Big update: everything that's changed since I first shared this
When I first posted this it was a bare-bones alpha. Thanks to the feedback in this thread it's grown into something genuinely useful. Here's the rundown (now at v0.10.0).
Early-dose guard with one-tap undo (newest). If a dose gets marked given well before its scheduled time, you get a warning right then with two buttons: Undo (it was an accidental tap, so it unchecks the dose and puts the supply count back) or Keep it (you meant to give it early). It's there to catch a misfire before it turns into a missed or doubled dose. This grew out of the over-dose-guard idea @IOT7712 raised.
Supply & refill tracking. Track how much of each medication you have on hand. The count drops as doses are marked given, shows doses-left and an estimated run-out date, turns red at a per-medication reorder threshold you set once (so slow-to-deliver meds can trigger earlier), and sends a refill reminder. Idea from @Tadies; the reorder-threshold detail came from feedback here.
Glanceable status. A per-patient "needs attention" sensor (problem class): red when a dose is overdue, green when all is well. It trips on elapsed time alone and fails safe toward "problem," so it works as a wall-panel light or siren too. That whole direction came from @IOT7712.
or
Scheduling. Each dose can now be daily or specific days (Mon/Wed/Fri), with 12h or 24h time display.
Cleaner dashboard. It auto-discovers every patient and dose (nothing to hand-edit), and the pill icons are blue so they don't compete with the red/green status from across the room. The today summary now splits pending doses into overdue and upcoming, the status banner tints red or green at a glance, and a refill soon line appears when a supply runs low. There's a per-patient schedule overview, and now two card files to pick from: the original single-column layout, plus a wide two-column one (a full-width status banner over two columns) sized to fill a 2-column Sections view section.
One-click automation blueprints. The companion automations (dose reminders, the mark-given confirmation, the low-supply alert, and the new early-dose warning) are now importable Home Assistant blueprints, so you add them from a button instead of pasting YAML. For anything custom there are also medication_reminder_dose_given and medication_reminder_dose_undone events to trigger off.
Plus the earlier additions: per-patient notify targets, UI reminder settings (reset time, nag window, re-nag interval), an "all doses given" sensor, patient types (person/dog/cat/...), and medications shown inline on each dose.
Still UI-driven, no YAML for schedules; entities auto-create per patient and state survives restarts.
A note on safety
Since this deals with medication, a few choices are deliberate:
- It fails safe, not silent. The "needs attention" status errs toward red: if a dose is overdue, or if it can't evaluate a dose for any reason, it flags a problem rather than showing a false "all OK." When in doubt, it tells you to look.
- It trips on time, not just taps. It re-checks every minute, so an overdue dose turns red on its own even if nobody opens the app. No stale "all clear."
- It double-checks an early tap. Mark a dose given well before its scheduled time and it warns you on the spot, with a one-tap undo that also restores the supply count, so an accidental tap doesn't quietly become a missed or doubled dose.
- It escalates a miss. Past the nag window a missed dose fires once as a high-priority, time-sensitive alert, and because it's a standard
problem sensor you can drive a physical light or siren off it so the alert is visible across the room.
- It survives restarts. What's been given today is remembered across Home Assistant restarts, so a reboot won't reset your tracking and risk a double or a missed dose.
- The tracking runs locally. The schedule, status, and red/green logic are entirely local with no cloud dependency; only the phone push needs a connection, like any HA notification.
- It won't let you run out quietly. Supply tracking flags low stock and reminds you to refill before a critical med runs out.
And, just as important, what it deliberately is not:
- It's a reminder aid, not a medical device. It can't detect that a dose was actually given, you tell it by tapping "Mark given." It warns on an early tap, but it doesn't enforce minimum gaps between doses or a maximum per day; it tracks, reminds, and nudges, it doesn't police.
- Treat it as a second set of eyes, not the only one. It's still alpha, so keep a backup method you trust, and confirm any dosing schedule with your doctor or vet.
Genuinely, thanks all! This feedback has really shaped the release into something more useful for everyone.
