possible to add a second lupusec system? That would be great.
Thanks!
Hi, I had no plans for the moment in doing so, but probably I will look into it if I find the time.
Best regards,
David
Is that possible that when the MQTT is activatet that i will not become any Push Notifications through my iphone ? i hope you understand me. Before i installed the MQTT with ther Lupusec Addon the push notifications has delivered. Now with the MQTT i dont become any push notifications. I this normal or is it an configuration ?
Hi Chritoph,
I don’t think that your problem is related to MQTT, seems to be a problem with the iphone app or iphone settings. Probably you could ask your question in the app section of the forum.
Best regards,
David
Ill try the addon too, since the Lupus integration in the Home Assistant core ist broken since weeks.
Iam using XT1
Glad to hear. Feel free to contact me if you have issues with the addon.
Best regards,
David
I have a problem getting everything to work. all states are updated. very well done. unfortunately i cannot change the status of the alarm system via the alarm.panel.
Hi @CyberDNS, sorry for the noob question in advance.
My setup:
HA as Docker
Mosquitto MQTT Broker as Docker
Zigbee2Mqtt as Docker
How can I install your git repo? I am kind of new in this topic.
Danke!
