Matter over thread Nanoleaf bulb keeps going unavailable. Unsure fix
Hello. I’m trying to get to the root of my Nanoleaf problem. It’s a matter over thread bulb, but it keeps going unavailable. Thread border routers are Apple HomePods and Apple TV. I assume it’s connected to a HomePod since that’s what it’s closest too but have no way to know for sure. Any help would be appreciated.
I am facing the same problem using skyconnect dongle. Sometimes it looks like it’s just unavailable for a second and it’s right back.
Any luck resolving these issues? I’m considering starting a similar setup, but so far it’s not sounding like things really work seamlessly. See also:
Same issue here as well, they keep getting on and off
+1 . I have the bulb connected to matter using google home and then to home assistant using the matter server. I believe it is a matter server problem because I can control the bulb with google home, and the nanoleaf app even when I cannot control it with home assistant.
Watching this for a fix
Seeing the same on my setup, with a SkyConnect and Nanoleaf Essential Matter with Thread Bulbs.
I just installed my SkyConnect, re-configured my network firewall so that it can actually communicate with Home Assistant, and then when I started adding devices the bulbs they connect for a few minutes then enter the same loop of becoming unresponsive then reconnecting every few seconds. The bulbs have had their firmware updated, been removed from all previous services, and still continue having the same issue. When I do a power cycle on the bulb it connects for a few minutes, but then shortly goes back to looping every few seconds.
I was seeing similar behavior before with these bulbs when they were connected to an apple home setup that used an Apple TV 4K (3rd Gen.) as the Thread Boarder Router. Even in Apple home I was seeing the drop offs in the network, and continued seeing that from home assistant when I linked the lights from Apple Home to Home Assistant over Matter.
Has anyone found if this is an issue with the bulbs, or with HA / SkyConnect / Thread integrations?
Seeing the same issue myself with the Nanoleaf matter/thread downlights & skyconnect.
I had some issues with connecting any matter device to HA, which where resolved when I connected my HA yellow directly to the router, before that I was using a power line.
Only a thought
Having similar issues with my nanoleaf matter bulbs.
It seems going into HA and restarting the matter server addon fixes it.
Considering setting up a nightly restart of the service or something like that
Seeing the same thing. Restarting Matter addon doesn’t help at all
Same issue with my matter test bulbs as well, will drop off a few hours in and a recycle of the bulb doesn’t work, HA recycle doesn’t work, bulb IS connected to the wireless network though, I see traffic, Matter controller loses it though.
I’m having the same problem with Nanoleaf bulbs. Connected via thread and matter.
FYI the latest beta firmware .136 is way more stable. Have pretty consistent connection with my 24 nanoleaf GU10’s. With 2-3 randomly disconnecting every so often, but largely working
We are waiting for the next big beta firmware which will move the bulbs up to matter 1.2 (currently 1.1) and hopefully for that, however the current beta is the most stable one I have had so far.
How do I sign up for beta software updates for my Nanoleaf lights?
Im on Firmware: 3.6.196 , but I still experience random “unavailable” issues of the Nanoleaf Matter bulb.
I have the exact same issue with one of my two Essential Lightstrip, both on firmware 4.1.0
I have a similar issue (Matter + WiFi), and I am somewhat relieved that this issue is not specific to my discount light-bulbs (was considering replacing them with more pricey ones with the assumption that it was a problem with ‘cheap’ things).
If/once I find a solution, I will share it so that others can determine if it is generalizable.
Great no solutions in 2 years :joy: I just converted to 9 Nanoleaf Essential bulbs updated all the firmware. Was a beast to get them connected on thread and then on HA.
Got it all working but every night or every other night different bulbs become unavailable and available. Sometimes they can be pinged when unavailable, usually not.
The Sense+ remote is awesome so long as you don’t use matter. Matter makes it practically unusable.
I’m pretty frustrated at this point as I can’t use my smart wall switches effectively. I can’t pair the bulbs to alexa and HA. Only the Sense+ remote works reliably, so when I leave I have to grab the remote. Which is quite the opposite of convenience. I’m close to just breaking out my old TUYA bulbs and calling it a day.
If anyone has any way to get HA to EASILY reconnect the Nanoleaf Essential bulbs please help a brother out! Re-pairing 1-4 bulbs every day is not a workable solution.
My solution was to get rid of them and buy third reality bulbs instead.
Same issue. Nanoleaf essential bulb becomes unavailable after max 24 hrs. I am happy that I only bought one for testing. A shame…
Such a big brand and such a poor connectivity to HA.
What other thread able light ls can you recommend?
