Mercedes Me Component
:smile:just updated to version 4296d0b. great work!
I’m from the UK and this is what I can see in the logs:
Logger: aiohttp.server
Source: custom_components/mbapi2020/client.py:67
First occurred: 1:20:55 (3 occurrences)
Last logged: 8:32:38
Error handling request
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
    resp = await self._request_handler(request)
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 118, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 169, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 60, in wrapper
    result = await method(view, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 106, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 155, in async_configure
    result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 213, in _async_handle_step
    result: Dict = await getattr(flow, method)(user_input)
  File "/config/custom_components/mbapi2020/config_flow.py", line 62, in async_step_user
    client = Client(session=session, hass=self.hass, config_entry=config_entry)
  File "/config/custom_components/mbapi2020/client.py", line 67, in __init__
    if self._config_entry.options:
AttributeError: 'dict' object has no attribute 'options'
Its a bug that I integrated last night. Give me some minutes.
please pull the latest code or refresh in HACS. Bug should be fixed.
Sorry
BR
Rene
Now works perfectly!! Thank you so much :blush:
This is great thank you. I can finally retire my janky node red flow.
Working in Ireland. I did have an issue where it would pull in my 2 cars as devices but not create any entities. One of my cars is not enabled for mercedes me (but registered to my account) so I excluded this and updated my country in the option and my entities were then created.
same for me … See Message …
Is not in add-ons
Try in HACS, Integrations, Custom repositories (tree dots in uper right corner)
As a smart fortwo EQ owner, I am following this thread because my car is visible in
my mercedes.me account! I installed your component without issues and everything looks fine, although I do not get any entities. If you have a spare moment, could you look if it is possible to support the Smart Cars? Ofcourse if I can help or test, please let me know! Thank you!
@ReneNulschDE fyi so far looking really good! a small error fyi:
Logger: custom_components.mbapi2020.client
Source: custom_components/mbapi2020/client.py:175
Integration: MercedesME 2020 (documentation, issues)
First occurred: 0:22:45 (1 occurrences)
Last logged: 0:22:45
Error with the websocket connection: Received message 257:None is not bytes
I even managed to get a small card up already ;-). Keep up the good work!
any chance you could share your card setup? it looks nice
I will, give me a bit of time to clean it up a bit and make it better ;-). I will post it in this forum.
your work is very great!
Great work! Works good with an E300de and I can throw away the Node-RED implementation.
The new version is working great with my C300de as well.
The only question I have is how to interpret the state values of the attribute chargingstatus in the range_electric sensor. Maybe I’ve overlooked it, but I could not find any description.
At the moment the state is 3 = charging finished(?). The mercedes me app describes the status as “charging cable disconnected”.
Edit:
I discovered the values on my car by comparing with the app:
chargingstatus = 0 means charging
chargingstatus = 1 means charging finished
chargingstatus = 2 ?? unknown
chargingstatus = 3 means charging cable disconnected
@ReneNulschDE - It will work for US region and for 2017 vehicles ? What are the minimum requirements ?!
Thank you.
I guess the minimum requirement would be that you can use the Mercedes Me app to access your car’s data.
@robertklep -
Mercedes US Region has two different apps/platforms for different years models (excluding 2013-2015 witch is using first version of mbrace):
  1. 2016 to 1018 is using Mercedes ME - mbrace for 2016-2018 Models | Mercedes-Benz USA (mbusa.com)
  2. 2019 to present is using Mercedes me connect - Mercedes me connect | Mercedes-Benz USA (mbusa.com)
So my question was if mbrace for 2016-2018 vehicules will work with this component.
Also - to answer to your statement - Yes - I can access my vehicle’s data with my Mercedes ME app for mbrace but my goal is to integrate my 2017 GLS450’s data into my HA - if possible.
Thanks.
I have a 2016/17 c350e and it works fine for me…
Hi @DerekO -
Perfect - great news - are you in US region ?
After I have installed the custom repo under HACS - and installed the integration under Configuration > Integrations - this is what I see:
It is there something that needs to be done prior ? I have followed all the integration install/config instructions line by line…
