esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: "my_ssid"
password: "my_pw"
ap:
ssid: "Led Matrix Fallback Hotspot"
password: "my_pw"
# Enable logging
logger:
# Enable Home Assistant API
api:
password: "my_pw"
ota:
password: "my_pw"
mqtt:
broker: pi_ip
username: ha_user
password: my_pw
web_server:
port: 80
captive_portal:
time:
- platform: homeassistant
spi:
clk_pin: D5 # D5 is connected to CLK of MAX7219
mosi_pin: D7 # D7 is connected to MOSI of MAX7219
display:
- platform: max7219digit
cs_pin: D8 # D8 is connected to CS of MAX7219
num_chips: 8
intensity: 3
scroll_speed: 100ms
update_interval: 100ms
lambda: |-
it.printf(0, 0, id(digit_font), TextAlign::TOP_LEFT, "%s", id(hatxt).state.c_str());
it.intensity(atoi(id(habri).state.c_str()));
it.scroll_left();
font:
- file: "pixelmix.ttf"
glyphs:
- '0'
- '1'
- '2'
- '3'
- '4'
- '5'
- '6'
- '7'
- '8'
- '9'
- A
- B
- C
- D
- E
- F
- G
- H
- I
- J
- K
- L
- M
- N
- O
- P
- Q
- R
- S
- T
- U
- V
- W
- X
- Y
- Z
- _
- a
- b
- c
- d
- e
- f
- g
- h
- i
- j
- k
- l
- m
- n
- o
- p
- q
- r
- s
- t
- u
- v
- w
- x
- y
- z
now getting this back:
INFO Reading configuration /config/esphome/led_matrix.yaml...
INFO Detected timezone 'CET' with UTC offset 1 and daylight savings time from 28 March 02:00:00 to 31 October 03:00:00
Failed config
display.max7219digit:
cs_pin:
number: 15
mode: OUTPUT
inverted: False
num_chips: 8
intensity: 3
scroll_speed: 100ms
Couldn't find ID 'hatxt'. Please check you have defined an ID with that name in your configuration.
lambda: !lambda |-
it.scroll_left();
rotate_chip: 0
scroll_mode: CONTINUOUS
scroll_enable: True
scroll_delay: 1000ms
scroll_dwell: 1000ms```
