Working again also in Italy, both via Melcloud Android app and Alexa integration.
working again here in Ireland as well … Happy days… Thank you @cornubot for putting up this thread… It definitely saved me a lot of stress.
working in france for me, but the response time is very long. If I press a key in melcloud, it takes at least a minute to operate the air conditioner. Before it was almost instantaneous. (france with bbox operator)
Anyone in the uk working yet.
I will have to reset all interface units as I deleted and reset all on the 17th thinking it was my router
Working in spain too.
Yep - Derbyshire. Looks to have reconnected 45 mins ago
Working again also in Barcelona for me.
Hello, MELCloud also started working here in France since approximately 21:00 Paris time.
The first indication of the change was when all indoor units that I had turned on using the old-fashioned remote, turned off!… Actually getting consistent with the climate’s state in HA (off).
So I got back to my HA dashboard and started turning on the climates.
Hoping the situation gets resolved quickly for all of you.
Cheers!
Working in Sweden as well. At least I can see the temperature data again ( remote so I can’t tell if its really true )
Working again in Spain.
Hope this is just a one time issue.
Anyway, unacceptable lack of response from Mitsubishi.
Cheers.
Working again in Spain!, Thanks you all for sharing information. I hope it’s solved in every country!
I’m sorry, but I have reset the Wi-Fi module because I thought the error was there. Now it turns out that I only get a message that the page does not exist when I log in to 192.168.11.1, and I am logged on to the Wi-Fi module. Does anyone know how I can get back in? Or are there others who have had the same error and found a solution?
Thank you, this worked.
Interestingly, this isn’t actually in my instruction manual, it only mentions logging in via 192.168.11.1??
You just saved me a heck of a lot of work now
This video says: 192.168.11.1. Didn’t work for me.
Switched off my temporary DNS redirect, and HVACs respond now timely to HA controlled command via Melcloud. Location is Germany.
My service resumed at 20:02 in the UK
Worked for me! Thanks!
In my case I use pi-hole, in the local DNS section I have defined a CNAME (alias) record:
~$ host production.receiver.melcloud.com
production.receiver.melcloud.com is an alias for leswifidata.meuk.mee.com.
leswifidata.meuk.mee.com is an alias for prd-alb-eu-west-1-device-841540953.eu-west-1.elb.amazonaws.com.
