Hi @YuQiang,
I have serious problems with the temperature differential … I lose the setting in a short time … can you solve? otherwise I am forced not to use the thermostat by installing the one I had before …
I currently have version P2.06H…
Regards
Hi Michele
Losing settings means the E2 chip has a problem, normally this chip could not problem, we have no solution for this issue.
We have released the new firmware v231, please download from this link:
WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free
Regards
Yu
@YuQiang great thanks. these fixed variables are written in the external eeprom or in the eeprom of the stm32 mcu? eventually I can try the replacement, thanks
Is there any chance of getting the Pinout for the Connector from the PCB (upper part) to the unit with Powersupply (part to be screwed into the wall)
There are 8 Pins soldered in my case (the pcb has 12holes and the silkcreen has numbers)
Pins are Starting at 3 up to 8
I assume there is Power 5V and ground somewhere and I want to find the trigger Pin for the relay and want to know if it is powered from the wall mounted piece itself or needs to be powered by one of the other pins.
My Device is a pretty old hardware revision and I never managed to put a firmware on it with working modbus/mqtt or similar. I want to keep the backpiece but add my own simple hardware on top with a display and some Buttons.
Hi, I have a V.309Z can you please help me how to update the firmware so I can use it with myhousepro app?
Hi, can every MC6 be updated? So it world with myhousepro app?
Hi Thijs
Yes, all MC6 could be reprogramed to new firmware, but because the old version hardware( before 2021) has different touch panel, backlight, LCD so those MC6 needs a different firmware, if you need to upgrade the old MC6 please take a picture of it then we will know which firmware fit for this.
Regards
Yu
Hi Chris,
Please email me your MC6 pcb picture, we will check it the pin details and send to you , my email is [email protected]
Regards
Yu
Hi Sler
Which model of your MC6 ? if it is heating version there are three terminals, - , RT2, RT- :
1) - , RT2 = remote air sensor, this will replace the internal sensor on the pcb if you set it in configuration menu.
2) - , RT1 = floor sensor, this sensor will limit the room floor temperature to avoid it is too hot if you enable this feature , you can set the max floor temperature in configuration menu.
Regards
Yu
I upgraded the firmware and the thermostat is working much better but the colors on the display are much dimmer/washed out. Seems like something is wrong with the blue component. Anyone recognize this? Did I break the display or is it some new setting?
@Ridax
I have the same problem as you and the brightness does not adjust. but touch is ok with 231z.
@YuQiang my pcb is 11-21-2019…but last firmware P2.06H you send me its all right…could you solve it please? thank you
Hi Michele
For the display it is because the LCD driver is different in new firmware, we will upload another firmware later today, you can try it .
About the backlight it is same issue, the old hardware has different backligh chip , we will mark the firmware name with OLD , so you can try this old firmware name .
Regards
Yu
Have you received the old touch version firmware ?
Hi @tty74it ,
I’m still waiting…
I have the same hardware as in this photo:
I thought it was the latest version of pcb and display, but the backlight setting is not doing anything. So am I wrong in believing this is the new version?
I also have this hardware but under the flat of the touch the date of the pcb is printed, mine is 21-11-2019.
However I noticed that with 231z the wifi connection is stable.
@YuQiang could you please release 231z old firmware for our hardware? Many thanks
Hi @YuQiang ,
could you please release the firmare 231z for our old hardware so we solve the display and backlight color problem? thank you
Yes, I am waiting for it as well. But wasn’t the company located in Shanghai with a large lockdown since 4 weeks?
Any luck ?
