Marstek Venus E with esphome SML Reader as Virtual Shelly 3 Pro EM
Hey Guys,
I´ve just wanted to share my Projekt with you.
I got so much help and Ideas from this community so i want to give something back.
I´ve bought an Marstek Venus E Battery (Firmware v151) with 5,15Kwh and I have no Shelly Pro 3 EM as SmartMeter.
I use an esp8266 on my energymeter with esphome to read alle values via SML direct from it.
Problem:
I don´t want another device or service like Unimeter,B2500 oder Energy2Shelly to send the Power Data to my Battery. i like it when it even works when my whole system is on maintenance.
I tried to use unimeter and Energy2Shelly but the Battery did not accept them because i just could send Power from all phases(Added) at once and the emulators divide it by 3 and send it even.
It´s Possible to send all values over MQTT but that´s an another point of failure.
The battery tests the Shelly to determine it´s own Phase.
So it didn´t work.
Solution:
My already in Place esphome smart meter.
My Smartmeter Esphome device waits for a UDP Packet on Port 1010 with Content:
…EM.GetStatus…
That packet is send every second via Broadcast when the Battery has no smart meter associated. I´ve checked wit Wireshark. So I could find the neccessary Port 22222.
Then i respond with and udp json Packet that´s formatted as it´s a Shelly Pro 3 EM.
The Marstek Battery Accepts the value because it thinks it´s an Shelly Pro 3 EM.
I´ve found analyses online what the answer JSON has to look like.
I could not make the UDP request dynamic so I´ve set the IP and Port from the Battery manual.
As soon as the Battery Accepts the Battery it send its packets via unicast to my SML Reader.
My Opinion:
It is a bit quick and dirty, but it works for me.
I´m not a programmer but i hope some one can use it.
My Goal was that the Battery gets a precise Energy reading every second.
And it works like a charm for my zero feed in.
Feel free to optimize and change it. It´s just an Idea starter.
Here´s the code from my Energy Meter:
uart:
  tx_pin: GPIO1
  rx_pin: GPIO3
  baud_rate: 9600
  data_bits: 8
  parity: NONE
  stop_bits: 1
sml:
  uart_id: uart_bus
  - platform: sml
    sml_id: mysml
    obis_code: "1-0:1.8.0"
    unit_of_measurement: kWh
    accuracy_decimals: 4
    device_class: energy
    state_class: total_increasing
    filters:
      - multiply: 0.0000001
  - platform: sml
    sml_id: mysml
    obis_code: "1-0:16.7.0"
    unit_of_measurement: W
    accuracy_decimals: 2
    filters:
      - multiply: 0.01
  - platform: sml
    sml_id: mysml
    obis_code: "1-0:36.7.0"
    filters:
      - multiply: 0.01
  - platform: sml
    sml_id: mysml
    obis_code: "1-0:56.7.0"
    filters:
      - multiply: 0.01
  - platform: sml
    sml_id: mysml
    obis_code: "1-0:76.7.0"
    filters:
      - multiply: 0.01
  - platform: sml
    sml_id: mysml
    obis_code: "1-0:32.7.0"
    unit_of_measurement: V
    filters:
      - multiply: 0.1
  - platform: sml
    sml_id: mysml
    obis_code: "1-0:52.7.0"
    filters:
      - multiply: 0.1
  - platform: sml
    sml_id: mysml
    obis_code: "1-0:72.7.0"
    filters:
      - multiply: 0.1
    unit_of_measurement: "A"
    update_interval: 1s
    lambda: |-
      if (id(u1).has_state() && id(l1).has_state() && id(u1).state > 0) {
        return fabs(id(l1).state / id(u1).state);
      } else {
        return 0.0;
    update_interval: 1s
    lambda: |-
      if (id(u2).has_state() && id(l2).has_state() && id(u2).state > 0) {
        return fabs(id(l2).state / id(u2).state);
      } else {
        return 0.0;
    update_interval: 1s
    lambda: |-
      if (id(u3).has_state() && id(l3).has_state() && id(u3).state > 0) {
