thanks for pointing me in the right direction. It works and is really a big benefit! Where can I buy you a beer?
Hi, is it possible to disable a scheduled preconditioning with the integration? I used
preheat_start_departure_time
to activate it, but I am not sure how to disable it.
Hi @lordofthewinds ,
This is not possible with the current release. The next release will have a new service âpreheat_stop_departure_timeâ.
The code is part of the master branch already, feel free to test.
BR
Rene
Hi @modem-man-gmx ,
sorry, I missed your message - Iâm not so deep in the different docker deployment options as Iâm running my environments with the plain core. However, the component has only one dependency to protobuf and this is supported on armv8.
You will have to use HACS as Iâm not providing a container for this.
BR
Rene
Hallo Rene,
I noticed that (at least on my car), the sensor.XXX_charging_power
seems to stop working (around 27 November 2023).
Curiously, the attribute ChargingPower
inside sensor.XXX_range_electric
still lists the charging power correctly.
Any idea whatâs going on? I know that Mercedes had some outages of their Mercedes Me services a couple of days ago.
Thanks,
Thomas
Hi Thomas,
This could happen when the charging power information is not delivered via the api on HA-startup. Give me some time to check this with my cars.
The attributes are dynamic and added whenever the info becomes available. But this is not the case for sensors currently. I have an idea of how to solve this.
BR
Rene
Hi there, just a quick question, will a 2018 model in Norway work?
Hi, yes - should work. Available features are depending on the purchased services. BR Rene
I have released a new minor release v0.9.7 with some new stuff and some fixes tooâŚ
But great things first: Thanks for your 100 Github Repo stars.
New:
- New Buttons for starting/stopping the preconditioning of a car (preheat, Mode âNowâ)
- New Service âSERVICE_PREHEAT_STOP_DEPARTURE_TIMEâ to stop a preheating/preconditioning that was initiated by departure time
Fixes:
Hi @Thomas01 ,
I canât reproduce this for the charging_power sensor but see this for the âElectric consumption startâ sensor currently.
I shared the reason already in my first answer.
My idea would be to integrate âDefault valuesâ for sensors like charging_power (0 in this case). For sensors like âElectric consumption startâ the latest recorded status could be the right default. What is your opinion?
BR
Rene
Hallo Rene,
I kind of confirmed your observation, as I restarted HA during the time my car was charging, and the sensor.XXX_charging_power
was populated.
Regarding your question: For parameters that tend to change quickly and infrequent (i.e. charging power - jumping from none to 11kW, to 150kW or so), I would prefer a â0
â as the default.
For parameters that tend to change slowly (i.e. (average) consumption), your idea of using the last known value seems the right idea.
Or could a ânoneâ (or the HA equivalent) work here?
On a related note: I noticed that the attribute âchargingstatus
â (inside sensor.XXX_range_electric
) looks like an integer, but is coded as a string.
Is that something that the MB API spits out, or a conscious decision on your part? Iâm good either way, just did cost me some hours figuring out why my comparison to 0
(as the number) failed.
Its working fine. I had to check this: Disable capabilities check
Then I could see alot more settings. Thanks one million for this add-on
Hi @kvast ,
thanks for the feedback. Could you give a little bit more background on what was missing before you enabled âDisable cap checksâ? I implemented this option for US market some years ago and it should have no effect in Europe.
BR Rene
Hi @Thomas01
thanks for your feedback. Let me try to implement this, I will start with the â0â-Default Value sensorsâŚ
Regarding:
Yes, all the values should be strings as the MB-API delivers the values as string. (and the API gives also a hint regarding the type but I never found the energy or value to implement this) - Therefore: All attributes should be handled like strings.
BR
Rene
I could just see if car was locked, windows etc. Dont remember all, but now it works super
just noticed the update of the integration, with the included buttons for the pre-entry climate.
I just want to share my previous solution, a simple toggle switch, and looking for both the commanded pre-entry climate, as well as the timer based one.
switch:
switches:
eqs_precond:
friendly_name: Pre-entry Climate Control
value_template: "{{ state_attr('sensor.XXX_range_electric', 'precondNow') or state_attr('sensor.XXX_range_electric', 'precondActive') }}"
icon_template: mdi:air-conditioner
turn_on:
service: mbapi2020.preheat_start
target: {}
type: '0'
vin: W1Kxxx
turn_off:
service: mbapi2020.preheat_stop
target: {}
vin: W1Kxxx
Thanks for the continued work,
Thomas
Sorry but im new to HA. can you share on how I can create a button that starts the pre-heater and indicate the its on?
Put the code I shared into configuration.yaml
(if you already have a section called âswitch:
â, put the code without the switch:
part below your definition, before the next section starts).
Do not forget to change the sensor.XXX
to your sensor name, and change the vin W1Kxxx
to your VIN.
418, message=âIâm a teapotâ,
The integration is not working right now. For some of you the teapot error is not new, means MB changed their APIs again and gave me a christmas presentâŚ
Update 1: The code in the master branch on github should work for Europe again. Working on the other regions and plan to push a release soon.
I have published an Hotfix Release to address the teapot error. As always something new was in the making and is part of the release too. (Even it is not 100% final - but should work)
v0.9.8 - Teapots, Windows, Translations Latest
IMPORTANT
Please open your MB mobile app and check if you have to accept new terms & conditions.
Fixes
- Teapot error message fix for (hopefully) all regions (fixed: #159) - Canât test this for all regions but US and EU looks good
- The option to reload the component in the frontend was removed for now - please restart HA in case of problems (fixed: internal)
- FIN/VIN is masked in the homeassistant.log now
New
- Some attributes of the Lock sensor have translated names and values now. This is in the frontend only and should have no impact on automations, scripts and so on. English only. Use the developer-tools/states function to see the original values if needed.
Internal
- There is an early support for default value handling for sensors. Its disabled for now but should solve the âmissing sensor at startupâ-problem in the future. (In case you miss for example the chargingkw sensor, get in touch with me whenever you want to test this)
