Hi all,
Many people try to setup a magic miror.
I do mine so i share my config files to help some people.
My projet is divided in 2 display (2 tablets behind a miror)
Each tablet runs WallPanel to detect motion to screen on and display each container docker running instance of magic mirror.
On the first display i have :
- my surf condition
- weather forecast
- Time
- News
On the second one :
- Traffic Jam for my city (google maps)
- My list for shopping
- My to do list
For that we need 2 containers docker that is the docker-compose.yml to create that.
mirror1/docker-compose.yml
version: '2'
services:
magic_mirror:
image: bastilimbach/docker-magicmirror
container_name: magic_mirror01
ports:
- "18081:8080"
volumes:
- /var/run/docker.sock:/tmp/docker.sock:ro
- /home/gano/docker/mirror1/config:/opt/magic_mirror/config:rw
- /home/gano/docker/mirror1/modules:/opt/magic_mirror/modules:rw
mirror2/docker-compose.yml
version: '2'
services:
magic_mirror:
ports:
- "18080:8080"
volumes:
- /home/gano/docker/mirror2/config:/opt/magic_mirror/config:rw
- /home/gano/docker/mirror2/modules:/opt/magic_mirror/modules:rw
You need to adapt the path to your installation.
for mirror1 this is my config.js :
address: "",
port: 8080,
ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.1/120", "192.168.3.8", "172.17.0.1", , "Your_Tablet_IP"],
module: 'MMM-Hue',
position: 'top_left',
config: {
bridgeip:"YOUR_BRIDGE_IP",
userid: "newdeveloper",
colour: true,
refreshTime: 60 * 100,
lightsorgroups: "groups",
showOnlyOn: true
module: 'MMM-Memo',
position: 'top_center',
classes: 'default everyone', // if using MMM-ProfileSwitcher module
config: {
// See 'Configuration options' for more information.
memoTitle: "Notes",
memoDisplayIfEmpty: false,
memoDisplayHeader: true,
memoDisplayId: true,
memoRotation: '8',
memoWidth: '150px',
memoHeight: '300px',
memoMaxItems: 26
module: 'MMM-Memo',
position: 'top_right',
config: {
memoTitle: "ToDo",
memoColorBackground: "SkyBlue",
memoRotation: '-8',
memoWidth: '250px',
memoMaxItems: 26
module: 'MMM-GoogleMapsTraffic',
position: "top_left",
config: {
key: 'YOUR_API_KEY,
lat: 44.833005,
lng: -0.5930878,
height: '300px',
width: '400px'
Change your API_KEY for GoogleMaps and LAT et LONG for your location.
For mirror2 :
address: "",
port: 8080,
ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.1/120", "192.168.3.8", "172.17.0.1", , "Your_Tablet2_IP"],
language: "fr",
timeFormat: 24,
units: "metric",
modules: [
module: "alert",
module: "updatenotification",
position: "top_bar"
module: "clock",
position: "top_right"
module: "currentweather",
position: "top_right",
config: {
locationID: "xxxxxxx", //ID from http://www.openweathermap.org/help/city_list.txt
appid: "fd7f5480e4b7c64b007931c34305d337"
module: "weatherforecast",
header: "Prévisions",
config: {
locationID: "xxxxxx", //ID from http://www.openweathermap.org/help/city_list.txt
module: 'MMM-Globe',
config: {
style: 'geoColor',
imageSize: 400,
ownImagePath:'modules/MMM-SimpleLogo/public/surf.png',
updateInterval: 10 * 60 * 1000
module: "newsfeed",
position: "bottom_bar",
config: {
feeds: [
title: "Le Monde",
url: "http://www.lemonde.fr/rss/une.xml"
showSourceTitle: false,
showPublishDate: false
Ok now in Home Assistant we need to add some scripts :
envoilistemiroir:
alias: Envoi Liste Miroir
sequence:
- alias: Envoi la liste des courses sur le miroir
service_template: >
{% if is_state('input_boolean.bieres', 'on') %} shell_command.miroirbieres {% endif %}
service_template: >
{% if is_state('input_boolean.papierwc', 'on') %} shell_command.miroirwc {% endif %}
service_template: >
{% if is_state('input_boolean.coca', 'on') %} shell_command.miroircoca {% endif %}
service_template: >
{% if is_state('input_boolean.lessive', 'on') %} shell_command.miroirlessive {% endif %}
service_template: >
{% if is_state('input_boolean.poulet', 'on') %} shell_command.miroirpoulet {% endif %}
service_template: >
{% if is_state('input_boolean.steak', 'on') %} shell_command.miroirsteak {% endif %}
service_template: >
{% if is_state('input_boolean.poisson', 'on') %} shell_command.miroirpoisson {% endif %}
service_template: >
{% if is_state('input_boolean.shampooing', 'on') %} shell_command.miroirshampoo {% endif %}
service_template: >
{% if is_state('input_boolean.geldouche', 'on') %} shell_command.miroirgeldouche {% endif %}
service_template: >
{% if is_state('input_boolean.cafe', 'on') %} shell_command.miroircafe {% endif %}
service_template: >