        return fabs(id(l3).state / id(u3).state);
      } else {
        return 0.0;
    update_interval: 1s
    lambda: |-
      return id(i1).state + id(i2).state + id(i3).state;
    update_interval: 60s
    lambda: |-
      return 1.0;
    lambda: |-
      return 1.0;
    lambda: |-
      return 1.0;
    unit_of_measurement: "Hz"
    accuracy_decimals: 1
    lambda: |-
      return 50.0;
udp:
  - id: udp_shelly_sender
    port:
      listen_port:    18001        # Any Port not used
      broadcast_port: 22222        # Destination Port Battery
    addresses:
      - 192.168.0.55               # Ip from  Battery
  - id: udp_server
    port:
      listen_port:    1010
      broadcast_port: 1010
    on_receive:
      then:
        - lambda: |-
            std::string msg(data.begin(), data.end());
            if (msg.find("\"method\":\"EM.GetStatus\"") == std::string::npos) return;
        - udp.write:
            data: !lambda |-
              char buf[512];
              int len = snprintf(buf, sizeof(buf),
                  "\"id\":0,"
                  "\"a_current\":%.2f,\"a_voltage\":%.1f,\"a_act_power\":%.2f,"
                  "\"a_aprt_power\":%.2f,\"a_pf\":%.2f,\"a_freq\":%.1f,"
                  "\"b_current\":%.2f,\"b_voltage\":%.1f,\"b_act_power\":%.2f,"
                  "\"b_aprt_power\":%.2f,\"b_pf\":%.2f,\"b_freq\":%.1f,"
                  "\"c_current\":%.2f,\"c_voltage\":%.1f,\"c_act_power\":%.2f,"
                  "\"c_aprt_power\":%.2f,\"c_pf\":%.2f,\"c_freq\":%.1f,"
                  "\"total_current\":%.2f,"
                  "\"total_act_power\":%.2f,"
                  "\"total_aprt_power\":%.2f"
                id(i1).state, id(u1).state, id(l1).state,
                id(l1).state, id(pf1).state, id(freq).state,
                id(i2).state, id(u2).state, id(l2).state,
                id(l2).state, id(pf2).state, id(freq).state,
                id(i3).state, id(u3).state, id(l3).state,
                id(l3).state, id(pf3).state, id(freq).state,
                id(i_total).state,
                id(verbrauch).state,
                id(verbrauch).state
              return std::vector<uint8_t>(buf, buf + len);
Got an Update to v153. It broke down :). Here´s the new config.
It even gives better values.
sml:
  uart_id: uart_bus
  - platform: sml
    sml_id: mysml
    filters:
  - platform: total_daily_energy
    power_id: export_power
    filters:
      - multiply: 0.001
  - platform: sml
    name: "Total Power Consumption"
    sml_id: mysml
    filters:
      - multiply: 0.01
    on_value:
      - sensor.template.publish:
          state: !lambda |-
            if ((id(verbrauch).state) >= 0) {
              return 0;
            } else {
              return (id(verbrauch).state /-1.0);
  - platform: sml
    name: "Power Consumption L1"
    sml_id: mysml
    filters:
      - multiply: 0.01
  - platform: sml
    name: "Power Consumption L2"
    sml_id: mysml
    filters:
      - multiply: 0.01
  - platform: sml
    name: "Power Consumption L3"
    sml_id: mysml
    filters:
      - multiply: 0.01
  - platform: sml
    sml_id: mysml
    filters:
      - multiply: 0.1
  - platform: sml
    sml_id: mysml
    filters:
      - multiply: 0.1
  - platform: sml
    sml_id: mysml
    filters:
      - multiply: 0.1
    update_interval: 1s
    lambda: |-
      } else {
        return 0.0;
    update_interval: 1s
    lambda: |-
      } else {
        return 0.0;
    update_interval: 1s
    lambda: |-
      } else {
        return 0.0;
    update_interval: 1s
    lambda: |-
    name: "Power Factor L1"
    update_interval: 1s
    lambda: |-
      if (!id(l1).has_state()) return 0.95; // Fallback
      // Power absolute value for calculation
