I installed the most recent 2024.1.4. update. Then I rebooted my Home Assistant Supervised x86 server. After that, suddenly, MariaDb does not start any more. It is very difficult to find anything, because even the manual start of MariaDb does not run. Here is what happens when I Docker run it. Can anyone help?
~ at orava ➜ sudo docker run homeassistant/amd64-addon-mariadb:latest
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service mariadb-pre: starting
[06:49:44] INFO: Create a new mariadb
s6-rc: info: service mariadb-pre successfully started
s6-rc: info: service mariadb-core: starting
s6-rc: info: service mariadb-core successfully started
s6-rc: info: service mariadb-post: starting
[06:49:45] INFO: Starting MariaDB
2024-01-20 6:49:45 0 [Note] Starting MariaDB 10.6.12-MariaDB source revision 4c79e15cc3716f69c044d4287ad2160da8101cdc as process 119
2024-01-20 6:49:45 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
2024-01-20 6:49:45 0 [Note] InnoDB: Number of pools: 1
2024-01-20 6:49:45 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2024-01-20 6:49:45 0 [Note] mysqld: O_TMPFILE is not supported on /var/tmp (disabling future attempts)
2024-01-20 6:49:45 0 [Note] InnoDB: Using Linux native AIO
2024-01-20 6:49:45 0 [Note] InnoDB: Initializing buffer pool, total size = 134217728, chunk size = 134217728
2024-01-20 6:49:45 0 [Note] InnoDB: Completed initialization of buffer pool
2024-01-20 6:49:45 0 [Note] InnoDB: 128 rollback segments are active.
2024-01-20 6:49:45 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2024-01-20 6:49:45 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2024-01-20 6:49:45 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
2024-01-20 6:49:45 0 [Note] InnoDB: 10.6.12 started; log sequence number 42120; transaction id 14
2024-01-20 6:49:45 0 [Note] InnoDB: Loading buffer pool(s) from /data/databases/ib_buffer_pool
2024-01-20 6:49:45 0 [Note] Plugin 'FEEDBACK' is disabled.
2024-01-20 6:49:45 0 [Note] Server socket created on IP: '0.0.0.0'.
2024-01-20 6:49:45 0 [Note] Server socket created on IP: '::'.
2024-01-20 6:49:45 0 [Note] InnoDB: Buffer pool(s) load completed at 240120 6:49:45
2024-01-20 6:49:45 0 [Warning] 'proxies_priv' entry '@% root@66d6614eb4cb' ignored in --skip-name-resolve mode.
2024-01-20 6:49:45 0 [Note] mysqld: ready for connections.
Version: '10.6.12-MariaDB' socket: '/run/mysqld/mysqld.sock' port: 3306 MariaDB Server
[06:49:46] INFO: MariaDB started
curl: (6) Could not resolve host: supervisor
[06:49:46] INFO: Check data integrity and fix corruptions
mysql.column_stats OK
mysql.columns_priv OK
mysql.db OK
mysql.event OK
mysql.func OK
mysql.global_priv OK
mysql.gtid_slave_pos OK
mysql.help_category OK
mysql.help_keyword OK
mysql.help_relation OK
mysql.help_topic OK
mysql.index_stats OK
mysql.innodb_index_stats OK
mysql.innodb_table_stats OK
mysql.plugin OK
mysql.proc OK
mysql.procs_priv OK
mysql.proxies_priv OK
mysql.roles_mapping OK
mysql.servers OK
mysql.table_stats OK
mysql.tables_priv OK
mysql.time_zone OK
mysql.time_zone_leap_second OK
mysql.time_zone_name OK
mysql.time_zone_transition OK
mysql.time_zone_transition_type OK
mysql.transaction_registry OK
sys.sys_config OK
[06:49:47] INFO: Ensuring internal database upgrades are performed
[06:49:47] INFO: Ensure databases exists
[06:49:47] ERROR: Something went wrong contacting the API
[06:49:47] INFO: Create database null
[06:49:47] INFO: Ensure users exists and are updated
jq: error (at <stdin>:1): null (null) has no keys
[06:49:47] INFO: Init/Update rights
[06:49:47] INFO: Sending service information to Home Assistant
s6-rc: warning: unable to start service mariadb-post: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service mariadb-core: stopping
2024-01-20 6:49:47 0 [Note] mysqld (initiated by: unknown): Normal shutdown
2024-01-20 6:49:47 0 [Note] InnoDB: FTS optimize thread exiting.
2024-01-20 6:49:47 0 [Note] InnoDB: Starting shutdown...
2024-01-20 6:49:47 0 [Note] InnoDB: Dumping buffer pool(s) to /data/databases/ib_buffer_pool
2024-01-20 6:49:47 0 [Note] InnoDB: Buffer pool(s) dump completed at 240120 6:49:47
2024-01-20 6:49:47 0 [Note] InnoDB: Removed temporary tablespace data file: "./ibtmp1"
2024-01-20 6:49:47 0 [Note] InnoDB: Shutdown completed; log sequence number 42132; transaction id 15
2024-01-20 6:49:47 0 [Note] mysqld: Shutdown complete
[06:49:47] INFO: Service mariadb exited with code 0 (by signal 0)
s6-rc: info: service mariadb-core successfully stopped
s6-rc: info: service mariadb-pre: stopping
s6-rc: info: service mariadb-pre successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
