Could anyone please tell me why I’m getting connection refused message?
16-06-10 13:59:54 homeassistant.core: BusHandler:Exception doing job
File "/usr/local/lib/python3.5/dist-packages/homeassistant/core.py", line 809, in job_handler
func(arg)
File "/usr/local/lib/python3.5/dist-packages/homeassistant/core.py", line 663, in _execute_service
service(call)
File "/usr/local/lib/python3.5/dist-packages/homeassistant/core.py", line 522, in __call__
self.func(call)
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/media_player/__init__.py", line 319, in volume_set_service
player.update_ha_state(True)
File "/usr/local/lib/python3.5/dist-packages/homeassistant/helpers/entity.py", line 145, in update_ha_state
self.update()
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/media_player/denon.py", line 76, in update
self._pwstate = self.telnet_request(telnet, "PW?")
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/media_player/denon.py", line 60, in telnet_request
return telnet.read_until(b"\r", timeout=0.2).decode("ASCII").strip()
File "/usr/lib/python3.5/telnetlib.py", line 315, in read_until
self.fill_rawq()
File "/usr/lib/python3.5/telnetlib.py", line 524, in fill_rawq
buf = self.sock.recv(50)
ConnectionResetError: [Errno 104] Connection reset by peer
16-06-10 14:00:04 homeassistant.core: BusHandler:Exception doing job
func(arg)
service(call)
self.func(call)
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/media_player/__init__.py", line 316, in volume_set_service
player.set_volume_level(volume)
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/media_player/denon.py", line 138, in set_volume_level
self.telnet_command("MV" + str(round(volume * 60)).zfill(2))
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/media_player/denon.py", line 64, in telnet_command
telnet = telnetlib.Telnet(self._host)
File "/usr/lib/python3.5/telnetlib.py", line 218, in __init__
self.open(host, port, timeout)
File "/usr/lib/python3.5/telnetlib.py", line 234, in open
self.sock = socket.create_connection((host, port), timeout)
File "/usr/lib/python3.5/socket.py", line 711, in create_connection
raise err
File "/usr/lib/python3.5/socket.py", line 702, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
I’m using a Marantz SR5008 receiver. Marantz is a subsidy of Denon, so IP Control in Denon receivers works in Marantz.
I seem to have no problems in 0.20 before an update to 0.21. (Sigh) That’s something I should not have upgraded…
And here’s another one:
16-06-10 14:05:42 homeassistant.core: BusHandler:Exception doing job
func(arg)
File "/usr/local/lib/python3.5/dist-packages/homeassistant/helpers/event.py", line 179, in pattern_time_change_listener
action(now)
File "/usr/local/lib/python3.5/dist-packages/homeassistant/helpers/entity_component.py", line 191, in _update_entity_states
entity.update_ha_state(True)
self.update()
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/media_player/denon.py", line 81, in update
self._volume = int(volume_str) / 60
ValueError: invalid literal for int() with base 10: ''
After I’ve been thinking about it, I think that might have something to do with my receiver reporting MVMAX. In my case, when telneting to my receiver, it alternates between “MVMAX 800” and “MXMAX 805” when I adjust the volume.
Does the DENON receiver do this as well?
More info after playing with my receiver for few minutes:
Setting Volume Limit to off alternates between “MVMAX 960” and “MVMAX 965” when adjusting the volume. That is, no matter the volume level.
Setting Volume Limit to -20dB alternates between “MVMAX 600” and “MVMAX 605.”
I think this may have something to do with my receiver rather than Home Assistant, but still I don’t think I’ve had a problem like this in 0.20… (confused)
