I’ve only gotten FW update once on my Ecodan and I had to approve it. But yeah, they might mean on the server side.
No, it should be immediately as you can see your device using your rewritten address
Now it seems to work, thanks.
Melcloud has started operating normally in Russia. Thanks to everyone who helped me through a couple of difficult days with good advice.)
Hi. Got it working by installing addon Dnsmasq on HA-server and redirected the DNS-address. Couldn’t do that on my ASUS-router with original firmware.
Hi tesamu2, thanks for that, I’ve just installed it - could you tell me which section I need to put the redirect into? Thanks very much.
Works, commands in Edgerouter X:
configure
set service dns forwarding options address=/production.receiver.melcloud.com/52.49.107.93
commit; save
Hi. In dnsmasq, section hosts (My local network are 10.0.****):
in ASUS-router under DNS/DHCP you have to use te HA-seradress as DNS-adress.
Hi all, is MELCloud the only app for Mitsubishi air con.
Thanks very much for that, I’ll give it a try!
Hi, so MELCloud is back up and running for you?
Yes, everything works without crutches.
I can see all the IP addresses production.receiver.melcloud.com resolves to have been changed today so they’re doing something. I still get a 503 when testing manually, and I have the DNS workaround to use the IPs from leswifidata.meuk.mee.com so don’t know if my units would work.
Still not working for me here in Italy (without workarounds). I hope they’ll solve soon
Anyway, the service seems to be back, but I will keep this solution for not only this, but also other situations when i want to redirect DNS. Great addon to HA ! Good luck !
Melcloud app went down for me late on Thursday, saying not responding. I thought it was the interface units that lost connection as they were flashing error.
I reset and deleted all thinking it was my units as I use this for multiple split units in one of the locations so I hope it’s sorted out soon.
Mine went down 18th of April, 8pm. Tried various resets. Not happy
Good morning, are you saying MELCloud is back up and running, also we’re about are you please.
Hi. I dont know, but reading the other latest posts above.
