then it doesnt work anymore, i dont see the state changing, i cant arm/disarm …, it just doesnt do anything…
and i think i need the manual_mqtt alarm, because i want to make use of the code_template as described in the second link above
i only want to code for DISARMING only, not to ARM
The relevant difference is described in the documentation for Manual MQTT Alarm:
Manual Alarm Control Panel is essentially the opposite of the MQTT Alarm Panel which allows Home Assistant to observe an existing, fully-featured alarm where all of the alarm logic is embedded in that physical device.
Key phrase: “Where all of the alarm logic is embedded in that physical device.” If an alarm panel is commanded to arm itself, it will (usually) expect to receive a valid passcode and then it will respond with its status (“armed”).
Manual MQTT Alarm works without a physical alarm system. It provides the same kind of command and response messages as a physical alarm system. Whats missing are the sensors and logic (automations) that perform the same functions as a physical alarm panel.
I use the MQTT Alarm Panel component with a physical alarm system (an ELK M1). However, it lacks the ability to send the passcode to the ELK M1. The M1 needs to receive a valid passcode otherwise it will ignore commands to arm/disarm itself. The component doesn’t support this feature so I modified its code so it could handle a code_command_topic. I also added state_template.
Here’s what my entry looks like using my modified component (mqtt_alarm):
alarm_control_panel:
- platform: mqtt_alarm
state_topic: "premise/home/securitysystem/securitystate"
state_template: >-
{% set values = { '0': 'armed_away', '1':'disarmed', '2':'armed_home', '3':'triggered'} %}
{{ values[value] if value in values.keys() else 'disarmed' }}
command_topic: "premise/command/home/securitysystem/securityaction"
payload_disarm: 1
payload_arm_home: 2
payload_arm_away: 0
code_command_topic: "premise/command/home/securitysystem/disarmcode"
code: !secret alarm_panel_code
retain: false
Let me know if this interests you and I’ll post the custom component’s code.
ok, thnx in advance, appreciate the comment
well, i my case, the logic is embedded in the external alarm system
i just need to send a topic arm/disarm with MQTT to my other service running on another server
in that other component is already my real actual code setup to arm or disarm
so i hassio if i use as code 1234 so i acntually can press the arm/disarm button, at the end it doesnt mather, since the code embedded in my other server is arming/disarming…
so i dont need to send the passcode, i just want a passcode, if want to use a new HA panel on my front door, so i can trow away my original panel from alarm it self
i hope this clears up ?
so therefore, if i just changed the platform from mqtt to manual_mqtt , the panel is HA is not working anymore
it doesnt change the state, and pressing arm/disarm doesnt do anything,
but i see that you use as platform: mqtt_alarm , thats again something else? i dont see it described on the pages?
ow ok, i read it now again, i need your custom component
@123 , is your custom component also capable to use a code for disarming only ? just t use on the panel, so it sends the mqtt message , so my service runnng accepts the disarm command to disarm my physical alarm system
ok, do you see a possibility for me?
i just need to have a code entered in the alarm panel, just for disarming only
i dont care what code it is, can be setup in HA,
i dont need it actually for disarming the alarm, since its already embedded in other script, i just want to have a code entered in Home assistant on the panel
Then you don’t need my custom component. MQTT Alarm already does what you want. From the documentation for code:
code: If defined, specifies a code to enable or disable the alarm in the frontend.
The code is only used by the frontend UI and is not shared via an MQTT topic. In other words, the code is not sent to another device and is only used by the UI to validate the user’s arm/disarm commands.
From what I’ve read, code is used for arming and disarming by both MQTT Alarm and Manual MQTT Alarm. So, as far as I can see, what you want (code not used for arming) isn’t supported by either component.
If you don’t want to use a code for arming, perhaps you should just create a script because they are rendered as pushbuttons in the UI. Simply push the button to arm the alarm system. The script would just use mqtt.publish to publish the arming command to riscopanel/armstatus/SET.
yes, was also thinking about a script/button for arming
but its nice to have the alarm panel, since its has a key pad
so i end with a keypad with a functional disarm button and code, but the arm button doesnt work
so i need to make a new arm button/script, that doesnt look good
another approach is to have a look at the mqtt PY code that is used now, modify it, delete the lines with arming with a code or something like that, and load it as a new custom component
Ok @123 , last question , on arming, I want to have a delay for like 30 seconds when I press the arm button, on the manual_mqtt there is a pending time, on this mqtt platform it’s missing, any idea how I can do that? Because when I arm now , it instants arms my alarm, no time to actually leave my house
Either option will work. I prefer the first one (rename it) because it reminds me that I am using a custom version of the component and not the standard version.
You could copy the relevant delay code from Manual MQTT Alarm to your custom component (and then test/debug it). However, a simpler solution would be to create an automation that serves as a broker (a ‘middleman’) between MQTT Alarm and your alarm system.
The automation subscribes to riscopanelbroker/command.
If it receives an “arm_away” command, it does two things:
– 1 Publishes “pending” to riscopanel/armstatus
– 2 Waits 30 seconds, then publishes “arm_away” to riscopanel/armstatus/SET
If it receives a “disarm” command, it immediately publishes it to riscopanel/armstatus/SET
