Master HA instance with multiple slaves
Same here, I am trying to resetup my environment and put zwave, zigbee, and wyze sense on a pi and use a VM as my Master. Does anything like remote_homeassistant need to be setup on the slave or does zwave need to be entered on the Master? I get an error Failed to call service light/turn_off. Service not found.
I advanced a bit but auth is not working.
So you only need config on master, not on slaves. I tested it and it works. Problem for me is no matter what I put in config I can’t get token or password to work. PaSsword is depreciated according to author. Token that I created via long lived token creation in user prefs in ha does not do anything and frankly I do not understand what concepts of ha architecture and exposed and integrated in this plugin.
There is so little info on this in documentation, and assumptions are made but not explained that this great work ends up not doing much for anyone until you figure out something by chance.
Post what you have. Maybe we can help correct it
Did you create the token on the remote instance or master instance?
You need to create it on the remote instance and add something like this in the configuration.yaml of the master instance:
remote_homeassistant:
  instances:
  - host: ip of remote instance
    port: HA port of remote instance
    secure: true
    verify_ssl: false
    access_token: token create on remote instance
    entity_prefix: "instance02_"
Yup you are correct,
Funny, I woke up early around 4:30AM today. While running occurred to me that token that I incorporated was from master and when I got back i incorporated remote auth_token to master instance and dropped secure option to false and viola stuff showed up on zwave panel on master.
Very cool indeed…
For others like me, here is what needs to be done:
  1. clone git repo https://github.com/lukas-hetzenecker/home-assistant-remote.git
  2. in config folder, in my case I am following dev setup (same user) so under .homeassistant extract only portion of cloned folder that starts with custom_components/remote_homeassistant as user that is bootstrapping HA
  3. setup master with simple following configuration that goes into configuration.yaml
instances:
  • host: x.x.x.x
    port: 8123
    secure: false
    verify_ssl: false
    access_token: Y0MjhlYWI3OTc1YzM1MjU1NWFkMSIsImlhd…
    entity_prefix: “Gajba1”
There is ton more options but I just needed this…
fire up remote HA first, then master and you will see something like this on master instance logs:
Connected to home-assistant websocket at ws://x.x.x.x:8123/api/websocket
After that go to zwave dashboard and you will see all stuff is now exported to master and visible to you to incorporate into polymer gui
Hope this helps others,
Thanks burnigstone and others for helping me …
Thank you for the tips, @Krash. Thanks to your suggestions on removing DuckDNS, I managed to connect to my remote HA. Did you manage to figure out how to activate DuckDNS again? And generally what is happening there? You said that you made it work with DuckDNS in the end?
Hey there.
I must admit I quit playing with this addon a year back.
From what I remember, if I had both my HA instances within the same Lan, I had to disable the duckdns addons for them to work. I believe I got it to work with enabling the duckdns only on the master, leaving rh slave with only local access. I’m guessing that’s cause my router does not support NAT loopback and at the time I had no dnsmasq or pihole running as a dns server. (I must admit that even with my master pi as dns server, I have no idea how the configuration should be done for both of them to work with duckdns access and have the master/slave connection)
When I moved my slave pi to a different location, I enabled duckdns on it and it just worked, with the ips set as stated in the documentation.
I hope this helped a bit. :slight_smile:
Following your advice, I tested them locally with the slave instance having the DuckDNS code in configuration.yaml and it did not work. I commented that code out and it started to work. I moved the slave instance to another network and connected to it via ZeroTier One and the same happened. With DuckDNS code it stops working, without the code it works.
I am not that good with networking and security to understand what you said about NAT loopback issues you had.
I am trying now via DuckDNS but having difficulties with my router and port forwarding. I will update once I succed. Thank you so much!
I don’t know what zero tier one is to be honest :slight_smile:
It worked for me with duckdns on both once the ports were configured and the HAs were accessible from outside networks.
It should also work within the same network with duckdns only on master.
Happy to help
Hi
I also have problem with connection from master to the slave.
I have two HASS instances. One on Ubuntu x86 (master) in Docker and second one (slave) on Pi3 also using Docker.
On slave I created new user and generated LongLived token.
On master I installed the addon and added to config:
  instances:
  - host: IP
    access_token: !secret xxx_access_token
I tried adding/removing options in the configuration.yaml. Whatever I do I get :
2020-06-07 10:34:10 INFO (MainThread) [custom_components.remote_homeassistant] Connecting to ws://IP:8123/api/websocket
2020-06-07 10:34:11 ERROR (MainThread) [custom_components.remote_homeassistant] Could not connect to ws://IP:8123/api/websocket, retry in 10 seconds...
I have duckdns on both instances, but I disabled it for the testing. It does not make any difference.
Is there something I am missing?
Are you publishing your slave HA at port 8123 and it works to log in via browser at the same address?
Yes. It is on 8123.
Ok. I got it working…So:
By default connection is not secure. I had to add to my config and it is working.
secure: true
duckdns components is enabled and is also working.
Just in case it helps anyone, I had to add webhooks_api: in configuration.yaml on the remote host. So far its working like a champ for my zha network entities. Is there anyway to devices? I would like to maintain my automation’s on the master instance, none of my remote buttons are showing up(guessing this is normal) Considering creating binary sensors on the remote to monitor on the master, anyone have any thoughts?
With remotes I’d rather work with events instead of entities with states. There’s a chance that there are already events fired on the machine that has the remotes when a button is pressed.
Either way its going to be some work to get them all up and running. Just so much easier in the UI to build it right off the device. I’ll put my big boy pants on and get to work lol
May I ask why you need this? Do you have a separate instance for devices that are too far away from the main instance?
Basically it boils down to 1 the need to learn something new, 2 my zigbee2mqtt install was really lagging more and more on my main instance, the cc2351 would randomly drop out requiring disconnection and reinsertion, then restarting the zigbee2mqtt add-on. I had a raspbee and RPI4 laying around so why not. Any time there was a problem with the lights the WAF went way down. Nothing more frustrating then the lights not coming on from the switch in the dark of early morning when you need to get ready for work.
But then you could install DeCONZ on the Pi and connect your Master instance to it through the network. That’s how I do it to use a ConBee stick with two instances, one for development/testing and one for production.
Yeah I had pure deconz before I went to zigbee2mqtt, I have a few devices that deconz was not supporting so I just opted to switch, figured I would try something new…again
