Hello everyone,
First, let me introduce myself. As you’ve probably noticed, I’ve registered on this forum to post this thread. I’m David, 38 years old, and I own a single-family house in NRW. I’ve automated a lot of things in my home using KNX. However, since not everything is available in KNX, I use Home Assistant to integrate third-party systems. So far, it has worked well for me, enabling me to access weather data in KNX and have my living room lights toggle when someone rings the doorbell.
My latest project involves controlling VELUX windows together with a KLF 200 Gateway using a KNX switch with the help of Home Assistant. I’m facing some challenges with this project, and the results are not satisfactory to me.
I’m using the HA Velux Integration and HA KNX Integration for this. Both of these integrations have the “Cover” data type.
I’ve set up an automation to close the VELUX cover when the KNX cover is set to “Close.” However, this is working quite poorly. It gets disrupted if the VELUX rain sensor interferes or if I use the VELUX remote control.
My automation.yaml file looks as follows:
- id: "1693424552737"
alias: EG_Bad_Dachfenster_Öffnen
description: ""
- platform: state
entity_id:
- cover.eg_bad_dachfenster
to: opening
for:
hours: 0
minutes: 0
seconds: 1
condition: []
- service: cover.open_cover
data: {}
entity_id: cover.2
mode: single
- id: "1693424804388"
alias: EG_Bad_Dachfenster_Schließen
description: ""
- platform: state
entity_id:
to: closing
condition: []
- service: cover.close_cover
data: {}
entity_id: cover.2
mode: single
- id: "1693425286843"
alias: EG_Bad_Dachfenster_Position
description: ""
- platform: state
entity_id:
to: set_cover_position
condition: []
- service: cover.set_cover_position
position: "{{ states.cover.eg_bad_dachfenster.set_cover_position.data }}"
entity_id: cover.2
mode: single
Is there a way to directly map the two covers together without dealing with complex automations?
I basically just want to do a cover.2=cover.eg_bad_dachfenster.
Does anyone have any tips for me? Unfortunately, I haven’t found anything in that direction through Google and similar sources. I’ve seen something similar with Philips Hue and KNX combined in HA, but it didn’t help me much.
Can you provide some assistance on this? Do I need to work with blueprints, perhaps?
Thank you, and have a great Sunday!
Best regards,
David