{% if is_state('input_boolean.petitdej', 'on') %} shell_command.miroirpetitdej {% endif %}
service_template: >
{% if is_state('input_boolean.cremefraiche', 'on') %} shell_command.cremefraiche {% endif %}
service_template: >
{% if is_state('input_boolean.tomates', 'on') %} shell_command.tomates {% endif %}
service_template: >
{% if is_state('input_boolean.pommedeterre', 'on') %} shell_command.pommedeterre {% endif %}
service_template: >
{% if is_state('input_boolean.poivron', 'on') %} shell_command.poivron {% endif %}
service_template: >
{% if is_state('input_boolean.oignon', 'on') %} shell_command.oignon {% endif %}
service_template: >
{% if is_state('input_boolean.pizza', 'on') %} shell_command.pizza {% endif %}
service_template: >
{% if is_state('input_boolean.riz', 'on') %} shell_command.riz {% endif %}
service_template: >
{% if is_state('input_boolean.pates', 'on') %} shell_command.pates {% endif %}
service_template: >
{% if is_state('input_boolean.jambon', 'on') %} shell_command.jambon {% endif %}
service_template: >
{% if is_state('input_boolean.apero', 'on') %} shell_command.apero {% endif %}
service_template: >
{% if is_state('input_boolean.sacpoubelle', 'on') %} shell_command.sacpoubelle {% endif %}
service_template: >
{% if is_state('input_boolean.deo', 'on') %} shell_command.deo {% endif %}
service_template: >
{% if is_state('input_boolean.dentifrice', 'on') %} shell_command.dentifrice {% endif %}
service_template: >
{% if is_state('input_boolean.oeufs', 'on') %} shell_command.oeufs {% endif %}
service_template: >
{% if is_state('input_boolean.lardon', 'on') %} shell_command.lardon {% endif %}
service_template: >
{% if is_state('input_boolean.puree', 'on') %} shell_command.puree {% endif %}
service_template: >
{% if is_state('input_boolean.lait', 'on') %} shell_command.lait {% endif %}
service_template: >
{% if is_state('input_boolean.glace', 'on') %} shell_command.glace {% endif %}
service_template: >
{% if is_state('input_boolean.dessert', 'on') %} shell_command.dessert {% endif %}
service_template: >
{% if is_state('input_boolean.paindemie', 'on') %} shell_command.paindemie {% endif %}
service_template: >
{% if is_state('input_boolean.rhum', 'on') %} shell_command.rhum {% endif %}
service_template: >
{% if is_state('input_boolean.sopalin', 'on') %} shell_command.sopalin {% endif %}
service_template: >
{% if is_state('input_boolean.huileolive', 'on') %} shell_command.huileolive {% endif %}
effacelistemiroir:
alias: Efface Liste Miroir
sequence:
- alias: Efface la liste des courses sur le miroir
service: shell_command.cleanmiroir
effacetodolist:
alias: Efface ToDo Miroir
sequence:
- alias: Efface la ToDo List sur le miroir
service: shell_command.todoclear
addtodolist:
alias: Add ToDo Miroir
sequence:
- alias: Add la ToDo List sur le miroir
service: shell_command.todoadd
effacetodolistid:
alias: Efface ToDo Miroir id
sequence:
- alias: Efface un element de la ToDo List
service: shell_command.todoclearid
The shopping list is based on my previous post (To do list (shopping list))
and we need some shell_command :
todoadd: /usr/bin/curl -G -v http://192.168.3.8:18081/AddMemo?memoTitle=ToDo --data-urlencode "item={{states.input_text.text1.state}}"
tododel: bash /config/tododel.sh {{text}}
todoclear: /usr/bin/curl -G -v http://192.168.3.8:18081/RemoveMemo?memoTitle=ToDo --data-urlencode "item=ALL"; rm /config/todo_list
todoclearid: /usr/bin/curl -G -v http://192.168.3.8:18081/RemoveMemo?memoTitle=ToDo --data-urlencode "item={{states.input_text.text1.state}}"
Finaly the script tododel.sh :
echo $* > /home/gano/.homeassistant/temp_todo
sed -i -e "s/,//g" /home/gano/.homeassistant/temp_todo
sed -i -e "s/\[//g" /home/gano/.homeassistant/temp_todo
sed -i -e "s/\]//g" /home/gano/.homeassistant/temp_todo
a=`cat /home/gano/.homeassistant/temp_todo`
b=`grep -n $a todo_list|cut -d ':' -f 1`
echo `cat todo_list | grep -v $a` > /home/gano/.homeassistant/todo_listnew
/usr/bin/curl -G -v http://192.168.3.8:18081/RemoveMemo?memoTitle=ToDo --data-urlencode "item=$b"
We need also in configuration.yaml :
input_text:
text1:
pattern: '[a-fA-F0-9]*'
in groups.yml
todolist:
entities:
- input_text.text1
- script.effacetodolist
- script.effacetodolistid
- script.addtodolist
So now in Home Assistant if someone add a text and click on “Add ToDo Memo” the text will be send on my magic mirror.
if i do a “Efface ToDo Mirror” the Memo will be destroy.
If I do a “Efface ToDo Mirror id” only the note with the number entered in the textzone will be removed.