      float power_abs = fabs(id(l1).state);
      // Export (negative power)
      if (id(l1).state < 0) {
        // Inverters typically have better PF (0.95-0.99)
        return 0.95 + (std::rand() % 4) * 0.01;
      // Import (positive power)
      else {
        if (power_abs < 20.0) {
          // Low load: worse PF (0.85-0.90)
          return 0.85 + (std::rand() % 5) * 0.01;
        } else if (power_abs < 100.0) {
          // Medium load: medium PF (0.90-0.94)
          return 0.90 + (std::rand() % 4) * 0.01;
        } else {
          // High load: better PF (0.94-0.98)
          return 0.94 + (std::rand() % 4) * 0.01;
    name: "Power Factor L2"
    update_interval: 1s
    lambda: |-
      if (!id(l2).has_state()) return 0.95; // Fallback
      float power_abs = fabs(id(l2).state);
      if (id(l2).state < 0) {
      else {
        } else {
    name: "Power Factor L3"
    update_interval: 1s
    lambda: |-
      if (!id(l3).has_state()) return 0.95; // Fallback
      float power_abs = fabs(id(l3).state);
      if (id(l3).state < 0) {
      else {
        } else {
  # Apparent power for phase L1
    name: "Apparent Power L1"
    unit_of_measurement: "VA"
    update_interval: 1s
    lambda: |-
      if (id(l1).has_state() && id(pf1).has_state() && id(pf1).state > 0) {
        return fabs(id(l1).state) / id(pf1).state;
      } else {
        return 0.0;
  # Apparent power for phase L2
    name: "Apparent Power L2"
    update_interval: 1s
    lambda: |-
      if (id(l2).has_state() && id(pf2).has_state() && id(pf2).state > 0) {
        return fabs(id(l2).state) / id(pf2).state;
      } else {
        return 0.0;
  # Apparent power for phase L3
    name: "Apparent Power L3"
    update_interval: 1s
    lambda: |-
      if (id(l3).has_state() && id(pf3).has_state() && id(pf3).state > 0) {
        return fabs(id(l3).state) / id(pf3).state;
      } else {
        return 0.0;
  # Total apparent power
    name: "Total Apparent Power"
    update_interval: 1s
    lambda: |-
      return id(apparent_power_l1).state + id(apparent_power_l2).state + id(apparent_power_l3).state;
    name: "Grid Frequency"
    update_interval: 10s
    lambda: |-
      static float last_freq = 50.0;
      // Simulate realistic, slightly fluctuating grid frequency
      // The frequency changes only slowly, never abruptly
      float new_freq = last_freq + ((float)(rand() % 5 - 2) / 20.0);  // -0.1 to +0.1 Hz change
      // Limit to realistic range
      if (new_freq < 49.8) new_freq = 49.8;
      if (new_freq > 50.2) new_freq = 50.2;
      last_freq = new_freq;
      return new_freq;
udp:
  - id: udp_sender
    port:
      listen_port: 18511
      broadcast_port: 18512
    addresses:
      - 192.168.0.54
  # 1) Sender: unicast to Venus battery 192.168.0.55:22222
    port:
      listen_port: 18001        # any local sending port
      broadcast_port: 22222     # target port of the battery
    addresses:
      - 192.168.0.55           # fixed IP of the battery
  # 2) Server: listens on port 1010 for EM.GetStatus
  - id: udp_server
    port:
      listen_port: 1010
    on_receive:
      then:
      - lambda: |-
      - udp.write:
          data: !lambda |-
            char buf[1024];
                "\"id\":0,"
                "\"src\":\"shellypro3em-e682e89c1724\","
                "\"result\":{"
                  "\"id\":0,"
              id(apparent_power_l1).state, id(pf1).state, id(freq).state,
              id(apparent_power_l2).state, id(pf2).state, id(freq).state,
              id(apparent_power_l3).state, id(pf3).state, id(freq).state,
              id(i_total).state,
              id(apparent_power_total).state
I bought the same battery (not yet shipped).
