MariaDb AddOn, Error message in log after update to 2.5.2
After upgading MariaDb to 2.5.2 I have started to get an error in my log:
Log Details (ERROR)
Logger: homeassistant.components.sql.sensor
Source: components/sql/sensor.py:184
Integration: SQL (documentation, issues)
First occurred: 13:11:36 (4 occurrences)
Last logged: 13:22:36
Error executing query SELECT table_schema “database”, Round(Sum(data_length + index_length) / POWER(1024,2), 1) “value” FROM information_schema.tables WHERE table_schema=“homeassistant” GROUP BY table_schema LIMIT 1;: Can’t reconnect until invalid transaction is rolled back. (Background on this error at: Error Messages — SQLAlchemy 1.4 Documentation)
I’m new to HA and all this and can’t figure out what it is about. I googled it and some wrote about the MariaDb size sensor, but that looks to work, at least it was both updated (seconds ago) and changed (2h ago), so as far I can see that sensor works.
But how do I figure out what it is about, and what to do about it?
See the release notes topic. There has been some discussion about updates required for SQL sensors.
ehhmmmm…release notes topic…can’t even find that…
I tried all three links in the log message, but nothing fresh or anything that looks exactly the same
Is there something I can do, or is it just to wait until dev team comes out with some fix?
Is it possible to post the full log text and any other useful information in the log file?
sure! If I understand how and what…and from what I can see it doesn’t contain anything personal/secret…
I copied the complete log message and it looks like above
The full log was to long to be pasted into the forum and I was not allowed to add it as a file
Had to cut what I think was related to this - se below
Is there some other way to provide the full log file?
zwave_js_server.exceptions.FailedZWaveCommand: Z-Wave error 202: The node did not respond after 3 attempts, it is presumed dead (ZW0202)
2023-02-02 11:46:06.097 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 11:48:09.056 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Z-Wave JS' for zwave_js integration not ready yet: Failed to connect: Cannot connect to host a0d7b954-zwavejs2mqtt:3000 ssl:default [Connect call failed ('172.30.33.1', 3000)]; Retrying in background
2023-02-02 11:52:06.105 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 11:55:06.111 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 11:56:36.116 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 12:00:36.126 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 12:07:06.144 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 12:12:06.156 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 12:17:36.171 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 12:26:36.196 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 12:33:36.218 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 12:36:06.225 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 12:43:36.247 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 12:52:06.267 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 12:57:36.284 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 13:00:06.290 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 13:07:06.306 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 13:11:36.321 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 13:13:06.324 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 13:21:36.345 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 13:22:36.349 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 13:24:15.249 ERROR (DbWorker_0) [homeassistant] Error doing job: Task was destroyed but it is pending!
2023-02-02 13:37:06.389 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 13:38:06.392 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 13:42:36.402 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 13:43:36.404 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 13:45:06.409 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 13:54:36.429 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 13:56:06.432 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 13:59:36.439 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 14:03:36.451 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 14:04:06.451 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 14:05:06.455 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 14:09:36.467 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 14:10:06.468 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 14:22:06.501 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 14:25:36.510 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 14:27:06.513 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 14:30:36.522 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 14:43:36.552 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 14:44:06.554 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 14:48:36.563 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 14:49:36.566 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 14:50:36.569 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 14:51:06.572 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
2023-02-02 14:52:06.574 ERROR (SyncWorker_2) [homeassistant.components.sql.sensor] Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
It looks like it is stuck as there is a transaction that needs to be rolled back. The transaction should get rolled back automatically once the clients are disconnected.
I’d try shutting down and restarting MariaDB; see if that helps. If not try restarting everything.
What is the disk media you are using for storage?
it’s running on an NVMe SSD drive
aha…but that was HA 2023.2 and I have not applied that update yet. Planned to wait until tonight.
The error I posted about came after updating MariaDb the other day.
Ah. I misread your first sentence. Sorry.
Cleared log, stopped and restarted MariaDb and got two long error messages in log:
Error executing query SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;: (MySQLdb.OperationalError) (2013, 'Lost connection to MySQL server during query') [SQL: SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema LIMIT 1;] (Background on this error at: https://sqlalche.me/e/14/e3q8)
15:28:06 – (ERROR) SQL
Unhandled database error while processing task EventTask(event=<Event state_changed[L]: entity_id=sensor.ute_trh_signal_strength, old_state=<state sensor.ute_trh_signal_strength=-64; state_class=measurement, event=0a52097f8e0080053f0179, unit_of_measurement=dBm, assumed_state=True, device_class=signal_strength, friendly_name=Ute Signal Strength @ 2023-02-02T15:25:29.010651+01:00>, new_state=<state sensor.ute_trh_signal_strength=-56; state_class=measurement, event=0a52098f8e0080053f0189, unit_of_measurement=dBm, assumed_state=True, device_class=signal_strength, friendly_name=Ute Signal Strength @ 2023-02-02T15:27:52.903271+01:00>>): (MySQLdb.OperationalError) (2013, 'Lost connection to MySQL server during query') [SQL: SELECT state_attributes.attributes_id FROM state_attributes WHERE state_attributes.hash = %s AND state_attributes.shared_attrs = %s] [parameters: (2559563188, '{"state_class":"measurement","event":"0a52098f8e0080053f0189","unit_of_measurement":"dBm","assumed_state":true,"device_class":"signal_strength","friendly_name":"Ute Signal Strength"}')] (Background on this error at: https://sqlalche.me/e/14/e3q8)
15:27:52 – (ERROR) Recorder
Tried a full restart of HA and…fingers crossed…still nothing in the log…but I have restarted since update of MariaDb as well…
I justed tried updating my DB, and it crashed big time to the point that I had to restore the Home Assistant from Backup. is there is a procedure to update the DB and HA Core without the database crashing.
Same issue here I updated mariadb to the latest version on docker but HA feels so slow and sluggish. Did you find any solutions to this?
