I have some audio files that I manually located in the home_assistant_config/media folder but when I go to select media for the action there is nothing listed in My Media. I have to use the manage button to add the files and then they work but only until the next reboot, and then the files are no longer found.
root@dave-desktop:~/home_assistant_config# ls
automations.yaml blueprints configuration.yaml.save home-assistant.log home-assistant.log.fault home-assistant_v2.db-shm image scenes.yaml secrets.yaml zigbee.db
backups configuration.yaml deps home-assistant.log.1 home-assistant_v2.db home-assistant_v2.db-wal media scripts.yaml tts
root@dave-desktop:~/home_assistant_config# ls media/
'dog-barking(LOUD2).mp3' 'la-cucaracha-car-horn-(2).mp3' vintage-doorbell.mp3
As you can see, the files are there in media.
I am running HA under docker and this is the run command line
docker run -d --network=host --restart=always --name homeassistant -v /root/home_assistant_config:/config homeassistant/home-assistant
What am I missing here?