Do you have the battery connected to home assistant?
I have a shelly 3pm, so I guess I want need your work.
But I ont know (yet) how to integrate the battery to home assistant.
Any advice?
Yea I´ve added it via an esp32 with esphome over modbus.
It´s even possible to integrate it with an RS485 wifi or ethernet adapter.
Just search “Marstek Venus E Modbus” on google. there are several solutions for this.
I have not all possible Values integrated, just the one I´m interested in.
Ohh wow das sieht ja perfekt aus :slightly_smiling_face:
Looks perfect, just like I imaged it should be.
This is exaclty what I am searching for.
@jibbo can you please share your esphome Code?
Would you share your esphome yaml configuration with us?
Since my configuration is only suited for my usecase i give you the link to the site where i have my code from.
Here´s the code for a lillygo esp32 modbus device:
There´s another easy solution with an rs485 wifi adapter.
Here the translated code:
here the original link:
https://gathering.tweakers.net/forum/list_messages/2282240
Any developer here that wants to start working on the new local API for marstek devices?
Do you have any information on the local api?
Source doc etc.
Sure , I tested it with net cat commands , it works…
I’ll take a look and try with noderred first.
Absolutely no guarantee i could do it but I may have a look.
Last time I dev an ha plugins was long time ago :rofl:
seems someone already try:
going to have a look.
Ok so as my HA and the venus are not on the same network it’s not possible for me to test more (udp response timeout everytime).
Back to try on nodered (as i have a runing one on the same subnet).
hey @lemuba did you create that integration?
That one works for me, forked the project as it is not maintained anymore, so will continue on that:
Thanks @lemuba
@jibbo I took inspiration from you use of the udp component and created an esphome custom component that does something similar, but fixes the problem with port re-use.
Have a look if you like: UDP server custom component (fake shelly pro em)
I have a fake shelly-em implementation (esphome-udpserver/examples/fake_shelly_em.yaml at 3ffc323901a5edb7a0bf8aab8ffdf522df894aa3 · jsimonetti/esphome-udpserver · GitHub) thats heavily inspired by your work! Thanks!
Really Nice that my work helped you. I will have a look at this and maybe integrate it to my esp32. looks cleaner an more modifiable. Thanks for letting me know about htis
Hi, i am wondering if i could get this to work with an ESPhome DSMR meter via P1.
My Marstek already seems to think it has a sensor connected (a ct003) but I can’t get any readings from that device with my landis E360 meter.
My esphome P1 meter works flawlessly.
How would i get the Marstek to start listening to the shelly emulation?
Have a look for the b2500 project , it’s to emulate an ct003 using HA addon… In develop branch , there is development to emulate a real CT003 , even to create a fake ct003 in the marstek app, to work with multiple devices…
If you have only 1 Venus, you can use the Shelly emulator
It’s called Astrameter…
So you can use other meters and inject those in the emulator…
Tnx.
I now went the route with changing my ESPhome device itself and also having that one generate/emulate a Shelly Pro 3 EM and sending data over UDP to the Marstek.
That way it isn’t yet depending on home assistant itself, or my outdated hardware, because my HA setup needs a bit stronger Pi to run on.
I used the external component from GitHub - jsimonetti/esphome-udpserver · GitHub to have the ESPhome device send data out via UDP.
although I had to change is code slightly as it didn’t work with the latest ESPhome. I responded to a bugrequest on his github to tell what i changed to make it work.
